pavinjoseph wrote:I was testing my Raspberry Pi 2 Model B with an Apache
web server. The Pi itself is overclocked using the Moderate Preset. It works reliably 24x7. I recently conducted Load Testing on the apache server and it held up pretty good, better than I expected. 10000 clients in 1 minute and only 169 timeouts.
Test Results
How can I improve upon this figure and what would be the steps required to further reduce response time and/or timeouts.
I don't know how the loader.io test works, but it looks from the graph like they ramped up the number of clients very aggressively, causing Apache to spawn a very large number of processes, which made the load climb rapidly on the Pi. As a result the response times went up along with the timeout rate. Look at the "Times" tab: the clients/sec peaked at ~00:06 and the response time a few seconds later at ~00:11. After that the test backed off to ~200 clients/sec and the response time was steady for the remainder of the test. Look at the "Details" tab: timeouts also peaked at ~00:11, but after the initial load there wasn't a single timeout. Without knowing anything more about the test, I would say it looks pretty good.
You should try repeating the test. Apache should be better equipped to deal with the initial load after it has been "warmed up".
