ccy
reboot or poweroff hang with Raspberry Pi 2
Sat Apr 04, 2015 3:21 pm
I installed the latest ArchLinux ARM and updates for Raspberry Pi 2. The installation works and Raspberry Pi works.
However, when I run
reboot
or
poweroff
, the system will hang in half way and no response. I have tried power off the Pi and same problem happen. My Pi should has enough power to run (2A).
After some tries, I notice that if I unplug the USB keyboard when Pi hang during
reboot
or
poweroff
, then it continue to run to reboot or poweroff finally. I suspect the USB device/services is responsible for the freeze issue.
Any ideas on how problem? Please advice. Thanks.
kusti8
Re: reboot or poweroff hang with Raspberry Pi 2
Sat Apr 04, 2015 7:02 pm
You can view the logs using dmesg. Post them here so we can sift through them.
There are 10 types of people: those who understand binary and those who don't.
Sat Apr 04, 2015 7:11 pm
kusti8 wrote:You can view the logs using dmesg. Post them here so we can sift through them.
It's better to use
sudo apt-get install pastebinit
dmesg | pastebinit # which returns a URL
Then post that URL of the dmesg stuff on here.
sdjf
Mon Apr 06, 2015 3:48 am
Dougie, we do not use apt-get in Arch, please note which OS and subforum before suggesting a wrong package manager.
FORUM TIP: To view someone's posting history, sign in, click on their user name, then on "Search User's Posts." || Running ArchLinuxArm on Model 2B and 512MB Model B
Mon Apr 06, 2015 8:25 am
Whatever!
ccy
Tue Apr 07, 2015 1:45 am
Here is the dmesg log:
[root@alarmpi ~]# dmesg
[    0.000000] Booting Linux on physical CPU 0xf00
[    0.000000] Initializing cgroup subsys cpuset
[    0.000000] Initializing cgroup subsys cpuacct
[    0.000000] Linux version 3.18.10-3-ARCH (builduser@leming) (gcc version 4.95
[    0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instructie
[    0.000000] Machine model: Raspberry Pi 2 Model B
[    0.000000] cma: Reserved 8 MiB at 0x36800000
[    0.000000] Memory policy: Data cache writealloc
[    0.000000] On node 0 totalpages: 225280
[    0.000000] free_area_init_node: node 0, pgdat 80aae580, node_mem_map b611300
[    0.000000]   Normal zone: 1760 pages used for memmap
[    0.000000]   Normal zone: 0 pages reserved
[    0.000000]   Normal zone: 225280 pages, LIFO batch:31
[    0.000000] [bcm2709_smp_init_cpus] enter (85c0->f3003010)
[    0.000000] [bcm2709_smp_init_cpus] ncores=4
[    0.000000] PERCPU: Embedded 10 pages/cpu @b60e1000 s12224 r8192 d20544 u4090
[    0.000000] pcpu-alloc: s12224 r8192 d20544 u40960 alloc=10*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pa0
[    0.000000] Kernel command line: dma.dmachans=0x7f35 bcm2708_fb.fbwidth=656 p
[    0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Memory: 873080K/901120K available (7554K kernel code, 479K rwdat)
[    0.000000] Virtual kernel memory layout:
                   vector  : 0xffff0000 - 0xffff1000   (   4 kB)
                   fixmap  : 0xffc00000 - 0xffe00000   (2048 kB)
                   vmalloc : 0xb7800000 - 0xff000000   (1144 MB)
                   lowmem  : 0x80000000 - 0xb7000000   ( 880 MB)
                   modules : 0x7f000000 - 0x80000000   (  16 MB)
                     .text : 0x80008000 - 0x809e8c80   (10116 kB)
                     .init : 0x809e9000 - 0x80a44000   ( 364 kB)
                     .data : 0x80a44000 - 0x80abbc1c   ( 480 kB)
                      .bss : 0x80abbc1c - 0x80b80550   ( 787 kB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000] NR_IRQS:608
[    0.000000] Architected cp15 timer(s) running at 19.20MHz (virt).
[    0.000014] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 3579s
[    0.000035] Switching to timer-based delay loop, resolution 52ns
[    0.000314] Console: colour dummy device 80x30
[    0.000349] Calibrating delay loop (skipped), value calculated using timer f)
[    0.000373] pid_max: default: 32768 minimum: 301
[    0.000760] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.000780] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.001969] Initializing cgroup subsys memory
[    0.002019] Initializing cgroup subsys devices
[    0.002045] Initializing cgroup subsys freezer
[    0.002065] Initializing cgroup subsys net_cls
[    0.002098] Initializing cgroup subsys blkio
[    0.002119] Initializing cgroup subsys bfqio
[    0.002140] Initializing cgroup subsys perf_event
[    0.002161] Initializing cgroup subsys net_prio
[    0.002263] CPU: Testing write buffer coherency: ok
[    0.002858] CPU0: update cpu_capacity 1024
[    0.002877] CPU0: thread -1, cpu 0, socket 15, mpidr 80000f00
[    0.002891] [bcm2709_smp_prepare_cpus] enter
[    0.003001] Setting up static identity map for 0x7317c0 - 0x7317f4
[    0.060578] [bcm2709_boot_secondary] cpu:1 started (0) 18
[    0.060877] CPU1: Booted secondary processor
[    0.060885] [bcm2709_secondary_init] enter cpu:1
[    0.060931] CPU1: update cpu_capacity 1024
[    0.060939] CPU1: thread -1, cpu 1, socket 15, mpidr 80000f01
[    0.080539] [bcm2709_boot_secondary] cpu:2 started (0) 17
[    0.080795] CPU2: Booted secondary processor
[    0.080801] [bcm2709_secondary_init] enter cpu:2
[    0.080829] CPU2: update cpu_capacity 1024
[    0.080837] CPU2: thread -1, cpu 2, socket 15, mpidr 80000f02
[    0.100591] [bcm2709_boot_secondary] cpu:3 started (0) 16
[    0.100831] CPU3: Booted secondary processor
[    0.100838] [bcm2709_secondary_init] enter cpu:3
[    0.100867] CPU3: update cpu_capacity 1024
[    0.100875] CPU3: thread -1, cpu 3, socket 15, mpidr 80000f03
[    0.100969] Brought up 4 CPUs
[    0.101002] SMP: Total of 4 processors activated (153.60 BogoMIPS).
[    0.101013] CPU: All CPU(s) started in SVC mode.
[    0.102096] devtmpfs: initialized
[    0.128404] VFP support v0.3: implementor 41 architecture 2 part 30 variant 5
[    0.130984] xor: measuring software checksum speed
[    0.230401]    arm4regs  :   832.000 MB/sec
[    0.330493]    8regs     :   528.000 MB/sec
[    0.430598]    32regs    :   512.800 MB/sec
[    0.530699]    neon      :   755.200 MB/sec
[    0.530713] xor: using function: arm4regs (832.000 MB/sec)
[    0.530752] pinctrl core: initialized pinctrl subsystem
[    0.533786] NET: Registered protocol family 16
[    0.539483] DMA: preallocated 4096 KiB pool for atomic coherent allocations
[    0.540746] bcm2709.uart_clock = 3000000
[    0.543397] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint.
[    0.543414] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.543452] mailbox: Broadcom VideoCore Mailbox driver
[    0.543575] bcm2708_vcio: mailbox at f300b880
[    0.543909] bcm_power: Broadcom power driver
[    0.543925] bcm_power_open() -> 0
[    0.543936] bcm_power_request(0, 8)
[    1.044605] bcm_mailbox_read -> 00000080, 0
[    1.044618] bcm_power_request -> 0
[    1.044739] Serial: AMBA PL011 UART driver
[    1.044872] dev:f1: ttyAMA0 at MMIO 0x3f201000 (irq = 83, base_baud = 0) is 3
[    1.588152] console [ttyAMA0] enabled
[    1.828512] raid6: int32x1     91 MB/s
[    1.998933] raid6: int32x2    116 MB/s
[    2.168998] raid6: int32x4    112 MB/s
[    2.339258] raid6: int32x8    110 MB/s
[    2.509212] raid6: neonx1     294 MB/s
[    2.679426] raid6: neonx2     394 MB/s
[    2.849455] raid6: neonx4     474 MB/s
[    3.019757] raid6: neonx8     406 MB/s
[    3.023501] raid6: using algorithm neonx4 (474 MB/s)
[    3.028472] raid6: using intx1 recovery algorithm
[    3.034096] SCSI subsystem initialized
[    3.038309] usbcore: registered new interface driver usbfs
[    3.043915] usbcore: registered new interface driver hub
[    3.049393] usbcore: registered new device driver usb
[    3.057399] Switched to clocksource arch_sys_counter
[    3.120959] FS-Cache: Loaded
[    3.124155] CacheFiles: Loaded
[    3.140288] NET: Registered protocol family 2
[    3.146004] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[    3.153221] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[    3.159863] TCP: Hash tables configured (established 8192 bind 8192)
[    3.166311] TCP: reno registered
[    3.169577] UDP hash table entries: 512 (order: 2, 16384 bytes)
[    3.175540] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[    3.182265] NET: Registered protocol family 1
[    3.187147] RPC: Registered named UNIX socket transport module.
[    3.193103] RPC: Registered udp transport module.
[    3.197824] RPC: Registered tcp transport module.
[    3.202521] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    3.210032] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 5 countee
[    3.219911] bcm2708_dma: DMA manager at f3007000
[    3.224704] vc-mem: phys_addr:0x00000000 mem_base=0x3dc00000 mem_size:0x3f00)
[    3.234549] futex hash table entries: 1024 (order: 4, 65536 bytes)
[    3.258807] VFS: Disk quotas dquot_6.5.2
[    3.263128] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    3.272975] FS-Cache: Netfs 'nfs' registered for caching
[    3.279603] NFS: Registering the id_resolver key type
[    3.284706] Key type id_resolver registered
[    3.288915] Key type id_legacy registered
[    3.292948] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    3.300568] JFS: nTxBlock = 6884, nTxLock = 55079
[    3.313722] SGI XFS with ACLs, security attributes, realtime, no debug enabld
[    3.327266] aufs 3.18.1+-20150330
[    3.330658] msgmni has been set to 1721
[    3.337137] async_tx: api initialized (async)
[    3.341676] Block layer SCSI generic (bsg) driver version 0.4 loaded (major )
[    3.349327] io scheduler noop registered (default)
[    3.354127] io scheduler deadline registered
[    3.358491] io scheduler cfq registered
[    3.362712] io scheduler bfq registered
[    3.366543] BFQ I/O-scheduler version: v7r7
[    3.373186] BCM2708FB: allocated DMA memory f6c00000
[    3.378385] BCM2708FB: allocated DMA channel 0 @ f3007000
[    3.389474] Console: switching to colour frame buffer device 82x26
[    3.399811] bcm2708-dmaengine bcm2708-dmaengine: Load BCM2835 DMA engine drir
[    3.407451] uart-pl011 dev:f1: no DMA platform data
[    3.412364] kgdb: Registered I/O driver kgdboc.
[    3.437982] vc-cma: Videocore CMA driver
[    3.441902] vc-cma: vc_cma_base      = 0x00000000
[    3.446598] vc-cma: vc_cma_size      = 0x00000000 (0 MiB)
[    3.452015] vc-cma: vc_cma_initial   = 0x00000000 (0 MiB)
[    3.468305] brd: module loaded
[    3.477165] loop: module loaded
[    3.480685] vchiq: vchiq_init_state: slot_zero = 0xb6800000, is_master = 0
[    3.488359] Loading iSCSI transport class v2.0-870.
[    3.495993] usbcore: registered new interface driver ax88179_178a
[    3.502277] usbcore: registered new interface driver smsc95xx
[    3.508199] usbcore: registered new interface driver cdc_ncm
[    3.513864] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[    3.719926] Core Release: 2.80a
[    3.723087] Setting default values for core params
[    3.727932] Finished setting default values for core params
[    3.933876] Using Buffer DMA mode
[    3.937190] Periodic Transfer Interrupt Enhancement - disabled
[    3.943031] Multiprocessor Interrupt Enhancement - disabled
[    3.948614] OTG VER PARAM: 0, OTG VER FLAG: 0
[    3.952968] Dedicated Tx FIFOs mode
[    3.956834] WARN::dwc_otg_hcd_init:1047: FIQ DMA bounce buffers: virt = 0xb64
[    3.966701] FIQ FSM acceleration enabled for :
               Non-periodic Split Transactions
               Periodic Split Transactions
               High-Speed Isochronous Endpoints
[    3.983447] dwc_otg: Microframe scheduler enabled
[    3.983520] WARN::hcd_init_fiq:412: FIQ on core 1 at 0x80587fdc
[    3.989438] WARN::hcd_init_fiq:413: FIQ ASM at 0x80588338 length 36
[    3.995702] WARN::hcd_init_fiq:438: MPHI regs_base at 0xb7c12000
[    4.001712] dwc_otg bcm2708_usb: DWC OTG Controller
[    4.006621] dwc_otg bcm2708_usb: new USB bus registered, assigned bus number1
[    4.013889] dwc_otg bcm2708_usb: irq 32, io mem 0x00000000
[    4.019428] Init: Port Power? op_state=1
[    4.023343] Init: Power Port (0)
[    4.026890] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    4.033700] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber1
[    4.040936] usb usb1: Product: DWC OTG Controller
[    4.045637] usb usb1: Manufacturer: Linux 3.18.10-3-ARCH dwc_otg_hcd
[    4.052003] usb usb1: SerialNumber: bcm2708_usb
[    4.057455] hub 1-0:1.0: USB hub found
[    4.061268] hub 1-0:1.0: 1 port detected
[    4.065657] dwc_otg: FIQ enabled
[    4.065669] dwc_otg: NAK holdoff enabled
[    4.065679] dwc_otg: FIQ split-transaction FSM enabled
[    4.065717] Module dwc_common_port init
[    4.066092] usbcore: registered new interface driver usb-storage
[    4.072222] usbcore: registered new interface driver ums-alauda
[    4.078239] usbcore: registered new interface driver ums-cypress
[    4.084315] usbcore: registered new interface driver ums-datafab
[    4.090415] usbcore: registered new interface driver ums_eneub6250
[    4.096667] usbcore: registered new interface driver ums-freecom
[    4.102766] usbcore: registered new interface driver ums-isd200
[    4.108793] usbcore: registered new interface driver ums-jumpshot
[    4.114956] usbcore: registered new interface driver ums-karma
[    4.120884] usbcore: registered new interface driver ums-onetouch
[    4.127083] usbcore: registered new interface driver ums-realtek
[    4.133205] usbcore: registered new interface driver ums-sddr09
[    4.139221] usbcore: registered new interface driver ums-sddr55
[    4.145230] usbcore: registered new interface driver ums-usbat
[    4.151407] mousedev: PS/2 mouse device common for all mice
[    4.157781] md: linear personality registered for level -1
[    4.163274] md: raid0 personality registered for level 0
[    4.168617] md: raid1 personality registered for level 1
[    4.173932] md: raid10 personality registered for level 10
[    4.179777] md: raid6 personality registered for level 6
[    4.185083] md: raid5 personality registered for level 5
[    4.190413] md: raid4 personality registered for level 4
[    4.195731] md: multipath personality registered for level -4
[    4.201501] md: faulty personality registered for level -5
[    4.207412] device-mapper: uevent: version 1.0.3
[    4.212630] device-mapper: ioctl: 4.28.0-ioctl (2014-09-17) initialised: dm-m
[    4.221966] device-mapper: multipath: version 1.7.0 loaded
[    4.227492] device-mapper: multipath round-robin: version 1.0.0 loaded
[    4.234022] device-mapper: multipath queue-length: version 0.1.0 loaded
[    4.240658] device-mapper: multipath service-time: version 0.2.0 loaded
[    4.247298] device-mapper: raid: Loading target version 1.6.0
[    4.253274] bcm2835-cpufreq: min=600000 max=1000000
[    4.258296] Indeed it is in host mode hprt0 = 00021501
[    4.280774] sdhci: Secure Digital Host Controller Interface driver
[    4.286938] sdhci: Copyright(c) Pierre Ossman
[    4.291443] DMA channels allocated for the MMC driver
[    4.327417] Load BCM2835 MMC driver
[    4.331128] sdhci-pltfm: SDHCI platform and OF driver helper
[    4.337143] ledtrig-cpu: registered to indicate activity on CPUs
[    4.343287] hidraw: raw HID events driver (C) Jiri Kosina
[    4.348977] usbcore: registered new interface driver usbhid
[    4.354536] usbhid: USB HID core driver
[    4.358577] TCP: cubic registered
[    4.361895] Initializing XFRM netlink socket
[    4.366172] NET: Registered protocol family 17
[    4.370734] Key type dns_resolver registered
[    4.375300] Registering SWP/SWPB emulation handler
[    4.380674] registered taskstats version 1
[    4.386776] mmc0: host does not support reading read-only switch, assuming we
[    4.386929] Btrfs loaded
[    4.387107] vc-sm: Videocore shared memory driver
[    4.387115] [vc_sm_connected_init]: start
[    4.395120] [vc_sm_connected_init]: end - returning 0
[    4.411250] md: Waiting for all devices to be available before autodetect
[    4.415111] mmc0: new high speed SDHC card at address aaaa
[    4.415530] mmcblk0: mmc0:aaaa SU08G 7.40 GiB
[    4.416972]  mmcblk0: p1 p2
[    4.430739] md: If you don't use raid, use raid=noautodetect
[    4.437025] md: Autodetecting RAID arrays.
[    4.437487] usb 1-1: new high-speed USB device number 2 using dwc_otg
[    4.437611] Indeed it is in host mode hprt0 = 00001101
[    4.452687] md: Scanned 0 and added 0 devices.
[    4.457115] md: autorun ...
[    4.459914] md: ... autorun DONE.
[    4.469156] EXT4-fs (mmcblk0p2): couldn't mount as ext3 due to feature incoms
[    4.477789] EXT4-fs (mmcblk0p2): couldn't mount as ext2 due to feature incoms
[    4.507228] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. )
[    4.515356] VFS: Mounted root (ext4 filesystem) on device 179:2.
[    4.534471] devtmpfs: mounted
[    4.537819] Freeing unused kernel memory: 364K (809e9000 - 80a44000)
[    4.637907] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
[    4.644696] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    4.652937] hub 1-1:1.0: USB hub found
[    4.656846] hub 1-1:1.0: 5 ports detected
[    4.937578] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[    5.032835] NET: Registered protocol family 10
[    5.039602] systemd[1]: Inserted module 'ipv6'
[    5.057912] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[    5.064874] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumbe0
[    5.074633] random: systemd urandom read with 65 bits of entropy available
[    5.075198] smsc95xx v1.0.4
[    5.096512] systemd[1]: systemd 218 running in system mode. (+PAM -AUDIT -SE)
[    5.115080] systemd[1]: Detected architecture 'arm'.
[    5.131192] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-bcm2708_usb-e
[    5.144349] systemd[1]: Set hostname to <alarmpi>.
[    5.238222] usb 1-1.2: new high-speed USB device number 4 using dwc_otg
[    5.358146] usb 1-1.2: New USB device found, idVendor=0bda, idProduct=8179
[    5.365114] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumbe3
[    5.372572] usb 1-1.2: Product: 802.11n NIC
[    5.376765] usb 1-1.2: Manufacturer: Realtek
[    5.381144] usb 1-1.2: SerialNumber: 00E04C0001
[    5.467622] usb 1-1.4: new full-speed USB device number 5 using dwc_otg
[    5.594197] usb 1-1.4: New USB device found, idVendor=046d, idProduct=c52b
[    5.601176] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumbe0
[    5.608557] usb 1-1.4: Product: USB Receiver
[    5.612876] usb 1-1.4: Manufacturer: Logitech
[    5.761649] systemd[1]: [/etc/systemd/system/getty@tty1.service.d/override.c.
[    5.815460] systemd[1]: Cannot add dependency job for unit display-manager.s.
[    5.841203] systemd[1]: Starting Forward Password Requests to Wall Directory.
[    5.849466] systemd[1]: Started Forward Password Requests to Wall Directory .
[    5.857333] systemd[1]: Starting Arbitrary Executable File Formats File Syst.
[    5.887631] systemd[1]: Set up automount Arbitrary Executable File Formats F.
[    5.897257] systemd[1]: Starting Swap.
[    5.917573] systemd[1]: Reached target Swap.
[    5.921994] systemd[1]: Expecting device dev-ttyAMA0.device...
[    5.947612] systemd[1]: Expecting device dev-mmcblk0p1.device...
[    5.967601] systemd[1]: Starting Root Slice.
[    5.987581] systemd[1]: Created slice Root Slice.
[    5.992457] systemd[1]: Starting LVM2 metadata daemon socket.
[    6.017584] systemd[1]: Listening on LVM2 metadata daemon socket.
[    6.023867] systemd[1]: Starting udev Kernel Socket.
[    6.047577] systemd[1]: Listening on udev Kernel Socket.
[    6.053031] systemd[1]: Starting Delayed Shutdown Socket.
[    6.077579] systemd[1]: Listening on Delayed Shutdown Socket.
[    6.083467] systemd[1]: Starting Device-mapper event daemon FIFOs.
[    6.107566] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[    6.114271] systemd[1]: Starting udev Control Socket.
[    6.137570] systemd[1]: Listening on udev Control Socket.
[    6.143169] systemd[1]: Starting Encrypted Volumes.
[    6.167568] systemd[1]: Reached target Encrypted Volumes.
[    6.173189] systemd[1]: Starting System Slice.
[    6.197585] systemd[1]: Created slice System Slice.
[    6.202722] systemd[1]: Starting system-serial\x2dgetty.slice.
[    6.227596] systemd[1]: Created slice system-serial\x2dgetty.slice.
[    6.234030] systemd[1]: Starting system-network\x2dwireless.slice.
[    6.257624] systemd[1]: Created slice system-network\x2dwireless.slice.
[    6.264429] systemd[1]: Starting Journal Socket (/dev/log).
[    6.287594] systemd[1]: Listening on Journal Socket (/dev/log).
[    6.293665] systemd[1]: Starting /dev/initctl Compatibility Named Pipe.
[    6.317572] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[    6.324759] systemd[1]: Starting Journal Socket.
[    6.347574] systemd[1]: Listening on Journal Socket.
[    6.356566] systemd[1]: Starting Load Kernel Modules...
[    6.382407] systemd[1]: Mounted Huge Pages File System.
[    6.388488] systemd[1]: Mounting Debug File System...
[    6.412070] systemd[1]: Starting udev Coldplug all Devices...
[    6.428853] bcm2708_rng_init=b7cf8000
[    6.445182] systemd[1]: Starting Startup Splash Video...
[    6.498044] systemd[1]: Started Startup Splash Video.
[    6.504264] systemd[1]: Starting Setup Virtual Console...
[    6.544917] systemd[1]: Started Set Up Additional Binary Formats.
[    6.551989] systemd[1]: Starting Remount Root and Kernel File Systems...
[    6.643294] systemd[1]: Listening on Journal Audit Socket.
[    6.649540] systemd[1]: Expecting device sys-subsystem-net-devices-wlan0.dev.
[    6.679142] systemd[1]: Starting Create list of required static device nodes.
[    6.716318] systemd[1]: Mounting POSIX Message Queue File System...
[    6.755896] systemd[1]: Starting Journal Service...
[    6.785545] systemd[1]: Starting system-getty.slice.
[    6.817892] systemd[1]: Created slice system-getty.slice.
[    6.823902] systemd[1]: Starting User and Session Slice.
[    6.847756] systemd[1]: Created slice User and Session Slice.
[    6.853770] systemd[1]: Starting Slices.
[    6.877934] systemd[1]: Reached target Slices.
[    6.882748] systemd[1]: Starting Remote File Systems.
[    6.907838] systemd[1]: Reached target Remote File Systems.
[    6.914183] systemd[1]: Starting Dispatch Password Requests to Console Direc.
[    6.923372] systemd[1]: Started Dispatch Password Requests to Console Direct.
[    6.931823] systemd[1]: Starting Paths.
[    6.957870] systemd[1]: Reached target Paths.
[    6.987689] systemd[1]: Mounted Debug File System.
[    7.017828] systemd[1]: Mounted POSIX Message Queue File System.
[    7.048151] systemd[1]: Started Setup Virtual Console.
[    7.078218] systemd[1]: Started Remount Root and Kernel File Systems.
[    7.107994] systemd[1]: Started Create list of required static device nodes .
[    7.137690] systemd[1]: Started udev Coldplug all Devices.
[    7.167753] systemd[1]: Started Journal Service.
[    8.159912] logitech-djreceiver 0003:046D:C52B.0003: hiddev0,hidraw0: USB HI2
[    8.228340] r8188eu: module is from the staging directory, the quality is un.
[    8.241169] input: Logitech Unifying Device. Wireless PID:2011 as /devices/p0
[    8.257789] Chip Version Info: CHIP_8188E_Normal_Chip_TSMC_D_CUT_1T1R_RomVer)
[    8.266179] logitech-djdevice 0003:046D:C52B.0004: input,hidraw1: USB HID v11
[    8.284508] input: Logitech Unifying Device. Wireless PID:4008 as /devices/p1
[    8.301688] logitech-djdevice 0003:046D:C52B.0005: input,hidraw2: USB HID v12
[    8.329126] usbcore: registered new interface driver r8188eu
[    8.353089] systemd-journald[130]: Received request to flush runtime journal1
[    8.384301] random: nonblocking pool is initialized
[    8.491646] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data.
[    9.667789] MAC Address = 30:b5:c2:05:9b:1b
[    9.674600] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[   11.378872] cfg80211: Calling CRDA to update world regulatory domain
sdjf
Tue Apr 07, 2015 9:49 pm
You have a PS/2 mouse attached somehow? Have not seen that mousedev line on my pi, which uses a USB mouse.
The lines about "faulty personality" look important, looks like there are threads on the web about that for archlinux, but they are above my head.
ccy
Wed Apr 08, 2015 12:10 am
Not a PS/2 mouse but it is a logitech keyboard mouse unifying wireless controller
sdjf
Wed Apr 08, 2015 7:02 am
Did you notice these lines?
Are you using RAID? If so, have you read the archlinux wiki page about that? I wish somebody who knows about RAID devices would comment about the faulty personality messages.
https://wiki.archlinux.org/index.php/RAID
ccy
Wed Apr 08, 2015 9:24 am
I add "raid=noautodetect" to /boot/cmdline.txt, but it doesn't help.
Return to “Arch”
