Jossep
Setting the time with GPS and RTC
Fri Apr 10, 2015 10:45 am
there's a lot of discussion about setting the time on your pi but I do not find a satisfying answer.
I have the adafruit ultimate GPS breakout connected to my pi. It is RTC battery-compatible.
I have a bicycle, attached with a few sensors + the GPS. I use an external battery to power my pi.
I write the sensor data to a file with every line timestamped. Unfortunately the time isn't right because my pi isn't connected to the internet.
So i bought the cr 1220 backup battery, which can be plugged in to the gps breakout.
My question is: how do I properly set the pi's time with my gps/rtc?
Jossep
Re: Setting the time with GPS and RTC
Fri Apr 10, 2015 12:04 pm
Thanks for the quick response.
I've checked the url but there's a hell of a lot information there.
I think there must be a much quicker/easier/obvious explanation to set the time with my rtc/gps?
ame
Fri Apr 10, 2015 12:11 pm
You're right. There must be something easier. Why not google for a while and see how you get on.
scotty101
Fri Apr 10, 2015 1:06 pm
A very quick google search turned up the following page. Is this too long?
http://blog.retep.org/2012/06/18/gettin ... pberry-pi/
