Ah22
Newbie, Os, Openelec?
Fri Feb 27, 2015 12:49 pm
I'd set out to use a pi to slideshow our pictures and movies of the children.
I'd originally set up raspbian OS, I had a quick nose around and then from searching found xbmc could do what I wished.
after realising raspxbmc isn't compatible (thinking I'd bricked the pi already) I tried open elec.
It does what I set out to do, it shares files from my laptop and HDD.
BUT, that's all it does I feel like I'm missing out on what the pi could do. I feel like I'm cheating.
Is it possible to run xbmc on raspbian os, or is there a program that will screensave photos and videos?
I'm new so raspian and installing anything looked scary.
Alex
Jayzeewood
Re: Newbie, Os, Openelec?
Fri Feb 27, 2015 2:47 pm
From what I have read Raspbian Wheezy can install XBMC might be what you are looking for but l am very new to the Pi
Fri Feb 27, 2015 3:01 pm
Ah22 wrote:Hi,
Alex
f
XBMC is now called KODI see
http://www.raspberrypi.org/forums/viewt ... 66&t=99866
Ah22
Fri Feb 27, 2015 4:21 pm
Thank you fruit of the loom.
I assume the best place to get used to running command text would be from working through the tutorial materials?
Sadly I've never had much experience with this before and its a bit daunting to a person that's only ever double clicked something to install...
Fri Feb 27, 2015 4:31 pm
Ah22 wrote:Thank you fruit of the loom.
http://www.raspberrypi.org/help
