SpamGate VX
Could a Rasberry PI 2 B power an external HDD by itself?
Fri Mar 13, 2015 5:47 pm
Could a Rasberry PI 2 Model B power an external HDD without a usb hub? If so, is it safe for the HDD & Rasberry PI?
Is a 5 Volt 2 Ampere Micro USB power supply enough for an external HDD + USB IR Reciever + WIFI dongle?
Thanks in advance.
Re: Could a Rasberry PI 2 B power an external HDD by itself?
Fri Mar 13, 2015 9:15 pm
SpamGate VX wrote:Could a Rasberry PI 2 Model B power an external HDD without a usb hub? If so, is it safe for the HDD & Rasberry PI?
Thanks in advance.
Though this was wriiten when the B+ was released it is also applicable to the RPi2 B, and has proven to be AOK providing you have a quality PSU
https://projects.drogon.net/testing-set ... berry-pi-b
In config.txt add the line max_usb_current=1 and reboot
pluggy
Fri Mar 13, 2015 10:38 pm
Yes, I've done it, but you need good power. It will not work with a cheap USB cable you bought off ebay.
mikronauts
Sat Mar 14, 2015 12:53 am
With max_usb_current=1 I was able to run two different SSD's and a laptop drive (only one plugged in at a time) from a Raspberry Pi 2
For the laptop drive, I also needed to use a short cable, as a long cable dropped too much voltage.
http://www.mikronauts.com/raspberry-pi/ ... ter-tests/
