pi@raspi3 ~ $ lsusb
Bus 001 Device 004: ID 148f:5370 Ralink Technology, Corp. RT5370 Wireless Adapter
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter
Bus 001 Device 002: ID 0424:9514 Standard Microsystems Corp.
rpdom@raspi4:~$ lsusb
Bus 001 Device 002: ID 0bda:8178 Realtek Semiconductor Corp. RTL8192CU 802.11n WLAN Adapter
Thanks for your prompt reply. The package it came in lists RASPI-081400 which I'm assuming is the Model https://www.creatroninc.com/search?cont ... it_search=ktb wrote:You might need to compile the driver yourself. I guess it could be a power issue also (it might be resolved by simply adding max_usb_current=1 to /boot/config.txt).
However, we need to know the model of the WiFi adapter or which chipset it uses. How about a link to the product? We need more information if you expect us to assist you.
Just plug it in and boot up the Operating SystemiPyrrebpsaR wrote:Thanks for your prompt reply. The package it came in lists RASPI-081400 which I'm assuming is the Model https://www.creatroninc.com/search?cont ... it_search=ktb wrote:You might need to compile the driver yourself. I guess it could be a power issue also (it might be resolved by simply adding max_usb_current=1 to /boot/config.txt).
I was trying to operate my Raspberry Pi using my laptops mouse, keyboard and monitor but this doesn't seem to be a method a newbie should try. I'm going to try and locate another mouse, keyboard and monitor for my Raspberry Pi. I'll try your suggestion once I locate and install a separate monitor.DougieLawson wrote:What does your Raspberry Pi say if you plug in the WiFi dongle, open a LXTerminal window and type a lsusb # ell, ess, you, ess, bee command?
It depends on Operating System installed, if Raspbian has been installed without NOBS installer / choser then SSH is enabled by defaultiPyrrebpsaR wrote:I was trying to operate my Raspberry Pi using my laptops mouse, keyboard and monitor but this doesn't seem to be a method a newbie should try. I'm going to try and locate another mouse, keyboard and monitor for my Raspberry Pi. I'll try your suggestion once I locate and install a separate monitor.DougieLawson wrote:What does your Raspberry Pi say if you plug in the WiFi dongle, open a LXTerminal window and type a lsusb # ell, ess, you, ess, bee command?
Thanks for the information and the address to the SSH Readme file. Learning can be made a lot easier when someone who knows takes the time to get you looking in the right direction. Thanksfruitoftheloom wrote:It depends on Operating System installed, if Raspbian has been installed without NOBS installer / choser then SSH is enabled by defaultiPyrrebpsaR wrote:I was trying to operate my Raspberry Pi using my laptops mouse, keyboard and monitor but this doesn't seem to be a method a newbie should try. I'm going to try and locate another mouse, keyboard and monitor for my Raspberry Pi. I'll try your suggestion once I locate and install a separate monitor.DougieLawson wrote:What does your Raspberry Pi say if you plug in the WiFi dongle, open a LXTerminal window and type a lsusb # ell, ess, you, ess, bee command?
http://www.raspberrypi.org/documentatio ... /README.md
This will give you access to the Raspbian CLi, it is all about learning......
Regards your comment about installing in Windows 7, totally irrelevent, Linux is different and the instruction you cited are not for the RPi
