teuma86
Best board for Motors
Thu Feb 19, 2015 7:11 pm
Hi
My friend and I are joining the world of PI.
I am looking build a robot of some time, he is looking to build a RC Tank.
Both items require multiple motors (He already has a broken tank which has 5 motors)
I looked at a L298N Board but that appears to only support 2 motors.
Can anyone point me in the right direction to the best boards and why for multiple motors.
I will also be looking at adding some LEDs so ideally dont want to use up all my GPIO ports.
Thanks in advanced.
teuma86
Re: Best board for Motors
Fri Feb 20, 2015 6:27 pm
Hi
Sorry not heard anything.
I have looked at an
L298N board which only controls 2 motors
We are looking to control
2 DIFFERENT LEDs
8 DC Motors
USB Webcam
Can someone suggest which board to use with Raspberry Pi 2?
I would love to see a blog of the different boards.
Regards
Jamie
joan
Fri Feb 20, 2015 6:45 pm
The board to use will depend on the motors.
teuma86
Fri Feb 20, 2015 6:57 pm
Hi
These are standard DC Motors found in most RC Cars.
Similar to
http://www.mind.ilstu.edu/curriculum/me ... cmotor.jpg
mikronauts
Fri Feb 20, 2015 7:15 pm
- What kind of LED's?
- How many of the 8 motors need bi-directional (forward, reverse) control?
- I suggest the Raspberry Pi Camera instead of the USB Webcam
teuma86 wrote: 2 DIFFERENT LEDs
8 DC Motors
USB Webcam
mott555
Fri Feb 20, 2015 7:23 pm
I'm planning out a similar project, and my current plan is to use some transistors as relays/switches for the motors, and trigger the transistors using some GPIO outputs and play with PWM for throttling.
teuma86
Fri Feb 20, 2015 7:27 pm
I believe standard LEDS (5mm)
Trying to work it out. This particular model for the tank has 5 motors but my project I am looking at 8, yes ideally bi-directional
Tank motors
2 to drive (Left and Right)
1 Move torrent around
1 Moves torrent up / down
1 fires gun (not seen this motor but i believe this can be one direction.
mikronauts
Fri Feb 20, 2015 7:47 pm
Ok, sounds like you need four bi-directional motor drivers, and one uni-directional motor or solenoid, depending on how the gun is fired.
For the four bi-directional motors:
Each motor will require 2 or 3 I/O's, depends on type of motor driver.
EN, DIRA, DIRB - requires 1 PWM, 2 I/O's per motor
EN, DIR - requires 1 PWM, 1 I/O per motor
DIRA, DIRB - requires 2 PWM per motor
so you require 4 - 8 PWM's and 0-8 additional GPIO's depending on motor type.
You will also need:
- 2 limit switches for turret up/down
- 2 limit switches for turret turning
for an additional 4 I/O's
Plus one I/O per LED.
You need to find out the voltage and stall current of the motors in the tank, so you can select an appropriate dual H-bridge driver board.
Models A & B would likely not have enough I/O to do what you want, an A+ / B+ / 2 should work, with joan's pigpio library, and appropriate driver boards.
Two L298N or three modules should work, if the motors do not require more than about 1.5A current during normal operation.
Or, if you want a lot more I/O, you could use a RoboPi in addition to your Raspberry Pi (see http://RoboPi.com)
teuma86 wrote:I believe standard LEDS (5mm)
Tank motors
teuma86
Fri Feb 20, 2015 8:09 pm
Thanks mikronauts
Please can you explain the Abbreviations. I am a web programmer, learning Pi and by the looks of it, in the deep end.
So my initial instinct of to purchase multiple L298N boards. I have seen multiple alternatives, just curious if one was better than the other.
I shall order multiple L298N boards
http://www.ebay.co.uk/itm/L298N-Stepper ... 43d12bba8a
mikronauts
Fri Feb 20, 2015 8:54 pm
You are welcome.
EN = enable
DIRA = go in one direction
DIRB = go in other direction
on other type of controller
DIR = 0 - go one direction
DIR = 1 - go in other direction
teuma86 wrote:Thanks mikronauts
