I believe I have a model B (Ethernet, Standard size SD-Card, 2 USB ports + RCA NTSC jack), that has it's HDMI video fading in and out. The device has over a year of stable performance and was playing a video perfectly when the video started cutting out. Flashes of white 'static' precede the video dropping out. Troubleshooting steps performed include:
* swapping power supplies
* verifying that TV HDMI port is good
* swapping out SD card (video still cuts out)
The video and sound cuts-out whether it is displaying the XBMC / Kodi menu, playing a video or playing music.
System is running KODI, however, the other SD card tested is running a different distro and cuts out. The drop-out behavior started in the middle of a movie tonight and is new.
Questions:
1) has anyone seen this issue?
2) what tests can be performed to identify the issue?
Actionable diagnostic suggestions are appreciated: Thank you.
