I don't know. Try it, then tell us how you got on. Use Google. If you get stuck at particular points, post here what you want to achieve, what you tried, and what actually happened.rpiswag wrote: can I turn the pi into a wifi pineapple?
I think you should use your Pi and run fruity WiFi on it.rpiswag wrote:Thank you but before I do that I would like to know if I should buy the TP-LINK TL-WR702N for $18 or should I use my pi and run fruity wifi on it? I have an alpha networks awus036h usb wifi adapter but does fruity wifi support that model because it uses a realtek chip set and fruity wifi on there website says that fruity wifi supports realtek chip sets?
On their forum?rpiswag wrote:Where do I contact the developers?
I think you should buy an alpha networks awus036h.rpiswag wrote:What wifi adapter would you recommend that works with fruity wifi that is under $20. The wifi adapter would have to work with every module in fruity wifi. Preferably one I could buy from Amazon.com
Oh. But I read on the internet that fruity wifi, on their website, says that fruity wifi supports realtek chip sets.rpiswag wrote:The alpha networks awus036h wifi adapter don't support all the modules in fruity wifi and I am looking for a network card that does. A card that uses and atheros chipset is the one that I am looking for and the alpha networks awus036h wifi card does not it uses a realtek chipset.
You can use any wireless card supported by Hostapd (like Atheros chipsets) to get all the functionalities on FruityWifi. If the card is not supported (like Realtek chipsets) you can use the [AP] mode Airmon-ng but you will lose some functionalities like Karma and/or Mana.
Ok, well I think you should buy a wifi card with an Atheros chipset.rpiswag wrote:Yes it does (kind of). Fruity Wifi will run in a Realtek chip set but not all of the modules work and fruity wifi can only work in ap mode. That is why I want to use a Atheros chip set because it can use all of the features that fruity wifi has to offer. Here is a quote from another post in this thread relating to what I just mentionedYou can use any wireless card supported by Hostapd (like Atheros chipsets) to get all the functionalities on FruityWifi. If the card is not supported (like Realtek chipsets) you can use the [AP] mode Airmon-ng but you will lose some functionalities like Karma and/or Mana.
No. Sorry. You could probably find one on Amazon.rpiswag wrote:Do you know of a specific model you would recommend?
I don't know. I heard you can use any wireless card supported by Hostapd (like Atheros chipsets) to get all the functionalities on FruityWifi.rpiswag wrote:Thats ok! I was thinking about getting the alpha awus036hna. Here is a link http://www.amazon.com/Alfa-AWUS036NHA-W ... awus036nha. Will this wifi adapter work with all of the modules that Fruity Wifi supports?
