fruitoftheloom wrote:deth502 wrote:thanks guys!!! (and maybe girls, idk) the win32 app worked just like fedora *should have*. very simple and i am currently writing to my sd card (albeit very slowly) so all is well so far.
again, many thanks!
sean
Well confusion reigns you clearly wrote in response earlier
i have pi 1 B+, but at this point, its irrelevant. i havent even touched it yet. im just trying to get raspbian wheezy onto an sd card to put into it. thats where im stuck.
So what are you trying to install ?
What model of RPi ?
ok, my terminology might be off, so let me try this again. im still new to this so my choice of diction may have made me hard to understand.
first off, i DID get win 32 imager to work fine so my problem IS SOLVED. not solved in as much as i got fedora to work, as was my original intent, but solved in that i got a different app (win 32 imager) to do what i needed done INSTEAD OF fedora.
question 1: im not trying to "install" anything. i was not able to write the raspbian wheezy image to my sd card because fedora would not recognize any devices to write to. i am still waiting on either my small 3.2" touch screen from ebay or my hdmi cable from amazon before i will even try to "install" anything onto the pi.
question 2: i have a pi 1 (not the new pi 2 model) b+ (not the a or b), but this is a moot point as my problem was not with the pi. i dont even have the pi out of the box yet. i cannot do anything with the pi until i get either my hdmi cable or display screen in. i have ethernet cables, a keyboard, mouse, power supply, and
now that the problem i had in my op is solved, an sd card with raspbian on it. my next step after getting some kind of display will be to put all of this together and install raspbian onto my pi, and hopefully everything will go well from this point on out.
