Help needed please.
Downloaded from torrents this file (raspbian_2gb.img) for which I found by doing a search for RPI Raspberry Pi raspbian wheezy 2gb image with deluge couchpotato sickrage on Google.
Description
***UPDATED***
raspbian wheezy 2gb image with deluge couchpotato sickrage (sickbeard) minidlna installed
user = pi
password = raspberry
ports:
deluge = 8112 (no passwd)
couchpotato = 5050
sickbeard = 8081
minidlna = 8200
change deluge to 'use compact allocation' for stability
You need at least 4gb sd card, loaded image to sd card with no problem then put it into RPI and started everything I think loaded because it asked for a login and password so entered Login pi and password raspberry then it came back with Type 'startx' to launch a graphical session so I typed this
pi@raspberrypi ~ $ startx it came back with
-bash: startx: command not found
pi@raspberrypi ~ $
I am at a lost for now there is no documentation for me to follow and I am trying to get something to run on a RPI for auto TV downloads, have tried to install Sonarr (Nzbdrone) but there also cannot get it to work.
Hoping someone can please help me with good documentation or an image of Sonarr for the Raspberry Pi . Again thank you and any help is appreciated .
JGN
naselloj@yahoo.com
