RecDev
120 seconds network wait on boot
Thu Feb 26, 2015 3:45 pm
When I configure a static ip for the Raspberry Pi (Latest Raspian Wheezy on a B+), in order to let it have an IP when a laptop connects with an Ethernet cable (The only way it will be connected to anything), the boot has a 120 seconds wait ("Waiting up to X more seconds for network" message pops up until it finally finishes the boot process)
All I did was set "ip=192...." in the /boot/cmdline.txt.
I have found no way to remove or reduce this wait time, as raspian lacks a failsafe.conf where such timeouts are usually found.
Is there a way to change it, or am I missing something vital regarding the static IP setup for direct network connections with no DHCP involved?
rpdom
Re: 120 seconds network wait on boot
Thu Feb 26, 2015 3:57 pm
Don't set the ip= in cmdline.com. Set the interface as static in /etc/network/interfaces.
iface eth0 static
    address 192.168.x.x
    netmask 255.255.255.0
    gateway 192.168.x.y
topguy
Thu Feb 26, 2015 4:00 pm
I believe it better to edit "/etc/network/interfaces" to set a static IP-address. If this file still specifies dhcp then it will try to run the dhcp client and waste a lot of time.
RecDev
Thu Feb 26, 2015 4:41 pm
Thanks, this way worked fine!
