geinux
Aliendeb for Raspberry Pi 2
Thu Feb 26, 2015 3:06 am
Standardized on the ARMv7-A architecture.
**youtube**
https://www.youtube.com/watch?v=F9YKpxRj5PQ
***download***
http://1drv.ms/1Ug4iSy
https://goo.gl/fKnMtn
https://goo.gl/eW8Bpy
***download torrrent***
https://goo.gl/ITNZbC
aliendeb-desktop-next-20150830.img
md5sum: 585a06c1070845b6f8e5d9b502e6e231 ./aliendeb-desktop-next-20150830.img
Default user: pi (password=aliendeb)
***NEW aliendeb desktop next 20150830*** :D :D :D :D :D :D :D
## by geinux 2015/08/30, new codename Aliendeb Desktop Next
## Updates
- Tested 4.x kernel, /PI_BOOT/config.txt
edit change:
# kernel=aliendeb.img
for this:
kernel=aliendeb.img
- Aliendeb Mod, /PI_BOOT/config.txt
- 32-bit color
- editing /etc/network/interfaces
- editing sources ubuntu 15.04 /etc/apt/sources.list
- Kodi media center
- LibreOffice
- Chromium web browser
- New theme and icons
- Aliendeb config
- Developers, libraries for scrips: zenity, yad, gtkdialog
Ryatzu
Re: Debian Jessie for Raspberry Pi 2
Thu Feb 26, 2015 12:22 pm
Thanks, will check it out today!
fraz0815
Thu Feb 26, 2015 2:01 pm
wow, that thing is fast, thanks :) I really need to move away from raspbian on pi 2 ...
first quick test shows some little minor problems when trying to use raspi-config.
expand root-fs does not work here '/dev/root does not exist or is not a symlink' - so using fdisk manually.
change localisation, keyboard layout also has no effect within raspi-config.
wicd does not work, or does not find anything. Issue seems similar to the UbuntuHF image I have read.
lsusb shows wifi-dongle, will test later if editing /etc/network/interfaces works
geinux
Thu Feb 26, 2015 9:30 pm
Hello all! ;)
I will review the changes in
-raspi-config (expand root-fs)
-wifi-dongle, editing /etc/network/interfaces
cjan
Fri Feb 27, 2015 5:41 am
jessie repository did not have omxplayer included?
rosslyn568
Sat Feb 28, 2015 7:03 pm
Thanks for the great image. I have it up and running but I'm having a little trouble getting the resolution to the desired 1920x1080. Anything I try with xrandr gives me this error:
xrandr: Failed to get size of gamma for output default
Tried several different things to no avail. Any ideas?
AndyD
Sat Feb 28, 2015 10:20 pm
rosslyn568 wrote:Thanks for the great image. I have it up and running but I'm having a little trouble getting the resolution to the desired 1920x1080. Anything I try with xrandr gives me this error:
You need to change the resolution in config.txt. On the Raspberry Pi you can't change the resolution from within X11.
rosslyn568
Sun Mar 01, 2015 2:22 am
I set the hdmi mode settings in the context and everything worked brilliantly. Thanks a lot
geinux
Wed Mar 04, 2015 6:36 am
***NEW iso*** :D :D :D :D :D :D
## by geinux 2015/03/4, new codename Aliendeb
## Updates
- Kodi media center
- 32-bit color
- Aliendeb Mod, boot/firmware/config.txt
**Torrent**
https://www.dropbox.com/s/g6cvdk15onmov ... rrent?dl=1
**Bittorrent Sync** - keep updated
https://link.getsync.com/#f=rpi-2&sz=68 ... HODVQLYRPD
eriktheitalian
Re: Debian Jessie (codename Aliendeb) for Raspberry Pi 2
Thu Mar 05, 2015 9:44 am
Firsty, thanks for developed Aliendeb.
Theme look like very nice.
Report:
My atheros based wifi no working. I'm installed atheros-firmware from debian repository. Not solution. Ubuntu 14.10 default not support atheros based wifi/bluetooth. Is it new kernel/module/package based issue i dont know.
I cant change keyboard map from rasp-config. ( or rasp-setup )
I cant using enough English language. My writings can be wrong grammer.$
"in micro$oft we not trust"
geinux
Thu Mar 05, 2015 11:27 am
eriktheitalian wrote: I cant change keyboard map from rasp-config. ( or rasp-setup )
terminal:
sudo dpkg-reconfigure keyboard-configuration
sudo dpkg-reconfigure locales
sudo dpkg-reconfigure tzdata
eriktheitalian
Thu Mar 05, 2015 12:04 pm
terminal:
resulting "keyboard-configiration not installed"
wifi fixed with "sudo modprobe ath9k_htc" after installed firmware.
eriktheitalian
Thu Mar 05, 2015 12:07 pm
When i'm tried "sudo apt-get update && sudo apt-get upgrade" resulting "libre office dependency -f to install". Its solved with removed libre office piece. This is only report.
eriktheitalian
Thu Mar 05, 2015 12:47 pm
Your config.txt modification :
# Aliendeb Mod
gpu_mem=160
framebuffer_ignore_alpha=1
framebuffer_depth=32
hdmi_group=1 CEA
arm_freq=1000
sdram_freq=500
core_freq=500
h624_freq=500
isp_freq=500
v3d_freq=500
over_voltage=2
gpu_mem=160
gpu_mem_1024=128
disable_overscan=1
initial_turbo=30
force_turbo=0
hvs_priority=0x32ff
dispmanx_offline=1
force_turbo=1
max_usb_current=1
dtdebug=on
dtparam=i2c_arm=on
dtparam=i2s=on
dtparam=spi=on
dtoverlay=lirc-rpi:gpio_in_pin=18,gpio_in_pull=down
dtoverlay=ds1307-rtc
Your image default overclocked. U are activated 1.2Amp usb support.
geinux
Thu Mar 05, 2015 2:43 pm
eriktheitalian wrote:Firsty, thanks for developed Aliendeb.
Report:
***terminal***
sudo apt-get -f install
sudo nano /etc/apt/sources.list
paste new line
deb http://ftp.debian.org/debian jessie main contrib non-free
sudo apt-get update
sudo apt-get install firmware-linux-nonfree firmware-bnx2 firmware-atheros firmware-realtek firmware-brcm80211 firmware-bnx2x
eriktheitalian
Thu Mar 05, 2015 10:40 pm
Report:
***terminal***
paste new line
sudo apt-get update
Thanks for image work and firmware advice.
Debian repo built in Atheros firmware is poor with kernel 3.18. I'm compiled new driver. Its done. Not your fault.
RobHenry
Fri Mar 06, 2015 11:06 pm
Boot doesn't complete for me with this image; it hangs at:
random: nonblocking pool is initialized
and I have to pull the power.
I put the rootfs onto USB drive and haven't used the huge config.txt that comes with the image - could either of these factors cause boot to fail in this way?
philippe.marques
Sat Mar 07, 2015 1:54 am
Good job, just clean /home/pi/.cache/mozilla/firefox ;)
Nada mal.
rinky451
Contact: Website Yahoo Messenger
Sat Mar 07, 2015 2:25 am
may i ask where you get the .zip file or the image to put on a sd card for the pi 2.. seems this dropbox link does not work for I thought that may be where the file is at.
https://www.dropbox.com/s/g6cvdk15onmovkc/aliendeb-rpi2-20150304.zip.torrent?dl=1
Sat Mar 07, 2015 10:24 am
RobHenry wrote:Boot doesn't complete for me with this image; it hangs at:
There's a firmware bug that causes that.
https://github.com/raspberrypi/firmware/issues/374
RobHenry
Sat Mar 07, 2015 8:30 pm
Thanks Dougie. I'll try swapping in working firmware and see if that fixes it.
karl_k
Wed Mar 11, 2015 10:01 pm
Hi !
Great stuff ! I have been trying for weeks to get kodi to compile on my debian jessie rpi2, unfortunately unsuccessfully...
Could you tell us how you got kodi running ? I seem to run into problems with the gles implementation.
I would really like to try your build, unfortunately, the torrent is quite dead, i am currently downloading at 1kb/s...
Any other way to get your image ?
Thanks,
Karl
tounch
Thu Mar 12, 2015 10:46 am
Thx for the image.
But I ve got some problems with the streaming on the web bowser (lag on youtube)
Can I install the flashplayer plug in on it ?
Ps : sorry for my bad english ;) :oops:
gkreidl
Thu Mar 12, 2015 11:47 am
tounch wrote:Thx for the image.
No (real) Adobe Flash plugin, never!
You are missing the hardware accelerated webkit engine that can use the GPU for playing HTML5 video. One more reason to stay with Raspbian.
Minimal Kiosk Browser (kweb)
Return to “Other”
