Heartland
Audio not streaming?
Thu Feb 19, 2015 12:12 pm
So i am trying to create a bluetooth speaker with the speakers I've already got and a bluetooth adapter on my pi. However the pi and my phone is now connected, however I cant get any audio to play. Does anyone know why or can help me?
thanks
tpylkko
Re: Audio not streaming?
Thu Feb 19, 2015 3:45 pm
If you don't know this it is easier to do this with wifi, and with wifi you can stream unpacked 24 bit hires audio, whereas with bluetooth your going to have to stream packed audio and it will not work out-of-the-box. Which OS are you using?
Heartland
Thu Feb 19, 2015 6:49 pm
already brought the bluetooth adapter so im doing it by bluetooth. Raspbain is the one im using.
tpylkko
Thu Feb 19, 2015 7:14 pm
Bluez 5. 28?
Heartland
Thu Feb 19, 2015 7:16 pm
i dont know what you mean, sorry? i installed something along the line of "blueman"
tpylkko
Thu Feb 19, 2015 7:37 pm
http://www.raspberrypi.org/forums/viewtopic.php?t=68779
pairing the device is only a part of the process.
See the thread on bluetooth audio streamin
Heartland
Thu Feb 19, 2015 8:09 pm
i was following this project as well as a few others and have done all the steps to where audio should work. Thats where i realized something wasn't right.
tpylkko
Thu Feb 19, 2015 8:49 pm
are your speakers connected to the pi via an amp that inputs on HDMI? or are you using the analog audio out? Or maybe even something else?
Douglas6
Thu Feb 19, 2015 10:29 pm
Isolate the problem. Are you running PulseAudio systemwide? Can you play a local file with 'sudo paplay'? Does the phone show a 'use for media audio' under the paired device? With the phone connected and playing audio, does 'sudo pactl list sources' show the Bluetooth source? Do you have a udev rule (or other method) to load the loopback module? Does 'sudo pactl list modules' show the loaded loopback module? Does it show the proper source and sink?
Heartland
Sat Feb 21, 2015 7:11 pm
Im using a 3.5mm audio connector. However i have tried plugging my apple headphones into the pi and i get no sound that way either.
When i typed
it returned:
pi@raspberrypi ~ $ sudo pactl list sources
Source #0
	State: SUSPENDED
	Description: Monitor of bcm2835 ALSA Analog Stereo
	Driver: module-alsa-card.c
	Sample Specification: s16le 2ch 44100Hz
	Channel Map: front-left,front-right
	Owner Module: 4
	Mute: no
	Volume: 0: 100% 1: 100%
	        0: 0.00 dB 1: 0.00 dB
	        balance 0.00
	Base Volume: 100%
	             0.00 dB
	Monitor of Sink: alsa_output.platform-bcm2835_AUD0.0.analog-stereo
	Latency: 0 usec, configured 0 usec
	Flags: DECIBEL_VOLUME LATENCY
	Properties:
		device.description = "Monitor of bcm2835 ALSA Analog Stereo"
		device.class = "monitor"
		alsa.card = "0"
		alsa.card_name = "bcm2835 ALSA"
		alsa.long_card_name = "bcm2835 ALSA"
		alsa.driver_name = "snd_bcm2835"
		device.bus_path = "platform-bcm2835_AUD0.0"
		sysfs.path = "/devices/platform/bcm2835_AUD0.0/sound/card0"
		device.string = "0"
		module-udev-detect.discovered = "1"
		device.icon_name = "audio-card"
	Formats:
		pcm
Source #1
	State: SUSPENDED
	Description: Ipod touch, Emma
	Driver: module-bluetooth-device.c
	Owner Module: 25
	Mute: no
	        balance 0.00
	Base Volume: 100%
	             0.00 dB
	Monitor of Sink: n/a
	Flags: HARDWARE DECIBEL_VOLUME LATENCY
	Properties:
		bluetooth.protocol = "a2dp_source"
		device.description = "Ipod touch, Emma"
		device.string = "78:6C:1C:5A:CF:1D"
		device.api = "bluez"
		device.class = "sound"
		device.bus = "bluetooth"
		device.form_factor = "portable"
		bluez.path = "/org/bluez/2147/hci0/dev_78_6C_1C_5A_CF_1D"
		bluez.class = "0x6a041c"
		bluez.name = "Ipod touch, Emma"
		device.icon_name = "multimedia-player-bluetooth"
	Formats:
		pcm
this is was while i was playing music.
Douglas6
Sat Feb 21, 2015 8:13 pm
OK, good, you have a Bluetooth audio source. To connect that to your audio out, try
sudo pactl load-module module-loopback source=bluez_source.78_6C_1C_5A_CF_1D sink=0
That should get the sound playing. To make that automatic, see this post: http://www.raspberrypi.org/forums/viewt ... 13#p619713 and follow the instructions for setting up a udev rule, at the bottom of step 5 (the 'Finally (finally!)' step.)
Ignore the cron nonsense in that b.ramus post mentioned earlier.
Heartland
Sat Feb 21, 2015 9:23 pm
[quote="Douglas6"]OK, good, you have a Bluetooth audio source. To connect that to your audio out, try
That doesnt work sorry.
Douglas6
Sat Feb 21, 2015 9:34 pm
Does it return an error? What does 'sudo pactl list modules' show? Are you sure the phone is not paused? Your previous output showed 'SUSPENDED' like the phone was not playing audio.
Heartland
Sun Feb 22, 2015 12:23 pm
returns
Module #23
Argument: address="78:6C:1C:5A:CF:1D" path=" /org/bluez/2149/hci0/dev_78_6C_1C_5A_CF_1D" profile="a2dp_source" auto_connect=no
Usage counter: 0
Properties:
module.author = "Joao Paulo Rechi Vita"
module.description = "Bluetooth audio sink and source"
module.version = "2.0"
I hope thats the right module, cant find a way to copy and paste something out of my remote desktop into my normal desktop on my laptop.
it doesn't return an error but a number which gets greater each time i run the command. Its not paused.
Douglas6
Sun Feb 22, 2015 2:56 pm
You should be looking for a module-loopback module with the same number as that returned by the pactl load-module command. Mine looks like this
Module #14
        Argument: source=bluez_source.AA_BB_CC_DD_EE_FF sink=0
        Usage counter: n/a
        Properties:
                module.author = "Pierre-Louis Bossart"
                module.description = "Loopback from source to sink"
Make sure the phone is trusted.
sudo bluez-test-device trusted 78:6C:1C:5A:CF:1D
should return '1'. If it returns '0', do
sudo bluez-test-device trusted 78:6C:1C:5A:CF:1D yes
Then disconnect your phone and re-connect.
Heartland
Mon Feb 23, 2015 1:27 pm
ok i have that module and has made the phone trusted, but i still cant get it to play any music!
Douglas6
Mon Feb 23, 2015 1:45 pm
OK, back to an earlier question. Does 'sudo paplay <local.wav>' work? You are using powered speakers, right? Check alsamixer to ensure that the volume is turned up. When you 'sudo pactl list sources', does the Bluetooth source show 'RUNNING' and not 'SUSPENDED'?
Heartland
Mon Feb 23, 2015 10:12 pm
So I did the alsamixer and it was down on 0, so I turned it up to 100. I did this on both bars was this right? I don't have any local files on my pi and as I'm a newbie to the pi, I don't really get how to get them. And yeah it says suspended when is paused and when its playing.
Douglas6
Tue Feb 24, 2015 4:27 am
There is a test file on the Pi. I think it's at /usr/share/sounds/alsa/Front_Center.wav (I don't have my Pi to hand).
Heartland
Tue Feb 24, 2015 1:46 pm
ok. i don't know what that sound file is meant to sound like but all i can hear is a hissing sound when i play it, but that is an improvement when i just play songs from my phone to my speakers, over bluetooth. The hissing sound is only when the sound is playing as it stops when the sound is over.
