I would like to be able to use this tool: http://www.bertold.org/sdtool/ on some SD cards to render them read-only.
To be clear, the SD cards aren't the same SD card that I use to run my Pi - they are SD cards that I use for other stuff but I'd like to be confident that nothing is able to be written to them once I've got the content on them that I need.
In order to modify the CSD register, the tool requires access to the SD card as a block device (e.g., /dev/mmcblk1) and not as a USB mass storage device (e.g., /dev/sda) thus using a USB SD card reader is not an option.
What I'm thinking might be possible is to use something like this: http://www.raspipress.com/2013/05/insta ... ash-drive/ to get the Pi booted in such a way that it's not dependent on the SD card, and then remove the SD card, introduce my other SD cards (one-at-a-time), and then run the SD tool on each SD card to edit the CSD register as I require.
I'm pretty much a noob with Raspberry Pis (and new to this forum so apologies if this is the wrong subforum to post in) so before I expend too much effort in trying to get this to work, I was keen to get some feedback from those of you who know this kind of stuff about whether or not this might be possible?
Thanks...
