kusti8
Re: Guide: Chromium 49 on Raspbian Jessie
Tue Apr 19, 2016 10:32 pm
rustybolt wrote:I tested my sound today and it works, but for omxplayer I have to include the -o local switch (see this thread). Is there any way to make RPi-youtube run omxplayer with this switch?
RPi-youtube uses OmxplayerGUI. When you open that up and go to settings you should be able to change all of the settings there.
rustybolt
Tue Apr 19, 2016 10:41 pm
I can, but adding -o local to "general omxplayer audio video options" doesn't help. Whatever, it's bedtime for me now. Thanks for your fast replies man! Don't sweat it ;)
Edit: Ah, I there is a seperate section for youtube streams. It works now :D
Ben_is_best
Wed Apr 20, 2016 12:59 am
gkreidl wrote:
Ben_is_best wrote:
The right one can be found at https://launchpad.net/ubuntu/trusty/arm ... m-browser/.
No 50 version. And there's an unmet dependency on Jessie; that's why kusti8 will compile a new version (and has done so for 49).
I know. I was just saying that once it comes out it will be there.
gkreidl
Wed Apr 20, 2016 5:10 am
There are for different places where you can add omxplayer options: for audio player, normal video player, live TV player and for web video. You can add
-o
local
(two lines!) to all of them or just to youtube_omxoptions for use with rpi-youtube. I recommend to save the setting as a preset "analog" (or whatever name you want).
For more details read this: viewtopic.php?p=952056#p952056
Minimal Kiosk Browser (kweb)
rustybolt
Wed Apr 20, 2016 9:25 am
-o
local
Yes, I found them, and it everything works perfectly now :) I already edited my earlier post but your post is probably a better explanation, for anyone with the same problem who finds this thread.
mi7chy
Wed Apr 20, 2016 3:55 pm
Is there any way to go back to the previous Chrome 48 version? Thanks
gkreidl
Wed Apr 20, 2016 5:48 pm
mi7chy wrote:Is there any way to go back to the previous Chrome 48 version? Thanks
Why?
mi7chy
Wed Apr 20, 2016 6:34 pm
gkreidl wrote:Why?
I like to keep consistency across multiple RPi3s plus I'm trying to determine if the newest RPi3 addition is running hotter causing the flashing yellow square because of hardware or because of software differences running different versions of Chrome.
kusti8
Wed Apr 20, 2016 7:10 pm
mi7chy wrote:
gkreidl wrote:Why?
Do:
apt-cache showpkg chromium-browser
And find the version from there.
Then:
sudo apt-get install chromium-browser=[version]
mi7chy
Wed Apr 20, 2016 9:00 pm
kusti8 wrote: Do:
Then:
Much appreciated. Was able to get past the errors (see below) and install Chrome version 48 by removing then installing the older chromium-codecs-ffmpeg-extra pkg using your method. Turns out it's the new RPi3 hardware with slightly older date code that's running hotter and causing the flashing yellow square as suspected.
[email protected]:~/Downloads $ sudo apt-get install chromium-browser=48.0.2564.82-0ubuntu0.15.04.1.1193
Reading package lists... Done
Building dependency tree
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
chromium-browser : Depends: chromium-codecs-ffmpeg-extra (= 48.0.2564.82-0ubuntu0.15.04.1.1193) but 49.0.2623.108-0ubuntu0.14.04.1.1113 is to be installed or
chromium-codecs-ffmpeg (= 48.0.2564.82-0ubuntu0.15.04.1.1193) but it is not installable
Recommends: chromium-browser-l10n but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
matteusbeus
Wed Apr 27, 2016 12:31 pm
I noticed someone else has previously mentioned in this thread about webkitSpeechRecognition. I was wondered if someone could tell me if it actually works? I need it for a core element in my PhD and it will save me a fortune in hardware if I can get it working!
kusti8
Wed Apr 27, 2016 12:32 pm
matteusbeus wrote:I noticed someone else has previously mentioned in this thread about webkitSpeechRecognition. I was wondered if someone could tell me if it actually works? I need it for a core element in my PhD and it will save me a fortune in hardware if I can get it working!
I'm very busy this week so I can't do much and I'm not sure if they got it to work. I'll check it out if I have time, but any instructions for Chromium should work fine here.
matteusbeus
Wed Apr 27, 2016 12:37 pm
Thanks for the amazingly prompt response! I think the pi might have an issue with the GetVoices call in the same way Chrome on PC presently does. Anyhow I'll be here to read the response whenever you get chance! Thank you :D
kusti8
Sat Apr 30, 2016 3:06 pm
I've released v0.5.0 of RPi-youtube, including automatic pausing of youtube videos when the icon is clicked and a minor speed improvement to about 3-5 seconds after subsequent plays!
Enjoy!
matteusbeus
Sat Apr 30, 2016 3:19 pm
<html>
<head>
</head>
<body>
<p>This is a chunk of text that will be spoken.</p>
<script>
function SpeakVoice(textToSpeak) {
	var t;
	if (window.speechSynthesis != undefined) {
		var selectedVoice = 'SpeakIt!';
		console.log("Speech Synthesis API is avaliable in your Browser");
		window.speechSynthesis.cancel();
		var watch = setInterval(function() {
		voices = speechSynthesis.getVoices();
		if (voices.length !== 0) {
			console.log("Got voices!");
			var u = new SpeechSynthesisUtterance();
			u.voice = voices.filter(function(voice) { return voice.name == selectedVoice; })[0];
			for(var i = 0; i < voices.length ; i++) {
				console.log(voices[i].name + ' (' + voices[i].lang + ')');
				console.log(voices[i].name);
			u.text = textToSpeak;
			u.onstart = function (event) {
				t = event.timeStamp;
				console.log("starting speech: " + t);
			u.onend = function (event) {
				t = event.timeStamp-t;
				console.log("ending speech: " + event.timeStamp);
			    	console.log((t/1000) +' seconds');
			window.speechSynthesis.speak(u);
			clearInterval(watch);
		  } else {
			console.log("No voices found");
		}, 200);
	} else {
		alert("Sorry - the Speech Synthesis API is not available in your Browser");
SpeakVoice("Hello there");
</script>
</body>
</html>
I've tried running this code and the "getvoices" of the Speech Synthesis API doesn't work on Raspian for some reason :/
kusti8
Sat Apr 30, 2016 3:20 pm
Just tested it and it seems to work. I made my USB soundcard the default using this: http://raspberrypi.stackexchange.com/qu ... ian-jessie
And I then went to http://www.google.com/intl/en/chrome/demos/speech.html and tried talking and it worked!
matteusbeus
Sat Apr 30, 2016 3:22 pm
Is the text to speech component working though? I get the impression the speech to text is but not the text to speech.
kusti8
Sat Apr 30, 2016 4:19 pm
I tried it and after installing a voice it works the first time but then doesn't work anymore until you restart the browser.
matteusbeus
Sat Apr 30, 2016 4:51 pm
kusti8 wrote:I tried it and after installing a voice it works the first time but then doesn't work anymore until you restart the browser.
out of interest how are you installing a voice? are you using speech-dispatcher and espeak? or something else?
kusti8
Sat Apr 30, 2016 4:53 pm
I installed SpeakIt, but I haven't tried espeak and I don't know if it works. Our of curiosity, why do you need TTS in the browser?
matteusbeus
Sat Apr 30, 2016 4:58 pm
I've written a web based AI. I'm using the TTS to give it a voice. Once I start publishing papers from my studies, I'll be able to explain in more detail.
matteusbeus
Sat Apr 30, 2016 5:01 pm
Speak it works a treat!!! Thank you so much :)
kusti8
Sat Apr 30, 2016 5:03 pm
It works more than once? Well, anyway, enjoy!
matteusbeus
Sat Apr 30, 2016 7:11 pm
Version 49 has been crashing on me with
ERROR:sandbox_linux.cc(334)] InitializeSandbox() called with multiple threads in process gpu-process
I've discovered this is a issue specifically with 49
https://ubuntu-mate.community/t/chromiu ... aults/4578
kusti8
Sat Apr 30, 2016 7:14 pm
matteusbeus wrote:Version 49 has been crashing on me with
That's always been there and isn't really an error. Chromium still starts and works.
