Emexrulsier wrote:My advice not just to you but everyone is to stop buying this prebuilt SD noobs set up. You learn nothing and when you run into error you are completely stuck. It is not hard at all to downloading pi images and write them to sd cards and then install extra apps etc and whilst doing this you will learn so much more
Poppycock and balderdash.
For the new users who've never used anything but Windows then NOOBS or NOOBS Lite is the best option, if you can follow simple instructions to unzip a zipfile and copy to an factory fresh FAT formatted SDCard then NOOBS is simple and straighforward.
The problems with NOOBS are: 1. it's not easy to update the firmware that's actually used to boot the RPi, 2. it makes a 8GB card into one that appears as 56MB card (to Windows) after a NOOBS install is complete, 3. Nearly 1GB of space can "vanish" and 4. it's impossible to add another OS to the boot manager once a NOOBS install is complete.
Other than that it's better than trying to get new users running that awful Win32DiskImager thing.
The only other way NOOBS could have been done would be as a purpose made Windows executable program that did everything on the Windows system to get from a blank card to a bootable card. (Download a small *.MSI installer, run NOOBS which then downloads the current image and writes it to the card.) But then you'd fail on the systems that are locked down and not allowed to install special purpose application programs. The current NOOBS system uses stuff that's already built in to Windows (no additional software needed).
