sudo raspi-configThanks!expandables wrote:Hi you will need to expand the sd card file system size so you can use all of the space. To do that ssh into the pi and typeand press enter on expand file system then reboot the pi.Code: Select all
sudo raspi-config
No. Use the extra storage on the same RPi2.xoopha wrote:I assume that you mean to use that same card on another computer as extra storage, without destroying the Pi OS in the card for further use with your Pi2?
Thanks!xoopha wrote:Oh, sorry. Then of course, sudo raspi-config and choose to expand the filesystem. Or, if you have used NOOBS, it will be done automatically.
