Latest versions of Raspbian have user pi in group spi and i2c so it can access those buses without needing sudo.danjperron wrote:can't do it without sudo unless PI has permission to handle /dev/spidev0.0
nRF24L01 Raspberry PI
PIN PIN description
1 1 GND
2 6 3.3V power
3 17 3.3V nRF24L01 CE
4 24 SPI CE0 N
5 23 SPI CLK
6 19 SPI MOSI
7 21 SPI MISO
#include <RF24.h>
#include <RF24_config.h>
#include <SPI.h>
#include <OneWire.h>
#include <DallasTemperature.h>
OneWire oneWire(2);
DallasTemperature sensors(&oneWire);
// ce,csn pins
RF24 radio(9,10);
unsigned char data[3] = {
0};
unsigned long count=0;
void setup(void)
sensors.begin();
Serial.begin(57600);
Serial.println("**************V1 Send Sensor Data***********");
radio.begin();
radio.setPALevel(RF24_PA_LOW);
radio.setChannel(0x4c);
// open pipe for writing
radio.openWritingPipe(0xF0F0F0F0E1LL);
radio.enableDynamicPayloads();
radio.setAutoAck(true);
radio.powerUp();
Serial.println("...Sending");
void loop(void)
sensors.requestTemperatures();
float currentTemp;
currentTemp = sensors.getTempCByIndex(0);
//assign 'T' to represent a Temperature reading
data[0] = 'T';
data[1] = currentTemp;
count++;
// print and increment the counter
radio.write(data, sizeof(float)+1);
Serial.print("Temperature sent: ");
Serial.println(currentTemp);
// pause a second
delay(500);
* Filename : rpi-hub.cpp
* This program makes the RPi as a hub listening to all six pipes from the remote sensor nodes ( usually Arduino )
* and will return the packet back to the sensor on pipe0 so that the sender can calculate the round trip delays
* when the payload matches.
* I encounter that at times, it also receive from pipe7 ( or pipe0 ) with content of FFFFFFFFF that I will not sent
* back to the sender
* Refer to RF24/examples/rpi_hub_arduino/ for the corresponding Arduino sketches to work with this code.
* CE is not used and CSN is GPIO25 (not pinout)
* Refer to RPi docs for GPIO numbers
* Author : Stanley Seow
* e-mail : stanleyseow@gmail.com
* date : 6th Mar 2013
* 03/17/2013 : Charles-Henri Hallard (http://hallard.me)
* Modified to use with Arduipi board http://hallard.me/arduipi
* Changed to use modified bcm2835 and RF24 library
#include <cstdlib>
#include <iostream>
#include <RF24/RF24.h>
using namespace std;
// Radio pipe addresses for the 2 nodes to communicate.
// First pipe is for writing, 2nd, 3rd, 4th, 5th & 6th is for reading...
const uint64_t pipes[6] =
{ 0xF0F0F0F0D2LL, 0xF0F0F0F0E1LL,
0xF0F0F0F0E2LL, 0xF0F0F0F0E3LL,
0xF0F0F0F0F1, 0xF0F0F0F0F2
// CE Pin, CSN Pin, SPI Speed
// Setup for GPIO 22 CE and GPIO 25 CSN with SPI Speed @ 1Mhz
//RF24 radio(RPI_V2_GPIO_P1_22, RPI_V2_GPIO_P1_18, BCM2835_SPI_SPEED_1MHZ);
// Setup for GPIO 22 CE and CE0 CSN with SPI Speed @ 4Mhz
//RF24 radio(RPI_V2_GPIO_P1_15, BCM2835_SPI_CS0, BCM2835_SPI_SPEED_4MHZ);
// Setup for GPIO 22 CE and CE1 CSN with SPI Speed @ 8Mhz
RF24 radio(RPI_V2_GPIO_P1_15, RPI_V2_GPIO_P1_24, BCM2835_SPI_SPEED_8MHZ);
void setup(void)
// init radio for reading
radio.begin();
radio.setAutoAck(1);
radio.setRetries(15,15);
radio.setDataRate(RF24_1MBPS);
radio.setPALevel(RF24_PA_MAX);
radio.setChannel(76);
radio.setCRCLength(RF24_CRC_16);
radio.openReadingPipe(1,0xF0F0F0F0E1LL);
radio.startListening();
void loop(void)
// 32 byte character array is max payload
char receivePayload[32];
time_t t = time(0); // get time now
struct tm * now = localtime( & t ); // Get curret Time.
while (radio.available())
// read from radio until payload size is reached
uint8_t len = radio.getDynamicPayloadSize();
radio.read(receivePayload, len);
// display payload
cout << (now->tm_year + 1900) << '-'
<< (now->tm_mon + 1) << '-'
<< now->tm_mday << ' '
<< now->tm_hour << ':'
<< now->tm_min << ' '
<< receivePayload << endl;
int main(int argc, char** argv)
setup();
while(1)
loop();
return 0;
solved my errorCode: Select all
sudo bash apt-get install python-dev apt-get install python3-dev apt-get install python-pip apt-get install python3-pip pip install spidev pip-3.2 install spidev exit
File "nRF24Reader.py", line 172, in <module>
radio.begin(0,17)
File "/root/lib_nrf24.py", line 373, in begin
self.spidev.open(0, csn_pin)
IOError: [Errno 2] No such file or directory
