MasterOfPuppets
Servo control - with or without driver?
Sun Mar 08, 2015 3:18 pm
Hello guys! :)
I am going to build simple (or not) robot. I have a question.
Why should I use driver to control servo?
My friend told me, that using driver may provide me more precise control over the servo, is it truth?
Thanks in advance
mikerr
Re: Servo control - with or without driver?
Sun Mar 08, 2015 3:38 pm
Couple of options:
  • Directly control a single servo via pi's hardware PWM
    the Pi only has one hardware PWM pin, GPIO18
  • Control 8 or more servos by software PWM using pigpio, servoblaster etc.
    In theory this option can cause jitter of servos, but I've found it fine.
  • Use an external servo controller board/chip.
    This offloads the "work" to the board, freeing up GPIOs
mikronauts
Sun Mar 08, 2015 4:15 pm
I can recommend joan's pigpio, it worked well for my SPRITE robot.
For more complex robots, I use my RoboPi controller (http://RoboPi.com) which can control up to 24 servos and has eight 12 bit analog inputs. (each of the 24 digital I/O's can control: a servo, or pwm motor, or digital input, or digital output, or ultrasonic distance sensor)
http://Mikronauts.com - home of EZasPi, RoboPi, Pi Rtc Dio and Pi Jumper @Mikronauts on Twitter
Advanced Robotics, I/O expansion and prototyping boards for the Raspberry Pi
MasterOfPuppets
Sun Mar 08, 2015 5:43 pm
Thanks, one more question.
Whats a difference between DRV8835 dual motor driver and RaspiRobot board?
As far as I know both can hold two motors, but second one is more expensive.
joan
Sun Mar 08, 2015 6:51 pm
The DRV8835 and raspirobot boards are for DC motors not servo motors. Is this in addition to any servos you may be using?
Personally for DC motors I just use the L298N or similar motor driver boards from eBay for a couple of pounds.
MasterOfPuppets
Sun Mar 08, 2015 7:22 pm
I know thats for motors. :) I just dont understand whats the difference between both (RaspiRobot and DRV8835). Could You answer me?
L298N is a bit cheaper but bit bigger. Thanks for advice. :)
Grumpy Mike
Tue Mar 17, 2015 10:02 am
They are both H-bridge controllers. The RaspiRobot is built up on a board and uses a L293DNE chip at the heart of it. This uses transistors to do the switching and will give a little voltage loss on the motor drive and has a 1A limit.
DRV8835 is a chip that you will have to build into your own board. It uses FETs to drive the bridge and has a 1.5A limit. It has a 0.35 ohm on resistance so you loose less voltage through the bridge.
Return to “Beginners”
