englischdude
Newbie with Rpi2 WIFI issue
Sat Mar 21, 2015 8:06 am
Hi there Rpi Community!
I have recently purchased a Rpi2 to replace the ageing pc components in my arcade cabinet. I have installed the piplay beta 8 image and all is going well.
I have a noname dongle which is not being recognised by the pi at all, however when I use it on my linux mint laptop the lsusb command gives me an ID of IBDA:0179
with this information, could someone please support me to get this dongle working on the pi2.
Thanks in advance for your help.
Regards
Martin
Re: Newbie with Rpi2 WIFI issue
Sat Mar 21, 2015 10:25 am
englischdude wrote:Hi there Rpi Community!
Regards
Martin
Should that not be OBDA:0179 ?? Then see:
http://www.raspberrypi.org/forums/viewt ... 82#p462982
RPi 4B 4GB (SSD Boot)..
englischdude
Sat Mar 21, 2015 12:54 pm
many thanks.
have installed the driver, now when I type lsusb into the command line it recognises a "realtek semiconductor corp" device. i cant however seem to start wifi. when I type ifconfig wlan0 is NOT listed!
Any suggestions?
englischdude
SOLVED - Newbie with Rpi2 WIFI issue
Sat Mar 21, 2015 5:30 pm
SOLVED. went through the procedure once more of installing the driver, now with alot of fiddling with the interface and .conf file I have it running.
thanks for your help!
