Hello there.
I would like to know if this is going to work in theory:
Powering the Pi with a 5.1V 700mA phone charger (high quality), and using an old USB2.0 HUB that has 4 ports and two connections, by disconnecting the power pins of the plug that is going to be connected to the Pi and connecting the other plug to a 5V 1000mA charger, in order to use an external HDD (850mA) and perhaps a logitech nano receiver (100mA) and a USB Flash Driver (100mA).
Here's a plan I did using some highly specialized and pofressional software:
"HUB C." stands for HUB Connector (USB male plug). The hub has 2 male plugs. Their power pins are connected together but I'm going to cut the power wires of the plug that's going to be used for the data.
Any ideas? Will any USB HUB work?
