Michael.S
Device tree and the Gertduino
Thu Mar 12, 2015 3:43 am
I have a rpi 2 with a Gertduino board, been having quit a time get this running.
1: Installed Friends of the unicorn instruction and could not get the Gertduino to program.
2: After many installs I used to avrdude 5.10-4 for the Gertboard and managed
to upload my sketch with no RC-1 error.
3: Found out that I have to remove the reset on the Gertduino to see my sketch run.
4: After reading the post here on disabling the device tree it all seems to work fine.
My knowledge is limitted but growing but the way it is right now i can not access the
Atmega 48 and disabling the device tree seems to be a short term fix. Is there another
way to do a better installation and could I adding a line in the config.txt and enable the
device tree ?
Thank You
Mike
Gert van Loo
Re: Device tree and the Gertduino
Thu Mar 12, 2015 1:31 pm
The issue is being investigated.
I can't try it here and now but thus might be a SW solution script:
reset_off:
#!/usr/bin/sudo bash
# Set GPIO pin 8, high releasing Arduino reset
sudo echo "8" >/sys/class/gpio/export
sudo echo "out" >/sys/class/gpio/gpio8/direction
sudo echo "1" >/sys/class/gpio/gpio8/value
# Do not release the GPIO as the device tree reverts it to input mode : keep it in output mode
# sudo echo "8" >/sys/class/gpio/unexport
reset_on:
sudo echo "0" >/sys/class/gpio/gpio8/value
panik
Thu Mar 12, 2015 11:31 pm
Unfortunately,
pi@raspberrypi ~/gertduino $ ./reset_on
pi@raspberrypi ~/gertduino $ ./reset_off
echo: write error: Device or resource busy
An experiment: first check if the pin is already exported. If it is, unexport it before requesting it again.
reset_on:
if [ -d /sys/class/gpio/gpio8 ]; then
fi
reset_off:
fi
At first sight, that seems to work:
However, now the pin is still exported. That means avrdude isn't able to pull the reset pin to program the chip and it will yell at you. The pin needs to be unexported before programming with avrdude.
reset_unexport:
fi
Or something. It may not be pretty, but here we are.
Microcontroller addon boards and software for Raspberry Pi A+/B+/Pi2:
- ARMinARM: ARM Cortex-M3 (STM32)
- AVRPi: ATmega32U4 & ATmega328 ("Arduino")
http://www.onandoffables.com
Michael.S
Fri Mar 13, 2015 1:58 am
Thank for your prompt reply, I have tried the code and the sketch woks with the reset off sent. When I
send another sketch it automatically reset the pin to on by itself. I have to send another rest off the sketch
works.
Mike
