73 duster
Sd card, noobs and xbmc
Sat Mar 14, 2015 2:06 am
Hi guys, new here and totally new to the Pi.... Just got the pi2. It seems to run fine with the kit I bought. I do intend getting more to add to my ham radio shack in the future.... But for now, I need to play and get familiar with the thing.
I am a Mac user, no PCs here.
Anyway, tonight I bought a new sd card, followed online instructions and installed xbmc on it. Attached to TV, and just got the multicolour screen. Does the card have to have anything else on it? Like another install of noobs? Thanks in advance.
Jeff
philmccan
Re: Sd card, noobs and xbmc
Sat Mar 14, 2015 6:42 am
XBMC is not compatible with pi2. Look at your other options.
Sat Mar 14, 2015 6:54 am
73 duster wrote:Hi guys, new here and totally new to the Pi.... Just got the pi2. It seems to run fine with the kit I bought. I do intend getting more to add to my ham radio shack in the future.... But for now, I need to play and get familiar with the thing.
Jeff
As XBMC is an interface and not an Operating System have no idea what you are trying to install.
The XBMC interface is now called KODI.
May I suggest you install OpenElec if you want a Media Centre Operating System
http://openelec.tv/get-openelec
73 duster
Sat Mar 14, 2015 2:12 pm
OK... So I need to install the xbmc on the same card as noobs? Then it should work.?
Sat Mar 14, 2015 2:23 pm
73 duster wrote:OK... So I need to install the xbmc on the same card as noobs? Then it should work.?
No you need to install OpenElec on its own, forget NOOBS
Yet again there is no Operating System called XBMC
73 duster
Sun Mar 15, 2015 3:43 am
All I am asking is how do I go about getting xbmc running. As I said totally new to this.
I have a Pi 2, an sd card that came with it that boots the machine.
I also have a new 16g sd card that is blank. If someone could please explain, that would be great. I only have macs here. As much detail as possible would be great.
thanks.
Sun Mar 15, 2015 6:58 am
73 duster wrote:All I am asking is how do I go about getting xbmc running. As I said totally new to this.
thanks.
Have you been ignoring my responses :?:
Try again XBMC is now called KODI and is an interface, it is not an Operating System
OpenElec is an Operating System which uses the KODI interface http://openelec.tv/get-openelec
download the second item under ""ARMv7 builds - RPi2 ARMv7 quad core models (Model B 1024MB)""
" [Stable] OpenELEC 5.0.6 (arm) Diskimage" which is named 'OpenELEC-RPi2.arm-5.0.6.img.gz' and needs to be unzipped which will then be
Then you need to 'copy' this to the SD Card
http://www.raspberrypi.org/documentatio ... ges/mac.md
73 duster
Sat Mar 21, 2015 9:21 pm
Thanks for that.
Now have it all installed. But surprise surprise, a whole new set of problems have arisen! LOL!
Sat Mar 21, 2015 9:44 pm
73 duster wrote:Thanks for that.
http://www.raspberrypi.org/forums/viewt ... 3&t=104918
Return to “Beginners”
