z3roCoo1 wrote:I have a bunch of these and was wondering if I can use the GPIO to control some of my lab equipment. It's got a handy RJ-45 port for control with 4 pins inside so easy to patch in.
This is the device I'm talking about;
http://www.rfi-engineering.com/downloads/RE.99.R1NC.pdf
It's got one of these in it;
http://uk.rs-online.com/web/p/non-latch ... m=680-3739, that's as far as my googling got me.
Potentially I could have the RE.99.R1NO version. For background, I'm a Cisco engineer and I have a few dozen of these as they were not used on a project. I'd like to put them to good use in our lab here and also at home
I'm willing to post one to any UK address for you to have a play and in return provide some idiot proof instructions!
hi z3roCoo1, I know the out of band modems and powers-switches a bit, and I too was looking to put the extra one I have got to good use. I just opened it, but it has more than the relay. It has its own transformer and small circuitry. And with the coil voltage of 12 volts it likely generates power that does fry your pi.
If we can find the modem circuits, we can see how they interface with the switches.
Perhaps one of the original engineers can help to document the port pinout and values.
BTW the switch port is a rj11 ( not rj45 )
When I have more time, I will use my multimeter to see what it does, and what is needed to interface with it from your pi GPIO ports. quite likely we need to add some circuitry to buffer the pi.
As these boxes are sturdy and well build I can see why you would reuse them. However if you know your electronics, and can create safe circuit setups, you might be able to use cheaper relay boards from Chinese origin . or even use them as buffer.
