pi@raspberrypi ~ $ uname -a
Linux raspberrypi 3.18.9-v7+ #768 SMP PREEMPT Sun Mar 15 19:41:56 GMT 2015 armv7l GNU/Linux
pi@raspberrypi ~ $ lsusb
Bus 001 Device 002: ID 0424:9514 Standard Microsystems Corp.
Bus 001 Device 004: ID 2001:3319 D-Link Corp.Code: Select all
pi@raspberrypi ~ $ iwconfig
lo no wireless extensions.
eth0 no wireless extensions.Code: Select all
pi@raspberrypi ~ $ lsmod
Module Size Used by
snd_bcm2835 18850 0
snd_pcm 75388 1 snd_bcm2835
snd_seq 53078 0
snd_seq_device 5628 1 snd_seq
snd_timer 17784 2 snd_pcm,snd_seq
snd 51667 5 snd_bcm2835,snd_timer,snd_pcm,snd_seq,snd_seq_device
uio_pdrv_genirq 2958 0
uio 8119 1 uio_pdrv_genirqCode: Select all
pi@raspberrypi ~ $ dmesg | grep usb
[ 1.279701] usbcore: registered new interface driver usbfs
[ 1.285375] usbcore: registered new interface driver hub
[ 1.290843] usbcore: registered new device driver usb
[ 1.655486] usbcore: registered new interface driver smsc95xx
[ 2.178592] dwc_otg bcm2708_usb: DWC OTG Controller
[ 2.185082] dwc_otg bcm2708_usb: new USB bus registered, assigned bus number 1
[ 2.193967] dwc_otg bcm2708_usb: irq 32, io mem 0x00000000
[ 2.211591] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.219995] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.228811] usb usb1: Product: DWC OTG Controller
[ 2.235055] usb usb1: Manufacturer: Linux 3.18.9-v7+ dwc_otg_hcd
[ 2.242678] usb usb1: SerialNumber: bcm2708_usb
[ 2.261339] usbcore: registered new interface driver usb-storage
[ 2.371212] usbcore: registered new interface driver usbhid
[ 2.379469] usbhid: USB HID core driver
[ 2.648249] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ 2.858226] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
[ 2.867025] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 3.167990] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[ 3.288312] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[ 3.297127] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 3.372718] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-bcm2708_usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:ed:4f:e1
[ 3.468081] usb 1-1.2: new high-speed USB device number 4 using dwc_otg
[ 3.579085] usb 1-1.2: New USB device found, idVendor=2001, idProduct=3319
[ 3.588281] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 3.597922] usb 1-1.2: Product: Wireless N Nano USB Adapter
[ 3.606003] usb 1-1.2: Manufacturer: Realtek
[ 3.612488] usb 1-1.2: SerialNumber: 00e04c000001
auto lo
iface lo inet loopback
iface eth0 inet static
address 192.168.1.91
netmask 255.255.255.0
network 192.168.1.1
broadcast 192.168.1.255
gateway 192.168.1.1
auto wlan0
allow-hotplug wlan0
iface wlan0 inet static
wpa-ssid "ssid"
wpa-psk "mypassword"
network 192.168.1.1
gateway 192.168.1.1
iface default inet dhcp
