some_evil
Trying to understand this code...
Tue Mar 10, 2015 3:14 am
Hi All,
I have recently been setting up a Thermometer with my Pi, and I have noticed a line of code in a tutorial which I am using, but I am unsure what it is doing exactly, so I am hoping to research and have it clearer in my mind...
The line is:
print 'Temp={0:0.1f}*C  Humidity={1:0.1f}%'.format(t,h)
I am used to doing this type of thing:
print 'Hi, My name is %s and my age is %s years' % (name,age)
but this stuff with the curly brackets and .format has me stumped.
Can anyone please either explain what the code is doing in my first example? Or give me something I can google to research myself?
Thanks very much for your time.
PiZeroW - May 2017
Pi 3 - Oct 2016
PiZero - June 2016
Pi 2 - Jan 2016
Pi B+ - Dec 25 2014
Douglas6
Re: Trying to understand this code...
Tue Mar 10, 2015 3:43 am
Format is the preferred method of doing the same thing. One, it requires more typing, and so promotes stoicism and finger strength. Two, it is more flexible, and is described fully here: https://docs.python.org/2/library/strin ... ing-syntax
some_evil
Tue Mar 10, 2015 3:55 am
Excellent, so after a quick read, I think I can pull it apart...
{0:0.1f}
the first zero is referencing the first argument (in this case it is 't')
the 0.1f is telling it that the t should be displayed to 1 decimal place. E.g. 26.5*C
is it as simple as that?
PiZeroW - May 2017
Pi 3 - Oct 2016
PiZero - June 2016
Pi 2 - Jan 2016
Pi B+ - Dec 25 2014
Douglas6
Tue Mar 10, 2015 3:58 am
Just that easy. The arguments can have names instead of indices, but frankly I've never seen it done. You can also skip the index {:0.1f} and assume a sequence.
Return to “Python”
