Who is we? You and the OP? 500k Pi2's sold so far, if things were not ready, I think there would be more issues showing up!Whayle wrote:Brand new Pi 2 and my first Pi, downloaded fresh images of openelec and raspbmc, and I get the same colored screen on boot using two different memory cards. Something tells me we aren't ready?
Sadness...
RASPBMC is not Pi2 compatible last time I looked.Whayle wrote:Brand new Pi 2 and my first Pi, downloaded fresh images of openelec and raspbmc, and I get the same colored screen on boot using two different memory cards. Something tells me we aren't ready?
Sadness...
Raspbmc is abandonned.(now it's OSMC)texy wrote:RASPBMC is not Pi2 compatible last time I looked.Whayle wrote:Brand new Pi 2 and my first Pi, downloaded fresh images of openelec and raspbmc, and I get the same colored screen on boot using two different memory cards. Something tells me we aren't ready?
Sadness...
Texy
From: http://www.raspberrypi.org/downloads/jamesh wrote:Who is we? You and the OP? 500k Pi2's sold so far, if things were not ready, I think there would be more issues showing up!Whayle wrote:Brand new Pi 2 and my first Pi, downloaded fresh images of openelec and raspbmc, and I get the same colored screen on boot using two different memory cards. Something tells me we aren't ready?
Sadness...
Where did you downlaod the images from? Have you tried Raspbian?
OpenELEC
An XBMC Media Centre
Version: 4.0.5
Release date: 2014-06-14
Note that the release dates for both pre-date the February 2015 release date of the RPi2, so to me it is no surprise that they are not compatible.RaspBMC
Version: November 2014
Release date: 2014-11-24
A bit of an update - as of Sun 16/02/2015 NOOBS lite was downloading a version of OpenELEC which appeared to install O.K. on my Pi2B. See my comment here:RaTTuS wrote:openelec does not work on a RPi2
http://openelec.tv/get-openelec <- read
The color pattern display normally means that your power supply is not sufficient - try another one and place well the microUSB connector.skilesd wrote:Just bought Pi 2 and pre-loaded NOOBS. Only a color pattern shows when I power on. frustrated!
You are assuming that the "color pattern" showing is the low voltage indicator. Given the rest of the available data, it may well be the GPU test screen: A 4-color pattern more or less filling the screen.user007 wrote:The color pattern display normally means that your power supply is not sufficient - try another one and place well the microUSB connector.skilesd wrote:Just bought Pi 2 and pre-loaded NOOBS. Only a color pattern shows when I power on. frustrated!
Some suggestions I found at elinux.org regarding the "coloured splash screen" or "rainbow screen" were about the power supply.W. H. Heydt wrote: You are assuming that the "color pattern" showing is the low voltage indicator. Given the rest of the available data, it may well be the GPU test screen: A 4-color pattern more or less filling the screen.
Ignore the ELinux wiki pages.user007 wrote:Some suggestions I found at elinux.org regarding the "coloured splash screen" or "rainbow screen" were about the power supply.W. H. Heydt wrote: You are assuming that the "color pattern" showing is the low voltage indicator. Given the rest of the available data, it may well be the GPU test screen: A 4-color pattern more or less filling the screen.
Since it is about purchased microSD card with pre-loaded NOOBS we may expect that the microSD card, the kernels and the config.txt file are correct.
"Immediately after displaying the splash screen, the PI starts consuming a little more current. If the PI resets at that moment, it is an indication that the power supply isn't able to deliver the full current your PI requires, but dips its output voltage below a minimum when loaded with the full current the PI needs."
Some more suggestions and explanations regarding the "coloured splash screen" you may find at:
http://elinux.org/R-Pi_Troubleshooting# ... ash_screen
The vast majority of these pages haven't been updated since the original Pi 1 was released and the early adopters crawled all over the devices finding bugs that were subsequently beaten out of the software.
With the release of Pi 2, these pages become even more irrelevant and misleading for new users.
I would not assume that a purchased NOOBS card is correct for a Pi2B. Indeed, I was looking at some other items on the MCM Electronics site today and they specifically noted that the NOOBS cards they have are *not* suitable for a Pi2B, and that they are trying to get newer ones that can be used for the Pi2B.user007 wrote:Some suggestions I found at elinux.org regarding the "coloured splash screen" or "rainbow screen" were about the power supply.W. H. Heydt wrote: You are assuming that the "color pattern" showing is the low voltage indicator. Given the rest of the available data, it may well be the GPU test screen: A 4-color pattern more or less filling the screen.
There were many posts here regarding similar problems and normally they all investigate the PS in case of Under-voltage Rainbow square warning. Something more. They also are giving a suggestion that the result of using a low voltage PS could be not only "coloured splash screen" or "rainbow screen" however a damaged SD card or damaged starting kernel image:W. H. Heydt wrote: I would not assume that a purchased NOOBS card is correct for a Pi2B.
user007 wrote:There were many posts here regarding similar problems and normally they all investigate the PS in case of Under-voltage Rainbow square warning. Something more. They also are giving a suggestion that the result of using a low voltage PS could be not only "coloured splash screen" or "rainbow screen" however a damaged SD card or damaged starting kernel image:W. H. Heydt wrote: I would not assume that a purchased NOOBS card is correct for a Pi2B.
http://www.raspberrypi.org/forums/viewt ... 29&t=82373
Another problem is that sometimes the purchased RPI2 plastic box may prevent proper placement of bigger plastic microUSB connector.
kusti8 wrote:
Normally people refer to the rainbow icon as small, and then we ask them if the red power light is blinking also. When getting a rainbow screen, the most common problem is an outdated version.
OSMC does claim to be Pi2 compatible.There might be a new version of RaspBMC, but it is now OSMC look there to see if a Pi2 version is up yet.
https://osmc.tv/2015/02/raspberry-pi-2- ... mc-supportBMS Doug wrote:OSMC does claim to be Pi2 compatible.There might be a new version of RaspBMC, but it is now OSMC look there to see if a Pi2 version is up yet.
