frafrichile
php, python, cgi, apache
Sat Apr 11, 2015 7:16 am
Hello everyone
I followed this tutorial http://www.raspberrypi-spy.co.uk/2013/1 ... n-mcp3008/
I got it working thank god, took me a while but finally came through.
my question now is .I have a server set up on the raspberry pi. How can I make the data that I get from running the python script to be visible on my webserver.
This is the code I am working with
#!/usr/bin/python
import spidev
import time
import os
# Open SPI bus
spi = spidev.SpiDev()
spi.open(0,0)
# Function to read SPI data from MCP3008 chip
# Channel must be an integer 0-7
def ReadChannel(channel):
  adc = spi.xfer2([1,(8+channel)<<4,0])
  data = ((adc[1]&3) << 8) + adc[2]
  return data
# Function to convert data to voltage level,
# rounded to specified number of decimal places.
def ConvertVolts(data,places):
  volts = (data * 3.3) / float(1023)
  volts = round(volts,places)
  return volts
# Function to calculate temperature from
# TMP36 data, rounded to specified
# number of decimal places.
def ConvertTemp(data,places):
  # ADC Value
  # (approx)  Temp  Volts
  #    0      -50    0.00
  #   78      -25    0.25
  #  155        0    0.50
  #  233       25    0.75
  #  310       50    1.00
  #  465      100    1.50
  #  775      200    2.50
  # 1023      280    3.30
  temp = ((data * 330)/float(1023))-50
  temp = round(temp,places)
  return temp
# Define sensor channels
light_channel = 0
temp_channel  = 1
# Define delay between readings
delay = 5
while True:
  # Read the light sensor data
  light_level = ReadChannel(light_channel)
  light_volts = ConvertVolts(light_level,2)
  # Read the temperature sensor data
  temp_level = ReadChannel(temp_channel)
  temp_volts = ConvertVolts(temp_level,2)
  temp       = ConvertTemp(temp_level,2)
  # Print out results
  print "--------------------------------------------"
  print("Light: {} ({}V)".format(light_level,light_volts))
  print("Temp : {} ({}V) {} deg C".format(temp_level,temp_volts,temp))
  # Wait before repeating loop
  time.sleep(delay)
Thanks again
Laurens-wuyts
Re: php, python
Sat Apr 11, 2015 7:26 am
For displaying python data on a webpage, you can use cgi. ;)
Laurens
frafrichile
Re: php, python
Tue Apr 21, 2015 12:42 am
I got cgi working on an apache server. But how do I embed the script or what do I need to do??
Thanks!
Laurens-wuyts
Re: php, python
Wed Apr 22, 2015 10:34 am
Just use the script and use print to display the code. ;)
Laurens
WebPi
Re: php, python
Wed Apr 22, 2015 3:53 pm
You need to save the script in /usr/lib/cgi-bin and make sure it has executable permissions.
Next, add some code near the start of your script to print HTTP headers:
print "Content-type: text/html\n\n"
Add HTML formatting to the output:
print "<bold>Light:</bold>"
Here's a crash course in CGI scripting: http://raspberrywebserver.com/cgiscripting/
raspberrywebserver.com - Raspberry Pi tutorials
LinuxWebServers.net - Linux Web Server tutorials and examples
pyplate.com - Python web publishing tool
frafrichile
Re: php, python, cgi, apache
Thu Apr 23, 2015 3:20 am
I will give it a try.
Thank you
My next question is how can I make this data go on a google sheet? I want to be able to graph it. and be able to see it on my server.
WebPi
Thu Apr 23, 2015 12:30 pm
You could try following this tutorial about Google Docs: https://learn.adafruit.com/dht-humidity ... cs-updated
Alternatively, you could store the data in an SQLite database: http://raspberrywebserver.com/sql-databases/
frafrichile
Tue Apr 28, 2015 12:28 am
Thank you guys. you are all very helpul
I put the python script mcp3008.py in this folder /usr/lib/cgi-bin . now the file is there but do I go to
http://192.168.2.100/cgi-bin/mcp3008.py ???????
and if so all I get is
Light:
Does the python script mcp3008.py have to be running or somehow cgi calls the script?
WebPi
Tue Apr 28, 2015 12:46 am
Apache will call the script, so you don't need to start it in advance. It looks like you're using the correct URL. Make sure the script is executable. Also, double check that you added the AddHandler directive to /etc/apache2/sites-enabled/000-default (see http://raspberrywebserver.com/cgiscript ... ython.html).
frafrichile
Tue Apr 28, 2015 4:14 pm
hmm
I did all the above, yet still I don't see the data.
All I see is
Light:
WebPi
Tue Apr 28, 2015 4:19 pm
Are there any error messages in /var/log/apache2/error.log?
frafrichile
Thu Apr 30, 2015 2:18 am
WebPi wrote:Are there any error messages in /var/log/apache2/error.log?
This is what I see
[Wed Apr 29 21:15:37 2015] [error] [client 192.168.2.1] Traceback (most recent call last):
[Wed Apr 29 21:15:37 2015] [error] [client 192.168.2.1]   File "/usr/lib/cgi-bin/mcp3008.py", line 21, in <module>
[Wed Apr 29 21:15:37 2015] [error] [client 192.168.2.1] spi.open(0,0)
[Wed Apr 29 21:15:37 2015] [error] [client 192.168.2.1] IOError: [Errno 13] Permission denied
[Wed Apr 29 21:15:38 2015] [error] [client 192.168.2.1] File does not exist: /var/www/favicon.ico, referer: http://192.168.2$
This is my currrent code, so far
#!/usr/bin/env python
# This script reads data from a
# MCP3008 ADC device using the SPI bus.
# Author : Matt Hawkins
# Date   : 13/10/2013
# http://www.raspberrypi-spy.co.uk/
import spidev
import time
import os
# Open SPI bus
spi.open(0,0)
  return data
  return volts
  # ADC Value
  #    0      -50    0.00
  #   78      -25    0.25
  #  155        0    0.50
  #  233       25    0.75
  #  310       50    1.00
  #  388       75    1.25
  #  465      100    1.50
  #  543      125    1.75
  #  620      150    2.00
  #  698      175    2.25
  #  775      200    2.50
  #  853      225    2.75
  #  930      250    3.00
  # 1008      275    3.25
  # 1023      280    3.30
  return temp
light_channel = 0
temp_channel  = 1
delay = 5
while True:
  # Print out results
  print "------The 'Ponics Project--------------------------------------"
  print("Light : {} ({}V)".format(light_level,light_volts))
  print("Temperature in the room  is: {} ({}V) {} deg F".format(temp_level,temp_volts,(temp * 9/5)+ 32))
  time.sleep(delay)
Thanks !
WebPi
Sat May 02, 2015 4:24 pm
This is a problem with the permission of the SPI interface. I think it's owned by root, but your script is running as Apache's user name, www-data. You need to give www-data access to SPI.
According to this thread, you need to add www-data to the spi group: viewtopic.php?f=28&t=106814
This is the command you need to use:
sudo adduser www-data spi
frafrichile
Sun May 03, 2015 8:43 pm
WebPi wrote:This is a problem with the permission of the SPI interface. I think it's owned by root, but your script is running as Apache's user name, www-data. You need to give www-data access to SPI.
awesome.
I am trying this at the moment but the group "spi" does not exist. thats the message I get
Thank you !
frafrichile
Fri May 08, 2015 5:41 pm
I still cannot figure it out :/
I tried adding the user but nothing.
[email protected] /usr/lib/cgi-bin $ sudo adduser www-data spi
adduser: The group `spi' does not exist.
[email protected] /usr/lib/cgi-bin $ sudo addgroup spi
Adding group `spi' (GID 1002) ...
Done.
Adding user `www-data' to group `spi' ...
Adding user www-data to group spi
Done.
any ideas?
joan
Fri May 08, 2015 6:03 pm
There is no point in adding a spi group as it won't help, if it's relevant the group would already exist.
You need to look at the spi device and see the access permissions.
What is reported by
ls -l /dev/spi*
My Pi2 shows
crw-rw---- 1 root spi 153, 0 May  7 22:57 /dev/spidev0.0
crw-rw---- 1 root spi 153, 1 May  7 22:57 /dev/spidev0.1
frafrichile
Fri May 08, 2015 6:12 pm
joan wrote:There is no point in adding a spi group as it won't help, if it's relevant the group would already exist.
What is reported by
ls -l /dev/spi*
My Pi2 shows
this is what mine reads
crw------- 1 root root 153, 0 Dec 31  1969 /dev/spidev0.0
crw------- 1 root root 153, 1 Dec 31  1969 /dev/spidev0.1
date seems weird.
Fri May 08, 2015 6:19 pm
sudo apt-get update && sudo apt-get dist-upgrade
will get your system updated (to the new Raspbian stuff as at yesterday) and one of the new packages will add the spi group and will add the pi user to the spi group.
This is a doctor free zone.
joan
Fri May 08, 2015 6:50 pm
DougieLawson wrote:sudo apt-get update && sudo apt-get dist-upgrade
...but make sure you delete the spi group you created before doing this.
frafrichile
Sat May 09, 2015 4:39 pm
Did all the above.
Still having the same problem :/
<type 'exceptions.IOError'>	Python 2.7.3: /usr/bin/python
Sat May 9 11:38:25 2015
A problem occurred in a Python script. Here is the sequence of function calls leading up to the error, in the order they occurred.
 /usr/lib/cgi-bin/mcp3008.py in ()
     23 # Open SPI bus
     24 spi = spidev.SpiDev()
=>   25 spi.open(0,0)
     26
     27 # Function to read SPI data from MCP3008 chip
spi = <SpiDev object>, spi.open = <built-in method open of SpiDev object>
<type 'exceptions.IOError'>: [Errno 13] Permission denied
      args = (13, 'Permission denied')
      errno = 13
      filename = None
      message = ''
      strerror = 'Permission denied
