Darren01274
Kodi Frrezzing during playback of streams
Tue Mar 24, 2015 8:48 pm
Hi I got Kodi installed on Pi 2 and seems to be freezing during streaming files, cant seem to find any settings that helps? I have a 50MB internet connection.
Galaxynik
Re: Kodi Frrezzing during playback of streams
Wed Mar 25, 2015 3:31 pm
have you tried changing the buffer setting?
advancedsettings.xml
<advancedsettings>
<network>
<buffermode>1</buffermode>
<cachemembuffersize>377286400</cachemembuffersize>
<readbufferfactor>30</readbufferfactor>
</network>
</advancedsettings>
should be found (or created in) home/osmc/.kodi/userdata
DirkS
Wed Mar 25, 2015 5:39 pm
Galaxynik wrote:should be found (or created in) home/osmc/.kodi/userdata
If OP is using Kodi on Raspbian then the path is most likely /home/pi/.kodi/userdata
Galaxynik
Wed Mar 25, 2015 6:00 pm
true I just assumed it was osmc - no idea why :D
Darren01274
Wed Mar 25, 2015 6:48 pm
No how can I adjust that from within Kodi?
Darren
Galaxynik
Wed Mar 25, 2015 7:04 pm
sorry cant help you there - I use ssh initialy to access the filesystem and then share the root filesystem with samba so I can edit those types of files from a windows machine
there is an add-on you can use but I've not tried it
http://forum.kodi.tv/showthread.php?tid=87524
POPEYE
Tue Jul 03, 2018 12:41 pm
I have similar problem.
I have two different streams from the same server. One works normally. The other freezes after 10 - 20 seconds of playing. No matter, I am using IPTV Simple add-on, or playing standalone file with link to the stream.
Both streams play normally from console omxplayer.
I have Kodi 17.4 from RetroPie on Pi 3 and wired internet connection.
Rascas
Tue Jul 03, 2018 3:21 pm
Your Kodi debug log is needed to find your problem.
https://kodi.wiki/view/Log_file
Return to “Media centres”
