expandables
Exit Fix for Kodi Raspbian built
Wed Feb 18, 2015 11:53 pm
Hi I am a beginner coder and i got tired seeing a blank screen on exit when i am using Kodi on Raspbian so i came up with a fix.
This is a fix for
http://michael.gorven.za.net/raspberrypi/xbmc
My Kodi launcher script.
#!/bin/bash
setterm -cursor off
mkdir -p ~/.kodi
clear
/usr/lib/kodi/kodi.bin --standalone
setterm -cursor on
kodi-standalone runs in tty7 and it appears that it leaves a blank screen. To fix this, run
sudo nano /usr/bin/kodi-standalone
Delete or comment out the last three lines, so they look like this:
#VT="$(fgconsole)"
#chvt 7
#chvt "$VT"
and save it.
When you try to "Quit ", Kodi appears to leave a blank screen.
Kodi log shows
WARNING: Attempted to remove window 10013 from the window manager when it didn't exist
I made 2 scripts to fix this error.
The first script:
sudo nano /home/pi/exitfix.sh
and put
#!/bin/bash
find /home/pi/.kodi/temp/kodi.log  -type f -exec egrep -w "Attempted to remove window 10013" {} \;  > /home/pi/exitfix2.txt
The second script:
sudo nano /home/pi/exitfix2.sh
and put
#!/bin/bash
    exitfix=$(cat  /home/pi/exitfix2.txt| awk 'NR==1' | tail -c 6)
     if [ $exitfix = "exist" ]; then
      sudo killall /usr/lib/kodi/kodi.bin  && sudo rm -r /home/pi/exitfix2.txt  /home/pi/.kodi/temp/kodi.log
fi
I now use crontab to run these script every minute
sudo crontab -e
and put
*/1 * * * * /home/pi/exitfix.sh
*/1 * * * * sudo sh  /home/pi/exitfix2.sh
By thinking like an engineer you can create a raspberry pi.
Michael Jackson enthusiast.
I got the PI model B, B+ and PI 2 model B.
When will I get the A? I don't know.
Fght
Re: Exit Fix for Kodi Raspbian built
Sun Feb 22, 2015 9:19 pm
1. in what directory to put these?
exitfix.sh
exitfix2.sh
2. and this is how the crontab should look like?
http://postimg.org/image/nizi1cozp/
expandables
Sun Feb 22, 2015 10:03 pm
Hi yes that's how crontab suppose to look.
That script runs every minute.
The home directory. :mrgreen:
If you want kodi to instantly get back out of the black screen you can put this script in crontab and delete the one minute cronjobs out of crontab.
Do this:
sudo nano /home/pi/fastkodiexit.sh
and put this in
while [ 1 ];
do
 sudo sh /home/pi/exitfix.sh & /home/pi/exitfix2.sh
  sleep 1;
done
Now do
sudo chmod +x fastkodiexit.sh
Then put this in crontab
@reboot  sudo sh /home/pi/fastkodiexit.sh
Fght
Mon Feb 23, 2015 10:14 am
so you said i'm goog to go if i put both first files in the home directory........!?
Fght
Mon Feb 23, 2015 10:18 am
sorry,
i did it but my tv still turning off....... when i exit kodi
expandables
Mon Feb 23, 2015 1:48 pm
Fght wrote:sorry,
If your TV turning off then you have CEC enable.
To disable CEC in kodi go to system settings then go to input devices you will see "Peripherals" click on that and a box will appear saying cec adapter. Now Click on that and where you see enable click on that to disable the cec adapter and press OK.
Also you might want to put this in your config file
sudo nano /boot/config.txt
hdmi_ignore_cec=1
hdmi_ignore_cec_init=1
:mrgreen:
Fght
Mon Feb 23, 2015 6:12 pm
in what group to put this?:
hdmi_ignore_cec=1
under 'noobs auto generated settings?
expandables
Mon Feb 23, 2015 6:17 pm
Fght wrote:in what group to put this?:
hdmi_ignore_cec=1
Put it in the config.txt file sis you read the post? I showed you how to edit the config.txt file so you can put them in. :mrgreen:
Fght
Mon Feb 23, 2015 6:23 pm
http://postimg.org/image/ntpas7iin/
where exactly inside the file? there are many sections...
DirkS
Mon Feb 23, 2015 6:53 pm
Fght wrote:http://postimg.org/image/ntpas7iin/
There are no real sections there. You can put it anywhere you like...
Fght
Mon Feb 23, 2015 7:05 pm
what do these actually do?
hdmi_ignore_cec=1
i did the first thing you guys instructed me but i'm wondering what does the config file editing do..
DirkS
Mon Feb 23, 2015 7:07 pm
Fght wrote:what do these actually do?
hdmi_ignore_cec=1
Described in the RPF docs: http://www.raspberrypi.org/documentatio ... fig-txt.md
Fght
Mon Feb 23, 2015 7:13 pm
ok i've found it there...
one more thing...
should it take some significant amount of time until the kodi is exiting? i think you said before that i can change how much time it takes until it is shutting down (kodi)...
because after hitting exit everything freezes and after some time i can see the gui again...
DirkS
Mon Feb 23, 2015 7:18 pm
Fght wrote:because after hitting exit everything freezes and after some time i can see the gui again...
Yes, it can take a while. Never measured it, but it can take long enough to make you wonder if it *does*.
Fght
Mon Feb 23, 2015 7:22 pm
thank you
expandables
Mon Feb 23, 2015 7:26 pm
Fght wrote:ok i've found it there...
one more thing...
Read the fastkodiexit script tutorial i previously posted. :mrgreen:
vankogt
Thu Mar 05, 2015 7:18 pm
Here is my working fix.
I start kodi from this script:
#!/bin/bash
kodi -fs && sleep 1 && sudo service lightdm restart
expandables
Thu Mar 05, 2015 11:10 pm
vankogt wrote:Here is my working fix.
#!/bin/bash
I tried your script and i can confirm that this does not work. :mrgreen:
dom
Fri Mar 06, 2015 12:12 am
The exit hang has been fixed on Kido master branch and my helix_rbp_backports branch.
expandables
Fri Mar 06, 2015 12:16 am
Really then how can i compile it?
gkreidl
Fri Mar 06, 2015 8:16 am
Someone should tell Michael Gorven about the fix and ask him to update his repository, (I can't, because his spam filter doesn't like my IP).
Minimal Kiosk Browser (kweb)
vankogt
Fri Mar 06, 2015 3:04 pm
#!/bin/bash
It works perfect on my Pi2. I start from desktop icon
juppiter89
Fri Mar 13, 2015 12:07 pm
I think this is a better and simplier fix ;)
sudo nano exitfix.sh
#!/bin/bash
if [[ $(tail -1 /home/pi/.kodi/temp/kodi.log | grep "application stopped...") ]]
then
        killall kodi.bin
        mv /home/pi/.kodi/temp/kodi.log /home/pi/.kodi/temp/kodi.old.log
        chvt 2 && sleep 1 && chvt 1
fi
sudo nano /etc/crontab
*/1 * * * * root bash /home/pi/exitfix.sh
Pixa
Wed Mar 25, 2015 8:41 pm
Any news regarding this fix ?
gkreidl
Wed Mar 25, 2015 10:06 pm
Pixa wrote:Any news regarding this fix ?
No. There was a posting on kodi.tv forum a while ago (by popcornmix) who proposed that a fixed version should be added to the Raspbian repository, but that hasn't happened yet.
