Thu Feb 19, 2015 1:40 pm
Thanks Pluggy. I've deleted all other OS, just leaving Raspbian. But still shows at only 2500MB available on a 4GB card....?
if you only want to use raspbian, which I would recommend as the first pi os to use and get to know, I would forget about what you have already on that SD card and write a new raspbian only (ie not NOOBS at all) image to use, from the download page. When it first runs up you will see the raspi-config menu running and at the top of the menu is the option to 'expand the filesystem'. This will automatically adjust the partitions to make full use of your chosen SD card.
Hope this helps,
Texy
