BPTMatthew
Resizing the root partition
Mon Jul 09, 2012 7:09 pm
I recently noticed that my raspberry pi only has a 1.6gb root partition, and after a few packages being installed there is almost no space left whatsoever to install any more.
What I was wondering was whether or not it was possible to resize this partition to take up the extra 5.6gb of unallocated space on the SD card without having to reformat, or whether or not its possible to just install new packages to a new 5.6gb partition on the SD card.
Have been battling this problem for a few days and no windows program wants to allow me to increase the size of this root partition.
Any help would be greatly appreciated :)
Matt
itimpi
Re: Resizing the root partition
Mon Jul 09, 2012 8:06 pm
Instructions on how to do this can be found at http://elinux.org/RPi_Resize_Flash_Partitions . The end gives you a method that can be used to do it in-situ on the Pi.
BPTMatthew
Tue Jul 10, 2012 6:13 am
Thanks! Problem sorted.
Matt
mark0978
Wed Aug 01, 2012 7:51 pm
As of 8/1/2012 (possibly earlier), the auto config in wheezy makes this as simple as picking a menu option, no need to do anything more. Image the SD card, boot, pick the option, reboot machine.
drgeoff
Wed Aug 01, 2012 11:03 pm
mark0978 wrote:As of 8/1/2012 (possibly earlier), the auto config in wheezy makes this as simple as picking a menu option, no need to do anything more. Image the SD card, boot, pick the option, reboot machine.
Please try not to use a purely numeric date format when posting to this and other forums with a worldwide readership.
W. H. Heydt
Thu Aug 02, 2012 2:35 am
2012-8-1 would be a world usable "purely numeric" date expression. However, I do understand the protest about ambiguous dates. ON the other hand, *no*one* was talking about Wheezy in January as far as I recall...
Jim JKla
Thu Aug 02, 2012 7:31 am
Since at this time there's only two dates for the Wheezy and the first is the beta it's a little hard to get confused.
Later on we will probably have a release letter like Wheezy "c"...... till then I wouldn't worry. ;)
Noob is not derogatory the noob is just the lower end of the noob--geek spectrum being a noob is just your first step towards being an uber-geek ;)
If you find a solution please post it in the wiki the forum dies too quick
