I therefore considered more correct to open this topic.
Previous attempts to solve the problem can be found in the above reported discussion.
Here I add that the used screen is a LED TV Samsung, model UE32B7000, and that I checked all the possibilities for graphic resolution that the system gave as theoretically available (command output tvservice -m CEA and tvservice -m DMT).
Here is the table with the result of each command tvservice used.
It would seem that none of the possible combinations resulted suitable for the screen of my TV LED which only works with the resolution that Raspbian identified automatically, corresponding to the instructions:
# NOOBS Settings Auto-generated:
hdmi_ignore_edid = 0xa5000080
hdmi_force_hotplug = 1
config_hdmi_boost = 4
hdmi_group = 2
hdmi_mode = 4Claudio
