Re: How to add cgminer 4.8.0 on pi raspbian
Mon Dec 21, 2015 9:20 am
use nohup
nohup ./miner.script.name.goes.here &
royal007
Wed Dec 23, 2015 10:13 pm
This guide helped me a lot, but the one question it didn't answer was what happens after. If I disconnect putty or close it out, does that shut down the miner. If it does, is there a way around that?
Wed Dec 23, 2015 10:43 pm
nohup means no hangup, the nohup'd task keeps running until you kill it, it fails or your reboot.
djdrtaylor
Sat Jan 09, 2016 8:51 pm
I just performed this tutorial and had no issues at all, Thank you!
My differences were
I used Raspian-Jessie full version.
my choices for Over Clocking were 900 and 1000 since you went to 800 in the video I left it alone.
my hash rate score is 63.57 Gh/s.
using Raspberry Pi/2
Still not sure how to set up my wallet but that will be next. :geek:
sgtpepper01
Sat Jan 16, 2016 5:59 pm
thank you for you informative post. Followed all steps without issue, but the moment
Install, configure and also enable bmsc options:
cd cgminer
(here) ******* sudo ./autogen.sh (it fails and come up with autorunconf:not found)
export LIBCURL_CFLAGS=’-I/usr/include/curl’
sudo ./configure --enable-bmsc
sudo make
lgritsch
Tue Feb 23, 2016 10:23 pm
Hey there, thanks for the tutorial, it also worked for me.
I am, however, not mining any bitcoins, since I only use my Raspberry Pi 2 and no external miners. Is that why I am not mining? Or is there likely to be any setup error?
thanks in advance :)
Bendito
Tue May 31, 2016 6:39 pm
Hello Folks,
I realize this is an old thread, but it is one of the most recent I have seen on the web regarding BTC and Raspberry Pi. It is also the only thread, out of all the tutorials I have tried (and there are many) that successfully got cgminer installed and working on my Pi.
Has anyone had any success mining on a Pi 3? I used the instructions above and removed the frequency and voltage settings as I am using Sapphire Asicminer through a powered D-Link USB 2.0 hub.
cgminer looks to be working fine, the USB miner is detected and enabled, the pool is connecting to cgminer, even the led on the miner starts blinking when I launch cgminer BUT, there is zero activity.
Here is what I am using to launch cgminer:
sudo ./cgminer --bmsc-options 115200:1:1 -o stratum+tcp://us-east.stratum.bitcoin.cz:3333 -u User.Worker -p Password
(no, I don't actually use User.Worker and Password)
And here is what I get:
cgminer version 4.9.0 - Started: [2016-05-31 14:33:45]
(5s):0.000 (1m):0.000 (5m):0.000 (15m):0.000 (avg):0.000h/s
A:0 R:0 HW:0 WU:0.0/m
Connected to us-east.stratum.bitcoin.cz diff 8 with stratum as user User.Worker
Block: 25ce4653... Diff:199G Started: [14:33:45] Best share: 0
SB management [P]ool management ettings [D]isplay options [Q]uit
0: AMU 0 : | | 0.000 / 0.000h/s WU:0.0/m
[2016-05-31 14:33:51] Bmsc send golden nonce1
[2016-05-31 14:33:51] Bmsc recv golden nonce timeout
[2016-05-31 14:33:52] -----------------start nonce------------------
[2016-05-31 14:33:52] Bmsc send golden nonce1
[2016-05-31 14:33:53] Bmsc recv golden nonce1 0345182b03 -- 0345182b
[2016-05-31 14:33:53] Bmsc send golden nonce2
[2016-05-31 14:33:53] Bmsc recv golden nonce timeout
[2016-05-31 14:33:53] AMU0 Init: mode=default read_time=100ms limit=0ms Hs=2.97
6100e-09
[2016-05-31 14:34:16] Pool 0 difficulty changed to 51
[2016-05-31 14:34:16] Stratum from pool 0 requested work restart
[2016-05-31 14:34:46] Pool 0 difficulty changed to 10
[2016-05-31 14:34:46] Stratum from pool 0 requested work restart
[2016-05-31 14:35:16] Pool 0 difficulty changed to 8
[2016-05-31 14:35:16] Stratum from pool 0 requested work restart
It just hangs.
Any advise or assistance would be VERY appreciated.
svenskdod
Sat Aug 06, 2016 1:09 pm
Hi there,
I have had no issue with this, it works fine. However, the final part, having it auto-run is not working for me unfortunately. I keep getting a "There is no screen to be attached matching cgminer." Message. I have the right username in and everything. I would just like to have this going while I am not SSH'd into the pi. I have checked via the slushpool terminal, and it is not actually going in the background.
  GNU nano 2.2.6                                            File: /etc/rc.local
#!/bin/sh -e
# rc.local
# This script is executed at the end of each multiuser runlevel.
# Make sure that the script will "exit 0" on success or any other
# value on error.
# In order to enable or disable this script just change the execution
# bits.
# By default this script does nothing.
# Print the IP address
_IP=$(hostname -I) || true
if [ "$_IP" ]; then
  printf "My IP address is %s\n" "$_IP"
fi
cd cgminer
screen -dmS cgminer ./cgminer --bmsc-options 115200:0.57 -o stratum+tcp://eu.stratum.bitcoin.cz:3333L -u USERNAME -p anything --bmsc-voltage 0800 --bmsc-freq 1286
exit 0
Any help would be most appreciated.
yohomiedude
Sat Aug 06, 2016 1:19 pm
svenskdod wrote: stratum+tcp://eu.stratum.bitcoin.cz:3333L -u USERNAME -p anything --bmsc-voltage 0800 --bmsc-freq 1286
You have the letter "L" after the stratum address, try removing that and try again :)
DXPetti
Tue Aug 09, 2016 9:31 am
svenskdod wrote:Hi there,
#!/bin/sh -e
# rc.local
# value on error.
# bits.
if [ "$_IP" ]; then
fi
cd cgminer
exit 0
Rather than use Screen, why not use nohup
nohup /home/pi/cgminer/cgminer --compact --real-quiet --bmsc-options 115200:0.57 -o stratum+tcp://eu.stratum.bitcoin.cz:3333L -u USERNAME -p anything --bmsc-voltage 0800 --bmsc-freq 1286 >/dev/null 2>&1&
Best to use --compact and --real-quiet options otheruse cgminer sends your CPU usage through the roof when sending all output + errors to the /dev/null blackhole
At least, this is how I've been running USB ASIC miners with cgminer on my Pi A+ for a long time now http://dxpetti.com/blog/?tag=cgminer
bigs21024
Tue Aug 16, 2016 12:11 am
i have a raspberry pi model b old one and a zeus thunder x3 running jessie can someone direct me to a step by step way to download this for the zeus please i know the miner works i have tried for iver a month cant get it to work dont think i downloaded it right i have never used linux jessie thanks
bigs21024
Tue Aug 16, 2016 11:53 pm
ok i have a raspberry pi model b older one running jessie i have a zeus thunder x3 and no matter what i do i cant get it to find my miner. i have never used linux so mabe i did something wrong is there any step by step instructions anywhere what commands and everything thanks
DJ_2012
Fri Oct 14, 2016 8:26 pm
Hello, I followed this tutorial and I'm trying to get gridseed miners workin, but I do not know how. CGminer does not detect them and I dont know how to add them, or even if I need to.
Are there drivers for griseed I should be using?
Please help out even if you could point me to a tutorial it would be great!
kliksaja
Sun Jul 09, 2017 12:46 pm
Dear ajweller88,
Other than antminer U3, is there any other devices like Bitfurry can mined using raspberry pi3 model b ?
Please Provide step by step how to set up , By the way do you think " Bitminter " good " for the Pool ?
Thanks in advance.
Gbu.
mzisu
Wed Jul 12, 2017 9:19 pm
I tried with several Ant Miners and I keep getting the following (any ideas why?)
[2017-07-12 17:10:52] Started cgminer 4.9.0
[2017-07-12 17:10:52] No devices detected!
[2017-07-12 17:10:52] Waiting for USB hotplug devices or press q to quit
[2017-07-12 17:10:52] Probing for an alive pool
I am using RPI2 with Raspbian, I was following
this URL in order to set the RPI2:
http://www.robbiebrandrick.com/Blog/Details/6
Starbiker
Mon Jan 22, 2018 6:24 pm
Hi all, This is driving me insane.
Got a raspebbry Pi 3 and a gridseed blade but no matter what I try I cannot get it to work.
CG miner tries to mine from the CPU and does not see the blades. :(
I am a total noob although picking up alot. :?
Already have Raspbian loaded, a fixed IP though the router so I can use putty and windows remote login.
changed the password for route and user.
Got a wallet and pool setup and ready to go. :geek:
all the equipment is working lovely, well er apart from CGminer and the hashing.
mining LTC only but later want to add maybe more gridseeds but for now HELPPPP! :oops:
Avulcron
Sat Jan 27, 2018 10:51 pm
WHAT DID I DO WRONG?
Stnrfrk
Fri Jul 13, 2018 7:36 pm
Does this setup work with gekkoscience 2pac USB miners. If so what freq would I use for 3 miners overclocked 33gh/s which I think is there Max. Don't know if I could push them further with great cooling unit. Any helpful info would be greatly appreciated. Thank you in advance.
Brabus453
Thu Aug 09, 2018 11:53 pm
i have same issue for Bifurry usb
no usb devices detected...
any help??
Brabus453
Fri Aug 10, 2018 9:05 am
i think i found the problem
when you are using a powered usb hub
(i do)
connect the power cable from usb hub to raspberry.
then, it should detect you usb miner.
it works for me in bfgminer and cgminer. now it detects my bitfury sticks.
hope this helps
Return to “Raspbian”
