I've got a couple of old original Model Bs and wanted to get cases for them but it seems a lot of the cases (like the PiBow) are for the "rev 2" which has hole next to the USB ports which the original did not.
Can anyone recommend any cases that'll fit the first generation ones?
Cheers
Re: Case for Model B "Rev 1"?
maybe I'm misunderstanding, but I think that unless the case _requires_ using the 'mounting' holes, then it'll work fine with rev.1 and rev.2 equally.
pibow should be fine, as should 99% of small plastic cases. definitely double-check you're getting them for the original pi though, and not a + or pi2 type...
note: I may or may not know what I'm talking about...
The PiBow (coupe version at least) requires the mounting hole next to the USB stack.
Lots of the cases don't make it clear though
Hi !
I have made many enclosure in these three years
here I expose some model for the first version of the Raspberry Pi.
https://lh4.googleusercontent.com/-3bJF ... to1458.jpg
in birch wood version..
https://lh3.googleusercontent.com/-blkO ... to1469.jpg
enclosure Adapter for Piface board..
http://www.raspberrypi.org/forums/downl ... hp?id=2888
enclosure Adapter for Wolfson Pi board....
http://www.raspberrypi.org/forums/downl ... hp?id=7765
Under the avatar, you see the link AMAZON store
Now I'm more for the use of wooden case , as they are more ecofriendly
and more resistant than acrylic enclosure. Feel free to comment !!
Thank's
Thank's
We have a discount for purchases made in ETSY site
Discount Codes :MAYTHE4TH
This worked well for me: http://www.modmypi.com/raspberry-pi/cas ... ry-pi-case whilst my Rev 1 B worked
