geffers
Root Password - What is it
Sun Jul 08, 2012 1:33 pm
I know of pi and raspberry for the normal login details but some of the programs need a password for administrator privileges;
What is the Admin password?
Geffers
StephenSwat
Re: Root Password - What is it
Sun Jul 08, 2012 1:35 pm
If you are using sudo, you should be able to use the password of the account you are logged in with.
geffers
Sun Jul 08, 2012 2:08 pm
StephenSwat wrote:If you are using sudo, you should be able to use the password of the account you are logged in with.
No, sudo password doesn't work when trying to open program from the applications menu.
It may work if I sudo the same program from the command line but I haven't tried that yet.
Geffers
StephenSwat
Sun Jul 08, 2012 2:31 pm
You could always open a terminal and sudo passwd root to set a new root password.
geffers
Tue Jul 10, 2012 8:21 pm
StephenSwat wrote:You could always open a terminal and sudo passwd root to set a new root password.
Thanks, I'll try that next time I use the Pi.
Geffers
mikerr
Tue Jul 10, 2012 9:00 pm
The answer to the question is the root password is usually "root".
su
Password: root
exit
geffers
Wed Jul 11, 2012 7:56 pm
mikerr wrote:The answer to the question is the root password is usually "root".
su
Password: root
exit
Thanks, I'll try that next time I fire it up.
Geffers
Return to “Beginners”
