julesd
x300 on pi 2
Mon Mar 16, 2015 10:57 pm
Hi guys
I know that pi 2 is different from b+, but there wasn't a pi 2 section for hardware yet and I know the x300 board works on both...
So... I have bought a couple of these :-
and I have followed the tutorials here :-
http://www.suptronics.com/Xseries/x300.html
but I can't get them to fully function. Wifi works and sata is spotted by the pi. I can get sound working too (as it is effectively a USB sound card on a USB hub)
I can't get the real time clock or the infrared to work though.
the web site has a raspian image, but they don't tell you the password!
Anyone got one of these fully working?
timrowledge
Re: x300 on pi 2
Wed Mar 18, 2015 5:31 pm
I have one of these (as well as an x100 for my old B and X505 for my A+) and had no trouble with the RTC stuff.
I *didn't* use the pre-built raspbian because it was just on the cusp of the Pi2 release; after some conversations about that with the extremely helpful support staff I worked through the "Section F Setting RTC time " part of the web page and had no problems. If you use rasp-config to enable i2c you'll almost certainly find that /etc/modprobe.d/raspi-blacklist.conf already has the bcm2708 stuff removed.
Now the bit I still haven't got going fully is the sound card. I really want to get some sound input working for Scratch.
Making Smalltalk on ARM since 1986; making your Scratch better since 2012
chucic
Re: x300 on pi 2
Tue Mar 24, 2015 4:39 am
The RTC for X300....needs fully follow theirs method, and please follow this page...
http://www.suptronics.com/Xseries/Using%20I2C.html
But, now, I'm using theirs image....
And install KODI, OFFICE, and Retropie on that....
Almost is full system....
ik4hps
Re: x300 on pi 2
Sat Oct 10, 2015 5:25 pm
I Julest
I see in your post you have a Suptronicx X300 with the wi-fi work well.
Sorry a question i've two X300 on Raspberry2 but I can not be able to configure wi-fi and I can not find information on how to fix it.
You how you got ??
Thank you and best regards
mirco
maxpavlov
Re: x300 on pi 2
Fri Nov 27, 2015 4:23 pm
Same problem, can't get WiFi on X300 to work. Not being detected.
FalloutBoy
Re: x300 on pi 2
Sat Jan 02, 2016 1:23 pm
I don't mean to hijack this but whats the speed like using SATA? I was considering one of these myself but have not seen any tests or anything that provides information on what sort of speed the SATA connection can do.
mikronauts
Re: x300 on pi 2
Sat Jan 02, 2016 5:50 pm
With an SSD or fast SATA drive, you will likely get 20MB/sec-30MB/sec, if the USB-SATA chip on the x300 mode supports usb attached scsi mode you might get close to 40MB/sec if nothing else (like Ethernet) is running.
See
http://www.mikronauts.com/raspberry-pi/ ... erry-pi-2/
http://www.mikronauts.com/raspberry-pi/ ... ent-howto/
for more info, which will show you why it is not possible for it to be faster
p.s.
SATA over GPIO will be much slower.
FalloutBoy wrote:I don't mean to hijack this but whats the speed like using SATA? I was considering one of these myself but have not seen any tests or anything that provides information on what sort of speed the SATA connection can do.
timrowledge
Re: x300 on pi 2
Mon Jan 04, 2016 7:57 pm
maxpavlov wrote:Same problem, can't get WiFi on X300 to work. Not being detected.
With the latest Raspbian (november '15) and the menubar network tool, it just works for me.
parapac
Re: x300 on pi 2
Sun Jan 17, 2016 8:08 pm
sorry if I am hijacking.
I had to install twice before I could get wifi working. Mine is on the raspi2 with Raspbian Wheezy 1.4.*
I have managed to get WIFI, IR and sound working but as for BlueTooth........nothing.
it says you have to change the baud rate from
dwc_otg.lpm_enable=0 console=tty1 root=/dev/mmcblk0p6 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
to
dwc_otg.lpm_enable=0 console=ttyAMA0,9600 kgdboc=ttyAMA0,9600 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline rootwait
when I do change it, the pi refuses to boot as it looks like the tty has totally changed.
joelalock
Re: x300 on pi 2
Tue Sep 27, 2016 5:57 pm
I'm using retropie 4 with mine so wifi was easy to set up. Sata was not a problem. IR sensor "sees" my harmony 650 remote and my phone "sees" the bluetooth. I was able to get sound working thru the 3.5mm jack but have not been able to get optical to output and there is an annoying thump on boot (think of the sound of dropping a needle on vinyl 3 times)
Now when I emailed them and asked for some help configuring the audio they said that they can not help me because everybody's situation is different. (WTF?)
Regarding helping me with my remote control they recommended that I buy a usb bluetooth adapter! Again WTF? One of the features of this board is bluetooth and guess what..it's usb!!
I had heard. That this company offers excellent support but someone was lying! I do not recommend anyone supports Suptronics! They have some neat stuff but without support or alot of knowledge they are useless to a regular Joe like me. (Pun intended)
Do not buy!
End rant
klintkrossa
Re: x300 on pi 2
Fri Dec 30, 2016 7:27 pm
I did have the same when I first got my board.
Make sure that thei2c is on.
http://www.suptronics.com/xseries/Using%20I2C.html
This is not like any other bulletin boards that I have been on. Been flamed on other BB's so bad I was afraid to ask.
All my Raspberry Pi's are like the Hessian artilleryman of Sleepy Hollow.
