BluRazPi
I need the "other programs" menu!
Thu Feb 26, 2015 2:56 am
Hi all, I have a Raspberry Pi model B, and soon a Pi2 and I am beside myself with excitement over the new one, but for now I have a bit of a problem. I recently flashed the latest build of Raspbian (2015-1-31) onto my Pi and I do like the new interface update, but the "other programs" menu has been removed from the application menu and while I understand that it was removed to clean up the interface, I really need a way to get it back (without reverting to an older OS build). I recently installed a couple programs on the pi, but they don't show up in any of the app categories that are available in the application menu; I suspect that I would find them in the "other programs" menu, which is nowhere to be found. One of the two programs I was able to run from the terminal and I find that to be real pain, but not the other. I really need a way to modify the menu to bring back the "other" menu. Can anyone please help me?
Any help would be greatly appreciated,
BluRazPi
klricks
Re: I need the "other programs" menu!
Sun Mar 01, 2015 12:22 am
Note that boot to desktop must first be enabled in order to do this.....
Go to [menu] --> shutdown and select Logout
Select LXDE from the popup menu box.
Login: pi
Password: raspberry (and you WILL see *** as you type)
Click login
You will now get the old desktop with [other] in the menu etc.
The choice will stick for future reboots.
To change back to the new setup.... logout and select [Default Xsession] and login to desktop again.
smartroad
Sun Mar 01, 2015 9:40 am
Is there anyway to get this to work with the current install? I have just installed BitScope and its desktop file indicates it should be listed in Science, Engineering and Application. However none of those show up. I have been forced to update the entry to include Office so I can have the icon.
I get this new interface was about cleaning up the default install but now it is preventing me from having a logical layout for the application menu :( Having an engineering application listed in the office section doesn't make sense to me ;)
Return to “Raspberry Pi OS”
