My pi3:
viewtopic.php?f=63&t=144391&p=952371#p952371
My Overclock (Ambient:
20C; Idle:
28C; Full Load with Stress
43C; Full Load with cpuburn-a53
61C; With Linpack
54C)
dtparam=sd_overclock=100
arm_freq=1260
core_freq=500
over_voltage=4
sdram_freq=575
sdram_schmoo=0x02000020
over_voltage_sdram_p=6
over_voltage_sdram_i=4
over_voltage_sdram_c=4
v3d_freq=500
h264_freq=333
linpack on overclocked pi3 @ 1.26 GHz N=8000 Gflop 6.74
pi@raspberrypi:~ $ ./xhpl
HPLinpack 2.1 -- High-Performance Linpack benchmark -- October 26, 2012
Written by A. Petitet and R. Clint Whaley, Innovative Computing Laboratory, UTK
Modified by Piotr Luszczek, Innovative Computing Laboratory, UTK
Modified by Julien Langou, University of Colorado Denver
An explanation of the input/output parameters follows:
T/V : Wall time / encoded variant.
N : The order of the coefficient matrix A.
NB : The partitioning blocking factor.
P : The number of process rows.
Q : The number of process columns.
Time : Time in seconds to solve the linear system.
Gflops : Rate of execution for solving the linear system.
The following parameter values will be used:
N : 8000
NB : 256
PMAP : Row-major process mapping
P : 1
Q : 1
PFACT : Left
NBMIN : 2
NDIV : 2
RFACT : Right
BCAST : 2ring
DEPTH : 0
SWAP : Mix (threshold = 64)
L1 : transposed form
U : transposed form
EQUIL : yes
ALIGN : 8 double precision words
- The matrix A is randomly generated for each test.
- The following scaled residual check will be computed:
||Ax-b||_oo / ( eps * ( || x ||_oo * || A ||_oo + || b ||_oo ) * N )
- The relative machine precision (eps) is taken to be 1.110223e-16
- Computational tests pass if scaled residuals are less than 16.0
T/V N NB P Q Time Gflops
WR02R2L2 8000 256 1 1 50.63 6.743e+00
HPL_pdgesv() start time Sat Apr 23 14:38:56 2016
HPL_pdgesv() end time Sat Apr 23 14:39:47 2016
||Ax-b||_oo/(eps*(||A||_oo*||x||_oo+||b||_oo)*N)= 0.0025941 ...... PASSED
Finished 1 tests with the following results:
1 tests completed and passed residual checks,
0 tests completed and failed residual checks,
0 tests skipped because of illegal input values.
End of Tests.
N=8000 Gflop 6.6 with overclocks appears to be stable (no fails)
N : 8000
NB : 256
P : 1
Q : 1
PFACT : Left
NBMIN : 2
NDIV : 2
RFACT : Right
BCAST : 2ring
DEPTH : 0
U : transposed form
EQUIL : yes
WR02R2L2 8000 256 1 1 51.27 6.660e+00
HPL_pdgesv() start time Sun Apr 24 09:13:21 2016
HPL_pdgesv() end time Sun Apr 24 09:14:12 2016
End of Tests.
N : 8000
NB : 256
P : 1
Q : 1
PFACT : Left
NBMIN : 2
NDIV : 2
RFACT : Right
BCAST : 2ring
DEPTH : 0
U : transposed form
EQUIL : yes
WR02R2L2 8000 256 1 1 51.47 6.634e+00
HPL_pdgesv() start time Sun Apr 24 09:14:53 2016
HPL_pdgesv() end time Sun Apr 24 09:15:44 2016
End of Tests.
N : 8000
NB : 256
P : 1
Q : 1
PFACT : Left
NBMIN : 2
NDIV : 2
RFACT : Right
BCAST : 2ring
DEPTH : 0
U : transposed form
EQUIL : yes
WR02R2L2 8000 256 1 1 51.69 6.605e+00
HPL_pdgesv() start time Sun Apr 24 09:16:14 2016
HPL_pdgesv() end time Sun Apr 24 09:17:06 2016
End of Tests.
Stock at 1.2 GHz (over_voltage=4) N=8000 Gflop 6.25
N : 8000
NB : 256
P : 1
Q : 1
PFACT : Left
NBMIN : 2
NDIV : 2
RFACT : Right
BCAST : 2ring
DEPTH : 0
U : transposed form
EQUIL : yes
WR02R2L2 8000 256 1 1 54.59 6.255e+00
HPL_pdgesv() start time Sat Apr 23 14:55:29 2016
HPL_pdgesv() end time Sat Apr 23 14:56:23 2016
End of Tests.
Stock at 1.2 GHz (over_voltage=1) N=8000 Gflop 6.16
N : 8000
NB : 256
P : 1
Q : 1
PFACT : Left
NBMIN : 2
NDIV : 2
RFACT : Right
BCAST : 2ring
DEPTH : 0
U : transposed form
EQUIL : yes
WR02R2L2 8000 256 1 1 55.37 6.166e+00
HPL_pdgesv() start time Sat Apr 23 15:14:17 2016
HPL_pdgesv() end time Sat Apr 23 15:15:12 2016
End of Tests.
