yameen
Audio cut off with festival and espeak
Thu Apr 16, 2015 5:08 pm
I am experiencing some rather strange problems with tts, tried festival directly and espeak, I end up getting the audio only for latter half.
so:
echo “Hello World” | festival --tts
and
espeak -ven+f3 -k5 -s150 "Hello World"
give only the audio 'world', it sounds like its un-naturally clipped
I have followed the instruction to set this up from http://elinux.org/RPi_Text_to_Speech_%2 ... nthesis%29
I have seen a couple of post suggesting I fill in garbage leading what I want to output, this feels a little wrong, considering I recall getting this to work on the raspbian on a raspberry pi 1.
current setup is:
Raspbian 3.18, raspberry pi 2, HDMI audio (forced as I couldn't get the jack audio to work)
Any help or pointers appreciated.
dom
Re: Audio cut off with festival and espeak
Thu Apr 16, 2015 5:38 pm
It's probably just the amount of time your tv takes to "warm up" before it can produce audio. I suspect with analogue (or a different tv) this wouldn't be an issue.
To work around this, you need the audio channel to remain open, not open/close every time you launch festival/espeak.
Try adding to config.txt
force_hdmi_open=1
and reboot. That may fix it. Alternatively play silence in the background (e.g. "aplay silence.wav &" and find a silent wav file) to keep the channel open.
