bertwert
Controlling a 7 segment 4 digit display with a Raspberry Pi
Sun Nov 16, 2014 5:10 pm
http://www.instructables.com/id/Control ... ith-a-Ras/
This instructable I made shows how to control a display.
Here is how:
Wiring:
The pins are connected to the Pi through a resistor and some directly.
See the diagrams for details and pin positionnement.
The python modules; time and RPI.GPIO are required for this code.
Code:
import RPi.GPIO as GPIO
import time
GPIO.setmode(GPIO.BOARD)
GPIO.setwarnings(False)
GPIO.setup(7, GPIO.IN, pull_up_down=GPIO.PUD_DOWN)
segments = (24,12,19,21,23,22,15,11)
for segment in segments:
    GPIO.setup(segment, GPIO.OUT)
    GPIO.output(segment, 0)
digits = (26,18,16,13)
for digit in digits:
    GPIO.setup(digit, GPIO.OUT)
    GPIO.output(digit, 1)
num = {' ':(0,0,0,0,0,0,0),
    '0':(1,1,1,1,1,1,0),
    '1':(0,1,1,0,0,0,0),
    '2':(1,1,0,1,1,0,1),
    '3':(1,1,1,1,0,0,1),
    '4':(0,1,1,0,0,1,1),
    '5':(1,0,1,1,0,1,1),
    '6':(1,0,1,1,1,1,1),
    '7':(1,1,1,0,0,0,0),
    '8':(1,1,1,1,1,1,1),
    '9':(1,1,1,1,0,1,1)}
try:
    while True:
        n = time.ctime()[11:13]+time.ctime()[14:16]
        s = str(n).rjust(4)
        for digit in range(4):
            for loop in range(0,7):
                GPIO.output(segments[loop], num[s[digit]][loop])
        if (int(time.ctime()[18:19])%2 == 0) and (digit == 1)
            GPIO.output(11, 1)
        else:
            GPIO.output(11, 0)
        GPIO.output(digits[digit], 0)
        time.sleep(0.001)
        GPIO.output(digits[digit], 1)
except KeyboardInterrupt:
    GPIO.cleanup()
And we are done!
This will be a clock.
Have fun!
Please correct me if I am wrong ;-)
Please post your code with these tags:
[code]Your Code Goes Here[/code]
BERTWERT
bertwert
Re: Controlling a 7 segment 4 digit display with a Raspberry
Wed Feb 11, 2015 7:01 pm
EDITED:
There were errors in the code indentation, now corrected!
BERTWERT
Wed Feb 11, 2015 7:59 pm
You're using 12 GPIO lines to drive four displays. Now look at using a shift register or BCD to 7-segment controller chip. You can easily drive 16, 7-segment displays on 8 gpio lines (four for data, four for select).
Microprocessor, Raspberry Pi & Arduino Hacker
Mainframe database troubleshooter
MQTT Evangelist
Twitter: @DougieLawson
Since 2012: 1B*5, 2B*2, B+, A+, Zero*2, 3B*3
Please post ALL technical questions on the forum. Do not send private messages.
icemann1978
Tue Oct 27, 2015 8:54 am
I Come from Germany and my English is bad... Sorry about that.
I try 5 days to run a 7 segment display like this example but it doesn't work. Cable 10 times checked segment for segment tested. Has anything changed python or so?
Tue Oct 27, 2015 12:22 pm
How do you have your display wired give us a Fritzing diagram and/or a photo of your wiring? Are you using a BCD to 7-seg decoder? Are you using a shift register? Or are you trying to multiplex the display directly from the GPIO pins?
MQTT Evangelist
icemann1978
Tue Oct 27, 2015 8:41 pm
hi,
i'am try it exactly like the example in the first post
pict:
Tue Oct 27, 2015 9:11 pm
I'll need to run an experiment to work out what's wrong. Watch this space ...
MQTT Evangelist
icemann1978
Wed Oct 28, 2015 4:52 pm
oh thanks, thats nice
Wed Oct 28, 2015 4:58 pm
First question is your 7 seg display common anode or common cathode? The OP doesn't tell us which model he's using. If it's the opposite we're going to have to turn all the logic upside down in his code.
MQTT Evangelist
icemann1978
Wed Oct 28, 2015 5:03 pm
i have 7seg with common anode, i think he also.
rugabi94
Fri Oct 30, 2015 11:30 am
It's not really working for me. I think I have the correct wiring I have 4 digits 7 segment: LTC-5623-HR and I have
File "time.py", line 62
SyntaxError: invalid syntax
Fri Oct 30, 2015 3:46 pm
My theory is proven @icemann1978's LED is common anode, the code is written for common cathode LEDs.
So all the logic has to be inverted. We end up with this version of Bert's code
#!/usr/bin/python
# Bert's code re-written for common anode LED arrays.
import time
import sys
#LED pin == GPIO == segment / digit
# 11     ==  24  == a
# 07     ==  12  == b
# 04     ==  19  == c
# 02     ==  21  == d
# 01     ==  23  == e
# 10     ==  22  == f
# 05     ==  15  == g
# 03     ==  11  == dp
  GPIO.output(segment, 1)
# 12     ==  26  == digit 1
# 09     ==  18  == digit 2
# 08     ==  16  == digit 3
# 06     ==  13  == digit 4
  GPIO.output(digit, 0)
num = {' ':(1,1,1,1,1,1,1),
'0':(0,0,0,0,0,0,1),
'1':(1,0,0,1,1,1,1),
'2':(0,0,1,0,0,1,0),
'3':(0,0,0,0,1,1,0),
'4':(1,0,0,1,1,0,0),
'5':(0,1,0,0,1,0,0),
'6':(0,1,0,0,0,0,0),
'7':(0,0,0,1,1,1,1),
'8':(0,0,0,0,0,0,0),
'9':(0,0,0,0,1,0,0)}
try:
  while True:
    s = str(n).rjust(4)
        if (int(time.ctime()[18:19])%2 == 0) and (digit == 1):
          GPIO.output(11, 0)
        else:
          GPIO.output(11, 1)
      time.sleep(0.001)
  GPIO.cleanup()
MQTT Evangelist
icemann1978
Fri Oct 30, 2015 5:16 pm
Wow thanks dougieLawson, I will try this
@rugabi94
Try a : at the end of the line after
== 1)
icemann1978
Sat Oct 31, 2015 12:31 pm
PERFECT!!!
DougieLawson you´re the BEST
many many thanks
blachanc
Fri Nov 06, 2015 4:40 am
Using Dougie's code (Many thanks) I got it working with a 3.3v 4 digit display with built-in resistor.
I wired the display using my raspio Ruler as a reference, so I had to replace:
by:
GPIO.setmode(GPIO.BCM)
EBAY 8 SEG LED Board Four 8-Segment Digits Digital Display information Eg:Time Module
Fun an fast (but display is a bit dim, as each segment is on only 25% of the time)
Now, let's see if I can get my kids interested ;)
Ben
Autism/Asperger syndrome: what is your score on this quiz?
http://www.raspberrypi.org/forums/viewtopic.php?f=62&t=70191
bertwert
Sat Nov 07, 2015 8:50 pm
Thanks Dougie for covering for me.
I have been inactive on these forums for a while...
BERTWERT
alexeames
Wed Nov 11, 2015 4:57 pm
I just went through this and wondered why I wasn't getting more than one digit.
I copied Bertwert's original code, and apart from fixing the missing : eventually I realised the copy & paste had messed up the indents so the loop was not iterating through all four segments.
I append the code in case it will help anyone else with the same issue. (Oh I changed everything to BCM as well, just to be awkward :lol: )
Oh yeah - one more thing. I don't think this line...
GPIO.setup(4, GPIO.IN, pull_up_down=GPIO.PUD_DOWN)
...is doing anything, since there is nothing connected to pin7/GPIO4, and it's not read in the script.
import time
segments = (8,18,10,9,11,25,22,17)
digits = (7,24,23,27)
try:
    while True:
        s = str(n).rjust(4)
                    GPIO.output(17, 1)
                else:
                    GPIO.output(17, 0)
            time.sleep(0.001)
    GPIO.cleanup()
Alex Eames RasPi.TV, RasP.iO
blachanc
Thu Nov 12, 2015 6:00 pm
Next step is converting this in a generic "display_script.py" reading its data from an external source.
The fun part is the display cannot stop/starve (always dynamic).
I am thinking about using the global variable approach os.environ.["7SEGDISP"]="0123":
example:
script "calculate_primes.py" outputs the value in chunck to a system ENV variable "7SEGDISP" , and "display_script.py" loops and constantly update the display according to the ENV variable "7SEGDISP".
I want to avoid passing data via a file (SD card wear), and I know that one flaw in my idea is that both scripts needs to be started in the same terminal.
let me know if you believe there is a better way than what i am thinking about (Maybe a ramdisk file ?)
Ben
blachanc
Fri Nov 13, 2015 3:51 am
Well,
I learned something(correct me if I am wrong): a python script does not read the updated env variable value in a terminal. It will keep the values it reads when it is invoked.
SO I reverted back to my second idea of using a file on a ramdisk for communication(and it is working). I still wonder if there would be a better way.
this is the main display loop (display daemon):
display.py
#!/usr/bin/python
#blachanc: used dougie's code and added external data input in ramdisk
import time
import sys
#GPIO.setmode(GPIO.BOARD)
# 11     ==  24  == a
# 07     ==  12  == b
# 04     ==  19  == c
# 02     ==  21  == d
# 01     ==  23  == e
# 10     ==  22  == f
# 05     ==  15  == g
# 03     ==  11  == dp
charactere = {' ':(1,1,1,1,1,1,1),
counter=100000
# use a file on ramdisk to get the data to be displayed
# bash commands passed in terminal:
# sudo mkdir /mnt/ramdisk
# sudo mount -t tmpfs -o size=128K tmpfs /mnt/ramdisk
# sudo chown pi:pi /mnt/ramdisk
# echo "1235" > /mnt/ramdisk/display.dat
def get_data_to_display():
    txt=open("/mnt/ramdisk/display.dat")
    new_string = str(txt.readline())
    txt.close()
    new_string=new_string.rstrip()
	# buf with 0 if less than 4 char
    new_string= str(new_string).rjust(4,"0")
	# limit to 4 chars
    new_string= new_string[0:4]
    return new_string
# main loop
try:
  while True:
	# First we only update the data to display each x loops
    counter +=1
    if (counter > 50):
       counter = 0
       new_string = get_data_to_display()
# for debug only       print  new_string
       data_to_display = new_string
        GPIO.output(segments[loop], charactere[data_to_display[digit]][loop])
      time.sleep(0.001)
  GPIO.cleanup()
and this is the data being feed to the display (scrolling numbers) for proof of concept.
feedata.py:
#!/usr/bin/python
import time
import sys
counter = 0
data_to_display= "    "
# main loop
try:
  while True:
    counter +=1
    if (counter > 9):
       counter = 0
     # shift the data to be displayed
    data_to_display= data_to_display[1] + data_to_display[2] + data_to_display[3]+ (str(counter))[0]
    txt=open("/mnt/ramdisk/display.dat", "w" )
    txt.write(data_to_display)
    txt.close()
# For debug only    print data_to_display
    time.sleep(.5)
  exit()
Waynetho
Tue Apr 05, 2016 3:05 am
I'm new to Python and I was wanting to make a digital clock for my bedroom. I tore apart an old LED digital clock that didn't work right, scavenged the digit mask from the old display and build my own display using tiny red axial-leaded "SuperBright" LEDs.
I've got a couple of issues still outstanding with this approach, specifically the LEDs are *VERY" dim (I'll work on that, maybe using a higher voltage to the LEDs, switched by transistors. The second issue is that I would like the clock to be a 12-hour clock (AM/PM indicator is desirable, but not necessary).
My display has an incomplete first digit so it can only display a "1" or nothing for the first digit. It looks like the only way to accomplish this would be to use "time.strftime" instead of "time.ctime" because it has the option of %H for 24-hr hours or %I for 12-hr hours.
Does anyone have any suggestions on how to modify the code to display 12-hr time?
Tue Apr 05, 2016 9:39 am
The current code is using time.ctime() and parsing that. Change it to use time.strftime() and you can get the time in any format you need.
>>> import time
>>> print time.ctime()
Tue Apr  5 09:38:06 2016
>>> print time.strftime('%I')
09
>>> print time.strftime('%I:%M %p')
09:38 AM
MQTT Evangelist
teddycool
Sat Aug 20, 2016 5:35 pm
Thanx for sharing this!
I used it as a base in my project creating a display device that will show time, temperature and some other information on a 4-digit 7-segment display. The project is available here https://github.com/teddycool/ClockDisplay
depauw
Thu Sep 29, 2016 2:28 pm
Hey guys,
does anyone of you how to get this working, using zerogpio istead of the 'normal' gpio.
Been looking around for an example, but haven't found anything yet...... :(
Kind regards,
Christophe
Notilix
Mon Dec 05, 2016 9:03 pm
Hi!
I have a question about the code.
In the loop
you’re stating each GPIO to True for every segment needing light. Okay but you don’t light them now, you light them a bit further with
right?
What I don’t understand is this: if I need to display an “8.”, with your code I will power on 8 leds simultaneously for about 0.001s okay? But… every led consume about 13mA and 8*13 = 104. It doesn’t respect the 50mA total rule! Even for a very short perdiod, are you sure it doesn’t damage GPIO controller ?
What about limiting two or tree segments simultaneously for a very short time and then light another bunch of 3 leds but do not allow all leds if needed simultaneously? Wouldn’t be safer?
lohtse
Mon Jan 30, 2017 8:25 am
Hi all
we have just recieved two of these https://www.aliexpress.com/item/4-Bits- ... 20e1e5d1a1 TM1637-for-Arduino-Raspberry-PI. We are looking for any help and advise with wiring and pinouts for use with our Pi-3's Also what would be the best code to use to allow us to use them as clocks??
looking forward to any and all assistance..
regards
Lohtse
3x Pi-3 1 x Pi-2 1 x Pi-B+ 1 x Pi-B 2 xPi-Zero 1 x Pi Zero W and a massive ever growing box/room of bits and bobs for them!
Who is online
Users browsing this forum: No registered users and 12 guests
