Any help would be appreciated
Brian
Without an internet connection you will get nowhere, seemeddyliol wrote:I am trying to update my pi and put the command 'sudo apt-get update' in. I keep getting some err lines. Then it gives a message 'Reading Package lists' followed by 'Failed to fetch' lines. I am trying to get the pi working on Wi-Fi, after putting the Wi-Fi adapter in and opening up the Wifi Configuration app it seems to 'see' my Adapter and the Network. I am not sure what the wpa_gui is supposed to show. Under 'Current Status Tab' 'Status:' shows '4-way Handshake (station)' then that goes off and 'scanning appears for a few seconds the back to '4-way Handshake (station)'. So I am not sure what is going on.
Brian
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Initializing cgroup subsys cpu
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 3.18.7+ (dc4@dc4-XPS13-9333) (gcc version 4.8.3 20140303 (prerelease) (crosstool-NG linaro-1.13.1+bzr2650 - Linaro GCC 2014.03) ) #755 PREEMPT Thu Feb 12 17:14:31 GMT 2015
[ 0.000000] CPU: ARMv6-compatible processor [410fb767] revision 7 (ARMv7), cr=00c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
[ 0.000000] Machine model: Raspberry Pi Model B
[ 0.000000] cma: Reserved 8 MiB at 0x1b800000
[ 0.000000] Memory policy: Data cache writeback
[ 0.000000] On node 0 totalpages: 114688
[ 0.000000] free_area_init_node: node 0, pgdat c084d804, node_mem_map db474000
[ 0.000000] Normal zone: 896 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 114688 pages, LIFO batch:31
[ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 113792
[ 0.000000] Kernel command line: dma.dmachans=0x7f35 bcm2708_fb.fbwidth=1776 bcm2708_fb.fbheight=952 bcm2708.boardrev=0xe bcm2708.serial=0xe73c5fd2 smsc95xx.macaddr=B8:27:EB:3C:5F:D2 bcm2708_fb.fbswap=1 sdhci-bcm2708.emmc_clock_freq=250000000 vc_mem.mem_base=0x1ec00000 vc_mem.mem_size=0x20000000 dwc_otg.lpm_enable=0 console=ttyAMA0,115200 console=tty1 root=/dev/mmcblk0p6 rootfstype=ext4 elevator=deadline rootwait
[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Memory: 437208K/458752K available (5926K kernel code, 358K rwdata, 1876K rodata, 340K init, 734K bss, 21544K reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xffc00000 - 0xffe00000 (2048 kB)
[ 0.000000] vmalloc : 0xdc800000 - 0xff000000 ( 552 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xdc000000 ( 448 MB)
[ 0.000000] modules : 0xbf000000 - 0xc0000000 ( 16 MB)
[ 0.000000] .text : 0xc0008000 - 0xc07a6ad8 (7803 kB)
[ 0.000000] .init : 0xc07a7000 - 0xc07fc000 ( 340 kB)
[ 0.000000] .data : 0xc07fc000 - 0xc085588c ( 359 kB)
[ 0.000000] .bss : 0xc085588c - 0xc090d128 ( 735 kB)
[ 0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] NR_IRQS:522
[ 0.000023] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 2147483648000ns
[ 0.000074] Switching to timer-based delay loop, resolution 1000ns
[ 0.000352] Console: colour dummy device 80x30
[ 0.001412] console [tty1] enabled
[ 0.001458] Calibrating delay loop (skipped), value calculated using timer frequency.. 2.00 BogoMIPS (lpj=10000)
[ 0.001532] pid_max: default: 32768 minimum: 301
[ 0.001912] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.001979] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.002988] Initializing cgroup subsys memory
[ 0.003082] Initializing cgroup subsys devices
[ 0.003141] Initializing cgroup subsys freezer
[ 0.003195] Initializing cgroup subsys net_cls
[ 0.003246] Initializing cgroup subsys blkio
[ 0.003373] CPU: Testing write buffer coherency: ok
[ 0.003486] ftrace: allocating 19479 entries in 58 pages
[ 0.111695] Setting up static identity map for 0x55d058 - 0x55d0b4
[ 0.114510] devtmpfs: initialized
[ 0.131972] VFP support v0.3: implementor 41 architecture 1 part 20 variant b rev 5
[ 0.135154] pinctrl core: initialized pinctrl subsystem
[ 0.137822] NET: Registered protocol family 16
[ 0.143287] DMA: preallocated 4096 KiB pool for atomic coherent allocations
[ 0.171471] cpuidle: using governor ladder
[ 0.201535] cpuidle: using governor menu
[ 0.202044] bcm2708.uart_clock = 3000000
[ 0.205146] No ATAGs?
[ 0.205211] hw-breakpoint: found 6 breakpoint and 1 watchpoint registers.
[ 0.205273] hw-breakpoint: maximum watchpoint size is 4 bytes.
[ 0.205341] mailbox: Broadcom VideoCore Mailbox driver
[ 0.205504] bcm2708_vcio: mailbox at f200b880
[ 0.205983] bcm_power: Broadcom power driver
[ 0.206041] bcm_power_open() -> 0
[ 0.206073] bcm_power_request(0, 8)
[ 0.706817] bcm_mailbox_read -> 00000080, 0
[ 0.706866] bcm_power_request -> 0
[ 0.707065] Serial: AMBA PL011 UART driver
[ 0.707304] dev:f1: ttyAMA0 at MMIO 0x20201000 (irq = 83, base_baud = 0) is a PL011 rev3
[ 1.096818] console [ttyAMA0] enabled
[ 1.169876] SCSI subsystem initialized
[ 1.174008] usbcore: registered new interface driver usbfs
[ 1.179801] usbcore: registered new interface driver hub
[ 1.185320] usbcore: registered new device driver usb
[ 1.192507] Switched to clocksource stc
[ 1.226925] FS-Cache: Loaded
[ 1.230246] CacheFiles: Loaded
[ 1.250452] NET: Registered protocol family 2
[ 1.256406] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
[ 1.263822] TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
[ 1.270383] TCP: Hash tables configured (established 4096 bind 4096)
[ 1.276891] TCP: reno registered
[ 1.280159] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 1.286085] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 1.292822] NET: Registered protocol family 1
[ 1.297827] RPC: Registered named UNIX socket transport module.
[ 1.303914] RPC: Registered udp transport module.
[ 1.308645] RPC: Registered tcp transport module.
[ 1.313409] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.321075] bcm2708_dma: DMA manager at f2007000
[ 1.326103] vc-mem: phys_addr:0x00000000 mem_base=0x1ec00000 mem_size:0x20000000(512 MiB)
[ 1.335975] futex hash table entries: 256 (order: -1, 3072 bytes)
[ 1.342245] audit: initializing netlink subsys (disabled)
[ 1.347970] audit: type=2000 audit(1.100:1): initialized
[ 1.368863] VFS: Disk quotas dquot_6.5.2
[ 1.373368] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 1.382844] FS-Cache: Netfs 'nfs' registered for caching
[ 1.389956] NFS: Registering the id_resolver key type
[ 1.395278] Key type id_resolver registered
[ 1.399492] Key type id_legacy registered
[ 1.405040] msgmni has been set to 869
[ 1.411334] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[ 1.419348] io scheduler noop registered
[ 1.423495] io scheduler deadline registered (default)
[ 1.429054] io scheduler cfq registered
[ 1.435623] BCM2708FB: allocated DMA memory 5bc00000
[ 1.440688] BCM2708FB: allocated DMA channel 0 @ f2007000
[ 1.469521] Console: switching to colour frame buffer device 222x59
[ 1.493785] bcm2708-dmaengine bcm2708-dmaengine: Load BCM2835 DMA engine driver
[ 1.501722] uart-pl011 dev:f1: no DMA platform data
[ 1.507674] vc-cma: Videocore CMA driver
[ 1.511730] vc-cma: vc_cma_base = 0x00000000
[ 1.516692] vc-cma: vc_cma_size = 0x00000000 (0 MiB)
[ 1.522221] vc-cma: vc_cma_initial = 0x00000000 (0 MiB)
[ 1.542013] brd: module loaded
[ 1.552852] loop: module loaded
[ 1.556648] vchiq: vchiq_init_state: slot_zero = 0xdb800000, is_master = 0
[ 1.564886] Loading iSCSI transport class v2.0-870.
[ 1.571482] usbcore: registered new interface driver smsc95xx
[ 1.577807] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 1.784054] Core Release: 2.80a
[ 1.787313] Setting default values for core params
[ 1.792247] Finished setting default values for core params
[ 1.998277] Using Buffer DMA mode
[ 2.001707] Periodic Transfer Interrupt Enhancement - disabled
[ 2.007706] Multiprocessor Interrupt Enhancement - disabled
[ 2.013455] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 2.017930] Dedicated Tx FIFOs mode
[ 2.021977] WARN::dwc_otg_hcd_init:1047: FIQ DMA bounce buffers: virt = 0xdbc14000 dma = 0x5bc14000 len=9024
[ 2.032095] FIQ FSM acceleration enabled for :
[ 2.032095] Non-periodic Split Transactions
[ 2.032095] Periodic Split Transactions
[ 2.032095] High-Speed Isochronous Endpoints
[ 2.059052] dwc_otg: Microframe scheduler enabled
[ 2.059180] WARN::hcd_init_fiq:412: FIQ on core 0 at 0xc040116c
[ 2.070003] WARN::hcd_init_fiq:413: FIQ ASM at 0xc0401444 length 36
[ 2.081244] WARN::hcd_init_fiq:438: MPHI regs_base at 0xdc806000
[ 2.092120] dwc_otg bcm2708_usb: DWC OTG Controller
[ 2.102083] dwc_otg bcm2708_usb: new USB bus registered, assigned bus number 1
[ 2.114347] dwc_otg bcm2708_usb: irq 32, io mem 0x00000000
[ 2.124977] Init: Port Power? op_state=1
[ 2.133995] Init: Power Port (0)
[ 2.142708] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.154550] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.166816] usb usb1: Product: DWC OTG Controller
[ 2.176525] usb usb1: Manufacturer: Linux 3.18.7+ dwc_otg_hcd
[ 2.187248] usb usb1: SerialNumber: bcm2708_usb
[ 2.197990] hub 1-0:1.0: USB hub found
[ 2.206933] hub 1-0:1.0: 1 port detected
[ 2.216636] dwc_otg: FIQ enabled
[ 2.216665] dwc_otg: NAK holdoff enabled
[ 2.216678] dwc_otg: FIQ split-transaction FSM enabled
[ 2.216744] Module dwc_common_port init
[ 2.217351] usbcore: registered new interface driver usb-storage
[ 2.228997] mousedev: PS/2 mouse device common for all mice
[ 2.240668] bcm2835-cpufreq: min=700000 max=700000
[ 2.250897] sdhci: Secure Digital Host Controller Interface driver
[ 2.262307] sdhci: Copyright(c) Pierre Ossman
[ 2.271902] DMA channels allocated for the MMC driver
[ 2.312800] Load BCM2835 MMC driver
[ 2.326578] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.344619] ledtrig-cpu: registered to indicate activity on CPUs
[ 2.358201] hidraw: raw HID events driver (C) Jiri Kosina
[ 2.373323] usbcore: registered new interface driver usbhid
[ 2.386144] usbhid: USB HID core driver
[ 2.396797] TCP: cubic registered
[ 2.407342] Initializing XFRM netlink socket
[ 2.416865] Indeed it is in host mode hprt0 = 00021501
[ 2.427119] NET: Registered protocol family 17
[ 2.442784] Key type dns_resolver registered
[ 2.460494] mmc0: host does not support reading read-only switch, assuming write-enable
[ 2.474726] registered taskstats version 1
[ 2.502990] vc-sm: Videocore shared memory driver
[ 2.513226] mmc0: new high speed SDHC card at address 1234
[ 2.532610] [vc_sm_connected_init]: start
[ 2.552642] mmcblk0: mmc0:1234 SA08G 7.28 GiB
[ 2.572667] [vc_sm_connected_init]: end - returning 0
[ 2.586197] mmcblk0: p1 p2 < p5 p6 > p3
[ 2.617828] EXT4-fs (mmcblk0p6): mounted filesystem with ordered data mode. Opts: (null)
[ 2.631550] VFS: Mounted root (ext4 filesystem) readonly on device 179:6.
[ 2.655523] devtmpfs: mounted
[ 2.664946] Freeing unused kernel memory: 340K (c07a7000 - c07fc000)
[ 2.702703] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ 2.715536] Indeed it is in host mode hprt0 = 00001101
[ 2.933153] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
[ 2.947256] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.963034] hub 1-1:1.0: USB hub found
[ 2.973570] hub 1-1:1.0: 5 ports detected
[ 3.262869] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[ 3.393224] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[ 3.393244] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 3.396518] smsc95xx v1.0.4
[ 3.470986] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-bcm2708_usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:3c:5f:d2
[ 3.582823] usb 1-1.3: new high-speed USB device number 4 using dwc_otg
[ 3.714668] usb 1-1.3: New USB device found, idVendor=05e3, idProduct=0608
[ 3.741782] usb 1-1.3: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 3.772758] usb 1-1.3: Product: USB2.0 Hub
[ 3.787062] hub 1-1.3:1.0: USB hub found
[ 3.807134] hub 1-1.3:1.0: 4 ports detected
[ 4.103165] usb 1-1.3.1: new high-speed USB device number 5 using dwc_otg
[ 4.234772] usb 1-1.3.1: New USB device found, idVendor=05e3, idProduct=0608
[ 4.262098] usb 1-1.3.1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 4.286018] usb 1-1.3.1: Product: USB2.0 Hub
[ 4.310138] hub 1-1.3.1:1.0: USB hub found
[ 4.333197] hub 1-1.3.1:1.0: 4 ports detected
[ 4.433146] usb 1-1.3.2: new low-speed USB device number 6 using dwc_otg
[ 4.551819] usb 1-1.3.2: New USB device found, idVendor=046d, idProduct=c046
[ 4.572268] usb 1-1.3.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 4.589187] usb 1-1.3.2: Product: USB Optical Mouse
[ 4.612913] usb 1-1.3.2: Manufacturer: Logitech
[ 4.656866] input: Logitech USB Optical Mouse as /devices/platform/bcm2708_usb/usb1/1-1/1-1.3/1-1.3.2/1-1.3.2:1.0/0003:046D:C046.0001/input/input0
[ 4.699134] hid-generic 0003:046D:C046.0001: input,hidraw0: USB HID v1.10 Mouse [Logitech USB Optical Mouse] on usb-bcm2708_usb-1.3.2/input0
[ 4.718084] usb 1-1.3.1.4: new high-speed USB device number 7 using dwc_otg
[ 4.813913] udevd[160]: starting version 175
[ 4.862722] usb 1-1.3.1.4: New USB device found, idVendor=148f, idProduct=5370
[ 4.892873] usb 1-1.3.1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 4.933058] usb 1-1.3.3: new low-speed USB device number 8 using dwc_otg
[ 4.949154] usb 1-1.3.1.4: Product: 802.11 n WLAN
[ 4.985315] usb 1-1.3.1.4: Manufacturer: Ralink
[ 5.022893] usb 1-1.3.1.4: SerialNumber: 1.0
[ 5.211908] usb 1-1.3.3: New USB device found, idVendor=04d9, idProduct=1603
[ 5.252867] usb 1-1.3.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 5.288348] usb 1-1.3.3: Product: USB Keyboard
[ 5.324446] usb 1-1.3.3: Manufacturer:
[ 5.422895] input: USB Keyboard as /devices/platform/bcm2708_usb/usb1/1-1/1-1.3/1-1.3.3/1-1.3.3:1.0/0003:04D9:1603.0002/input/input1
[ 5.473397] hid-generic 0003:04D9:1603.0002: input,hidraw1: USB HID v1.10 Keyboard [ USB Keyboard] on usb-bcm2708_usb-1.3.3/input0
[ 5.620484] input: USB Keyboard as /devices/platform/bcm2708_usb/usb1/1-1/1-1.3/1-1.3.3/1-1.3.3:1.1/0003:04D9:1603.0003/input/input2
[ 5.672273] hid-generic 0003:04D9:1603.0003: input,hidraw2: USB HID v1.10 Device [ USB Keyboard] on usb-bcm2708_usb-1.3.3/input1
[ 5.733476] cfg80211: Calling CRDA to update world regulatory domain
[ 6.090357] usb 1-1.3.1.4: reset high-speed USB device number 7 using dwc_otg
[ 6.406052] ieee80211 phy0: rt2x00_set_rt: Info - RT chipset 5390, rev 0502 detected
[ 6.993198] ieee80211 phy0: rt2x00_set_rf: Info - RF chipset 5370 detected
[ 7.117748] random: nonblocking pool is initialized
[ 7.206317] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
[ 7.208773] usbcore: registered new interface driver rt2800usb
[ 13.162934] EXT4-fs (mmcblk0p6): re-mounted. Opts: (null)
[ 13.670914] EXT4-fs (mmcblk0p6): re-mounted. Opts: (null)
[ 29.658945] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[ 29.887533] ieee80211 phy0: rt2x00lib_request_firmware: Info - Loading firmware file 'rt2870.bin'
[ 29.894645] ieee80211 phy0: rt2x00lib_request_firmware: Info - Firmware detected - version: 0.29
[ 38.579463] Adding 102396k swap on /var/swap. Priority:-1 extents:1 across:102396k SSFS
[ 52.866029] EXT4-fs (mmcblk0p3): mounted filesystem with ordered data mode. Opts: (null)
[ 1365.965152] wlan0: authenticate with e4:f4:c6:fb:f9:20
[ 1366.036657] wlan0: send auth to e4:f4:c6:fb:f9:20 (try 1/3)
[ 1366.039442] wlan0: authenticated
[ 1366.052790] wlan0: associate with e4:f4:c6:fb:f9:20 (try 1/3)
[ 1366.057015] wlan0: RX AssocResp from e4:f4:c6:fb:f9:20 (capab=0x431 status=0 aid=8)
[ 1366.071854] wlan0: associated
[ 1380.212245] wlan0: deauthenticating from e4:f4:c6:fb:f9:20 by local choice (Reason: 2=PREV_AUTH_NOT_VALID)
[ 1380.314389] cfg80211: Calling CRDA to update world regulatory domain
[ 1380.323993] wlan0: authenticate with e4:f4:c6:fb:f9:20
[ 1380.370687] wlan0: send auth to e4:f4:c6:fb:f9:20 (try 1/3)
[ 1380.373416] wlan0: authenticated
[ 1380.402749] wlan0: associate with e4:f4:c6:fb:f9:20 (try 1/3)
[ 1380.411235] wlan0: RX AssocResp from e4:f4:c6:fb:f9:20 (capab=0x431 status=0 aid=8)
[ 1380.424629] wlan0: associated
[ 1381.965859] wlan0: deauthenticating from e4:f4:c6:fb:f9:20 by local choice (Reason: 3=DEAUTH_LEAVING)
[ 1382.079910] cfg80211: Calling CRDA to update world regulatory domain
[ 1384.272244] wlan0: authenticate with e4:f4:c6:fb:f9:20
[ 1384.330942] wlan0: send auth to e4:f4:c6:fb:f9:20 (try 1/3)
[ 1384.334400] wlan0: authenticated
[ 1384.343739] wlan0: associate with e4:f4:c6:fb:f9:20 (try 1/3)
[ 1384.350493] wlan0: RX AssocResp from e4:f4:c6:fb:f9:20 (capab=0x431 status=0 aid=8)
[ 1384.365073] wlan0: associated
[ 1419.392759] wlan0: deauthenticating from e4:f4:c6:fb:f9:20 by local choice (Reason: 3=DEAUTH_LEAVING)
[ 1419.501300] cfg80211: Calling CRDA to update world regulatory domain
[ 1421.724339] wlan0: authenticate with e4:f4:c6:fb:f9:20
[ 1421.781194] wlan0: send auth to e4:f4:c6:fb:f9:20 (try 1/3)
[ 1421.784179] wlan0: authenticated
[ 1421.794478] wlan0: associate with e4:f4:c6:fb:f9:20 (try 1/3)
[ 1421.805105] wlan0: RX AssocResp from e4:f4:c6:fb:f9:20 (capab=0x431 status=0 aid=8)
[ 1421.818645] wlan0: associated
[ 1475.638864] wlan0: deauthenticating from e4:f4:c6:fb:f9:20 by local choice (Reason: 3=DEAUTH_LEAVING)
[ 1475.761164] cfg80211: Calling CRDA to update world regulatory domain
[ 1477.933019] wlan0: authenticate with e4:f4:c6:fb:f9:20
[ 1477.991058] wlan0: send auth to e4:f4:c6:fb:f9:20 (try 1/3)
[ 1477.994471] wlan0: authenticated
[ 1478.003846] wlan0: associate with e4:f4:c6:fb:f9:20 (try 1/3)
[ 1478.008100] wlan0: RX AssocResp from e4:f4:c6:fb:f9:20 (capab=0x431 status=0 aid=8)
[ 1478.021316] wlan0: associated
[ 1511.181794] wlan0: deauthenticating from e4:f4:c6:fb:f9:20 by local choice (Reason: 3=DEAUTH_LEAVING)
[ 1511.278856] cfg80211: Calling CRDA to update world regulatory domain
[ 1513.302502] wlan0: authenticate with e4:f4:c6:fb:f9:20
[ 1513.381278] wlan0: send auth to e4:f4:c6:fb:f9:20 (try 1/3)
[ 1513.384490] wlan0: authenticated
[ 1513.393703] wlan0: associate with e4:f4:c6:fb:f9:20 (try 1/3)
[ 1513.398123] wlan0: RX AssocResp from e4:f4:c6:fb:f9:20 (capab=0x431 status=0 aid=8)
[ 1513.411849] wlan0: associated
[ 1533.552743] wlan0: deauthenticating from e4:f4:c6:fb:f9:20 by local choice (Reason: 3=DEAUTH_LEAVING)
[ 1533.659117] cfg80211: Calling CRDA to update world regulatory domain
[ 1535.566972] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0x4DE1
[ 1535.751283] wlan0: authenticate with e4:f4:c6:fb:f9:20
[ 1535.830907] wlan0: send auth to e4:f4:c6:fb:f9:20 (try 1/3)
[ 1535.837366] wlan0: authenticated
[ 1535.842840] wlan0: associate with e4:f4:c6:fb:f9:20 (try 1/3)
[ 1535.847149] wlan0: RX AssocResp from e4:f4:c6:fb:f9:20 (capab=0x431 status=0 aid=8)
[ 1535.860265] wlan0: associated
[ 1541.843407] wlan0: deauthenticating from e4:f4:c6:fb:f9:20 by local choice (Reason: 3=DEAUTH_LEAVING)
[ 1541.915069] cfg80211: Calling CRDA to update world regulatory domain
sudo nano /etc/wpa_supplicant/wpa_supplicant.conf in an LXTermina window.meddyliol wrote:How exactly do I get to /etc/wpa_supplicant/wpa_supplicant.conf?
There is no USB WiFi adaptor shown in above listmeddyliol wrote:[codelsusb
Bus 001 Device 002: ID 0424:9514 Standard Microsystems Corp.
Bus 001 Device 004: ID 05e3:0608 Genesys Logic, Inc. USB-2.0 4-Port HUB
Bus 001 Device 005: ID 05e3:0608 Genesys Logic, Inc. USB-2.0 4-Port HUB
Bus 001 Device 006: ID 046d:c046 Logitech, Inc. RX1000 Laser Mouse
Bus 001 Device 008: ID 04d9:1603 Holtek Semiconductor, Inc. Keyboard
lsusb
Bus 001 Device 010: ID 148f:5370 Ralink Technology, Corp. RT5370 Wireless Adapter
ifconfig -a
eth0 Link encap:Ethernet HWaddr b8:27:eb:3c:5f:d2
inet addr:192.168.1.15 Bcast:192.168.1.255 Mask:255.255.255.0
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:65886 errors:0 dropped:1 overruns:0 frame:0
TX packets:22160 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:74155073 (70.7 MiB) TX bytes:2119238 (2.0 MiB)
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:2408 errors:0 dropped:0 overruns:0 frame:0
TX packets:2408 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:121104 (118.2 KiB) TX bytes:121104 (118.2 KiB)
wlan0 Link encap:Ethernet HWaddr 00:0c:43:47:9c:56
RX packets:50 errors:0 dropped:9 overruns:0 frame:0
TX packets:3 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:4924 (4.8 KiB) TX bytes:350 (350.0 B)
iwlist wlan0 scan | grep ESSID
ESSID:"chessbroadband"
