jose4158
How to control the GPIO pins using c++
Fri Feb 13, 2015 4:05 pm
Sorry if this is a somewhat stupid question.
I have become a real expert with Python and the GPIO pins on my Raspberry Pi B+. But recently I decided that I should start coding in C++. I do know a fair amount of C++ but I do not know how to control the GPIO pins. I have looked at wiringPi, but I did not understand how to install and use it on the Raspberry Pi.
Could someone please explain to me (in the simplest way possible) how to control the GPIO pins using C++?? I don't care if it is not Wiring Pi, plus some simple example code (to light up a led?) would be greatly appreciated.
Thanks in advance to anyone who willingly can show me a way to control the gpio pins using C++. :D :D :D
AndyD
Re: How to control the GPIO pins using c++
Fri Feb 13, 2015 10:36 pm
There is a website for Wiring Pi. There are detailed instructions on installing the library here on the Wiring Pi website. The classic blink example is here.
joan
Fri Feb 13, 2015 10:45 pm
For a lightweight standalone solution have a look at my minimal gpio access at http://abyz.me.uk/rpi/pigpio/examples.html#Misc_code
perimeno
Sun Jun 02, 2019 8:54 pm
Take a look:
https://github.com/perimeno/LIO
Its a high level C++ wrapper for Linux sysfs, so no nasty direct memory writing and other hacky stuff that could mess up your OS.
Hope you can use it.
dl324
Sun Jun 02, 2019 11:10 pm
If you don't need MHz speed, using the sysfs interface is the easiest.
For more speed, you can use the register interface. I only have Pi Zero and Zero W, so can't give you specifics for B+.
6by9
Mon Jun 03, 2019 7:22 am
The Linux sysfs interface is officially deprecated, replaced by gpiolib. I can't see the official docs quickly, but the examples are at https://github.com/raspberrypi/linux/tr ... tools/gpio
hippy
Mon Jun 03, 2019 3:00 pm
Take a look:
Using sysfs for GPIO has long been deprecated in Linux and, I believe, is scheduled for removal in 2020 so probably not the best direction to send people in. Though the wrapper should stay the same, and be just as usable, once sysfs access has disappeared, assuming the author updates that wrapper.
The new recommended interface is 'gpio-cdev' which uses "/dev/gpiochip*", with 'libgpiod' to provide userland utilities. The latest Raspbian seems to support those but there's not been any discussion on here which I have seen and 'libgpiod' and userland utilities don't seem included by defult or available as an installable package yet -
https://www.kernel.org/doc/Documentatio ... /gpio-cdev
https://www.beyondlogic.org/an-introduc ... spberry-pi
6by9
Mon Jun 03, 2019 3:38 pm
libgpiod is available in Buster, but not Stretch - https://packages.debian.org/source/buster/libgpiod
It is certainly the recommended route forward instead of sysfs.
hippy
Mon Jun 03, 2019 7:22 pm
Do you happen to know what the future is intended to be for /dev/gpiomem and direct register access to GPIO when Buster arrives ?
I am guessing both will continue to be supported on the Pi because there are so many people currently using those to access GPIO.
buja
Tue Jun 04, 2019 7:45 pm
libgpiod seems to be pretty available to me on my Pi with Raspbian Stretch:
apt search libgpio
Sorting... Done
Full Text Search... Done
gpiod/stable,now 1.0.1-1~bpo9+1 armhf [installed]
  Tools for interacting with Linux GPIO character device - binary
libgpiod-dev/stable,now 1.0.1-1~bpo9+1 armhf [installed]
  C library for interacting with Linux GPIO device - static libraries and headers
libgpiod-doc/stable,now 1.0.1-1~bpo9+1 all [installed]
  C library for interacting with Linux GPIO device - library documentation
libgpiod1/stable,now 1.0.1-1~bpo9+1 armhf [installed,automatic]
  C library for interacting with Linux GPIO device - shared libraries
libgpiod1-dbgsym/stable 1.0.1-1~bpo9+1 armhf
  Debug symbols for libgpiod1
hippy
Tue Jun 04, 2019 8:24 pm
I see the same here, and /dev/gpiochip* exist.
But there's something missing. The userland utilities don't seem to be there, eg "gpiodetect", and when I tried building those gcc gives file not found for "#include <gpiod.h>".
buja
Wed Jun 05, 2019 5:43 pm
This is what I have:
 $ ls -l /usr/bin/gpio*
-rwsr-xr-x 1 root root 33348 Mar 13 14:41 /usr/bin/gpio
-rwxr-xr-x 1 root root  9728 Jun 29  2018 /usr/bin/gpiodetect
-rwxr-xr-x 1 root root  9728 Jun 29  2018 /usr/bin/gpiofind
-rwxr-xr-x 1 root root  9728 Jun 29  2018 /usr/bin/gpioget
-rwxr-xr-x 1 root root  9728 Jun 29  2018 /usr/bin/gpioinfo
-rwxr-xr-x 1 root root  9728 Jun 29  2018 /usr/bin/gpiomon
-rwxr-xr-x 1 root root 13824 Jun 29  2018 /usr/bin/gpioset
These tools are in the package gpiod, except gpio, which is part of wiringPi.
Header file gpiod.h is in /usr/include.
I don't remember doing anything special to make it work.
Example program, just a matter of gcc -o test test.c -lgpiod
/* test.c */
#include <stdio.h>
#include <stdlib.h>
#include <unistd.h>
#include <gpiod.h>
int main(void)
    printf("gpiod version: %d\n", gpiod_version_string());
hippy
Wed Jun 05, 2019 7:23 pm
Very odd, Pi 3B (non-plus), Raspbian Stretch Full with Desktop ...
[email protected]:~/tmp $ uname -a
Linux Pi3B 4.19.42-v7+ #1219 SMP Tue May 14 21:20:58 BST 2019 armv7l GNU/Linux
[email protected]:~/tmp $ ls -l /usr/bin/gpio*
-rwsr-xr-x 1 root root 33348 Mar 13 13:41 /usr/bin/gpio
None of the others.
[email protected]:~/tmp $ cat test.c
/* test.c */
#include <stdio.h>
#include <stdlib.h>
#include <unistd.h>
#include <gpiod.h>
int main(void)
[email protected]:~/tmp $ gcc -o test test.c -lgpiod
test.c:6:19: fatal error: gpiod.h: No such file or directory
 #include <gpiod.h>
compilation terminated.
Running "sudo apt-get install gpiod" does seem to have partially fixed things, bringing in "gpiod" and "libgpiod1" -- I had been trying to install "libgpiod" which doesn't exist !
That creates the previously missing /usr/bin/gpio* files, and this at least works and seems correct (3B) ...
[email protected]:~/tmp $ gpiodetect
gpiochip0 [pinctrl-bcm2835] (54 lines)
gpiochip1 [raspberrypi-exp-gpio] (8 lines)
gpiochip2 [brcmvirt-gpio] (2 lines)
But the compile still fails with gpiod.h not found. It's not in /usr/include.
"sudo apt-get install libgpiod-dev" fixed that ...
[email protected]:~/tmp $ ./test
gpiod version: 1995806036
Thanks for the pointers which got me there.
perimeno
Sat Nov 16, 2019 10:17 pm
Take a look:
Thanks for the info. I was able to provide both sysfs and gpiolib implementation. If you would like to manipulate IO from high level C++ code (and from user space) and you don't want to bother with implementation details you should give try to LIO.
btw sysfs is deprecated indeed, but it remains in the kernel as a legacy interface (https://www.kernel.org/doc/html/latest/ ... sysfs.html). And until you cant set from user space for example pull up/down resistors with gpiolob, it is really useful.
HermannSW
Sun Nov 17, 2019 9:57 am
For a lightweight standalone solution have a look at my minimal gpio access at http://abyz.co.uk/rpi/pigpio/examples.html#Misc_code
The link changed, seems to be this one today:
http://abyz.me.uk/rpi/pigpio/misc.html
pigpio library is nice way to access GPIOs from bash (with pigs), Python or C.
From C interface documentation, see gpioSetMode, gpioRead and gpioWrite for getting started:
What is really valuable it being able to send arbitrary waveforms on a GPIO pin.
Here is 61 line C program that does trigger two 9us long pulses, 0.925s apart (after being triggered by GPIO alert function):
https://github.com/Hermann-SW/Raspberry ... io_alert.c
I used that code, triggered from Raspberry camera frame sync pulses, to get two flashes "far" apart, but guaranteed to be in the 1 second timeframe of a 1fps recording video for global shutter capturing a fast rotating mini drone propeller with v1 camera:
https://github.com/Hermann-SW/Raspberry ... ync-pulses
⇨https://stamm-wilbrandt.de/en/Raspberry_camera.html
https://stamm-wilbrandt.de/github_repo_i420toh264
https://github.com/Hermann-SW/fork-raspiraw
https://twitter.com/HermannSW
Return to “C/C++”
