Fght
rasbpian (installed with noobs) won't boot up
Sun Mar 01, 2015 12:28 pm
i've messed up with the config.txt and then raspbian won't boot...
i've a backup file in the same folder but don't know how to make it primary...
how can i do that?
B.Goode
Re: rasbpian (insralled with noobs) won't boot up
Sun Mar 01, 2015 12:31 pm
From https://github.com/raspberrypi/noobs/bl ... /README.md
On any subsequent boot you can then press the SHIFT key to enter the NOOBS interface and easily reinstall your choice of OSes.
The NOOBS interface provides the following functionality:
Install: Installs the selected OSes onto your SD card. Changing this selection erases all OSes currently installed.
Edit Config: Opens a text editor allowing the cmdline and config for the selected installed OS to be edited.
Fght
Re: rasbpian (installed with noobs) won't boot up
Sun Mar 01, 2015 12:36 pm
cool
when i enter the 'Edit Config' feature how can i make "copy-all" command and "select-all"??
going to check it...
Fght
Sun Mar 01, 2015 12:45 pm
i've added the '#" back... but now i won't get it booted up too... this time i can see the process tho...
http://postimg.org/image/q9d1xozev/
if i only could know how to copy the whole backup file text and put it in the real thing it might have solved it...
DirkS
Sun Mar 01, 2015 2:00 pm
Fght wrote:i've added the '#" back... but now i won't get it booted up too... this time i can see the process tho...
Maybe you don't have to type too much if you leave out all the comments (lines starting with '#').
Fght
Sun Mar 01, 2015 5:12 pm
sorry, i don't understand
what do i need to do?
DirkS
Sun Mar 01, 2015 6:23 pm
Fght wrote:sorry, i don't understand
Lines starting with a '#' are comments and can be left out.
I would be surprised if you would need to type more than 10 (short) lines.
Fght
Sun Mar 01, 2015 6:26 pm
i already changed the lines to start with a hash tag..
but it's yield these errors
what do i need to do to use my raspbian again?
DirkS
Sun Mar 01, 2015 6:31 pm
Fght wrote:i already changed the lines to start with a hash tag..
Try it with an empty config.txt
Fght
Sun Mar 01, 2015 6:49 pm
i've emptied it but for some reason the problem persisting...
http://postimg.org/image/ly28e771r/
any solution for this besides installing noobs and raspbian again?
Fght
Sun Mar 01, 2015 7:41 pm
Maybe it is open elec that took all the space on the card?
edit:
anyone knows what to do next?
should i really reinstall noobs from the beginning? there is no solution for that?
