matthieu_in_hk
kernel.img and kernel7.img?
Sat Feb 21, 2015 3:03 am
On my /boot partition I have 2 files named kernel*.img.
How can I know which one i'm currently running ? (I need to delete the other one for space reasons):
Thanks for your help. Under my config.txt and the $ ls -ls /boot
Cheers,
Mat
pi@rp /boot $ more config.txt |grep kernel
kernel=linux-3.12.y
pi@rp /boot $ ls -ls
total 17752
   8 -rwxr-xr-x 1 root root    4379 Feb 20 19:03 bcm2708-rpi-b.dtb
   8 -rwxr-xr-x 1 root root    4658 Feb 20 19:03 bcm2708-rpi-b-plus.dtb
   8 -rwxr-xr-x 1 root root    5622 Feb 20 19:03 bcm2709-rpi-2-b.dtb
  24 -rwxr-xr-x 1 root root   17856 Feb 20 19:03 bootcode.bin
   8 -rwxr-xr-x 1 root root     120 Dec 21 19:14 cmdline.txt
   8 -rwxr-xr-x 1 root root    1486 Feb 20 17:13 config.txt
  24 -rwxr-xr-x 1 root root   18693 Feb 20 18:09 COPYING.linux
   8 -rwxr-xr-x 1 root root     256 Feb 13 20:02 edid.dat
   8 -rwxr-xr-x 1 root root    2354 Feb 20 19:03 fixup_cd.dat
   8 -rwxr-xr-x 1 root root    6144 Feb 20 19:03 fixup.dat
  16 -rwxr-xr-x 1 root root    9196 Feb 20 19:03 fixup_x.dat
   8 -rwxr-xr-x 1 root root     137 Dec 24 20:29 issue.txt
3880 -rwxr-xr-x 1 root root 3969768 Feb 20 19:03 kernel7.img
3904 -rwxr-xr-x 1 root root 3996668 Feb 20 19:03 kernel.img
   8 -rwxr-xr-x 1 root root    1447 Feb 20 18:09 LICENCE.broadcom
  24 -rwxr-xr-x 1 root root   18974 Sep 26  2013 LICENSE.oracle
3144 -rwxr-xr-x 1 root root 3217152 Jan 30 07:52 linux-3.12.y
   8 drwxr-xr-x 2 root root    8192 Feb 20 19:03 overlays
 544 -rwxr-xr-x 1 root root  555672 Feb 20 19:03 start_cd.elf
2584 -rwxr-xr-x 1 root root 2643544 Feb 20 19:03 start.elf
3520 -rwxr-xr-x 1 root root 3600424 Feb 20 19:03 start_x.elf
AndyD
Re: kernel.img and kernel7.img?
Sat Feb 21, 2015 3:07 am
If you are using a Pi 2, the kernel will be kernel7.img, if you are using any other Raspberry Pi it will use kernel.img.
matthieu_in_hk
Sat Feb 21, 2015 4:23 am
Ok, thanks for the clarification.
I have a RPI B+, so I can erase the kernel7.img ?
Thanks,
Mat
Sat Feb 21, 2015 6:34 am
Yes.
Sat Feb 21, 2015 7:41 am
You can also trash that 3.12.y kernel you've got in there.
ragnarjensen
Sun Feb 22, 2015 4:10 pm
According to this
kernel=linux-3.12.y
you're not running either of the kernel*.img files, but the linux-3.12.y file.
Ragnar
Me5000
Mon Dec 25, 2017 6:15 pm
Does the Raspberry Pi Zero W use kernel7.img or kernel.img?
Mon Dec 25, 2017 6:44 pm
kernel.img is used by RPi 1B, 1A, A+, B+, 2B (first version) Z, Z (with camera), ZW, CM1
kernel7.img is used by the RPi2B2, RPi3B, CM3 and CM3L.
codedoo
Mon Jan 01, 2018 6:29 pm
that's strange :roll: because I put 3 files in my sd for booting a bare metal Pi zero hello world (only a blink led to say hello):
bootcode.bin
kernel7.img
start.elf
Files bootcode.bin and start.elf come from raspberry firmware, while kernel.7.img is created by me using this code :
https://github.com/cirosantilli/raspber ... 91e13fd764
The code from the github example is for Pi 2, but works in my Pi Zero too.
(Thank you guys for this topic, very very interesting )
Regards
Leonardo
Return to “Raspberry Pi OS”
