In one application we are using the raspberry p to control motor speed via PWM. We were able to get a valid working code on the rapsberry pi 2, but when we transferred this code and drivers over to the pi 3 the code simply does not work. Is there any easy thing we are missing in switching from the pi 2 to the pi 3 to get this code working? Thank you for any help.
#include <bcm2835.h>
#include <stdio.h>
#define PIN RPI_BPLUS_GPIO_J8_32
#define PIN2 RPI_BPLUS_GPIO_J8_33
#define CTL_PIN RPI_BPLUS_GPIO_J8_29
#define CTL_PIN2 RPI_BPLUS_GPIO_J8_31
#define PWM_CHANNEL 0
#define PWM_CHANNEL2 1
#define RANGE 1024
int main(int argc, char **argv)
// bcm2835_delay(10000);
if (!bcm2835_init())
return 1;
// Set the output pin to Alt Fun 5, to allow PWM channel 0 to be output there
bcm2835_gpio_fsel(PIN, BCM2835_GPIO_FSEL_ALT0);
bcm2835_gpio_fsel(PIN2, BCM2835_GPIO_FSEL_ALT0);
bcm2835_gpio_fsel(CTL_PIN, BCM2835_GPIO_FSEL_OUTP);
bcm2835_gpio_fsel(CTL_PIN2, BCM2835_GPIO_FSEL_OUTP);
// Clock divider is set to 16.
// With a divider of 16 and a RANGE of 1024, in MARKSPACE mode,
// the pulse repetition frequency will be
// 1.2MHz/1024 = 1171.875Hz, suitable for driving a DC motor with PWM
bcm2835_pwm_set_clock(BCM2835_PWM_CLOCK_DIVIDER_16);
bcm2835_pwm_set_mode(PWM_CHANNEL, 1, 1);
bcm2835_pwm_set_range(PWM_CHANNEL, RANGE);
bcm2835_pwm_set_mode(PWM_CHANNEL2, 1, 1);
bcm2835_pwm_set_range(PWM_CHANNEL2, RANGE);
// Vary the PWM m/s ratio between 1/RANGE and (RANGE-1)/RANGE
int direction = 1;
int data = 1;
int j;
bcm2835_gpio_write(CTL_PIN, HIGH);
bcm2835_gpio_write(CTL_PIN2, HIGH);
for (j=0;j<4096;j++)
if (j==2048) {
bcm2835_gpio_write(CTL_PIN, LOW);
// bcm2835_gpio_write(CTL_PIN2, LOW);
if (data == 1)
direction = 1;
else if (data == RANGE-1)
direction = -1;
data += direction;
bcm2835_pwm_set_data(PWM_CHANNEL, data);
bcm2835_pwm_set_data(PWM_CHANNEL2, data);
bcm2835_delay(10);
bcm2835_pwm_set_data(PWM_CHANNEL, 0);
bcm2835_pwm_set_data(PWM_CHANNEL2, 0);
bcm2835_close();
return 0;
