Hi all,
I run a few gadgets on my RPi B+. I have:
- USB 3G modem
- USB Creative Webcam
- Motor controller board (L298)
- USB GPS (BU 353)
And of course, I have to run this on batteries as well... (remote battleship).
It has work well a few times (probably by accident) but now I cannot get all gadgets to run at once any more. If all is connected, the 3G modem is struggling and needs maybe 7-8 retry attempts/reboots before connecting. If I remove the webcam, the modem connects immediately after a reboot.
In the past, I've used a usb batterypack to run it all (http://forum.xda-developers.com/showthr ... ?t=1921093) but now it cant provide enough amps (i'm guessing). If I connect both ports from the USB-battery to the regular mini-usb connection, it's about 3.1A (according to specs).
So, I added powered usb hub connected to a second battery (lead) via a UBEC 5V, 3A and connected some devices to it, but still no success (still struggling with the 3G connection). I noticed as well that I could disconnect the USB battery without the RPi complaining/halting.
My theory is... Could it be that the USB battery powers down since the RPi gets power from two sources? I'm guessing that the RPi gets it's juice from the USB hub as well? In total I'm using up to 6A, so it cant be that that's the issue.
In this case, I cannot connect anything to the GPIO since thats blocked by the motor controller board connections.
Any suggestions?
