raspiBenett
Access to Windows store?
Fri Apr 01, 2016 12:43 pm
Hello together,
I have a short question concerning Windows 10 IoT running on a raspberry pi 3.
Do you have the possibility to access the Windows Store or is this only possible with the "normal" Windows 10?
I want to download the Fitbit Connect App which is running on Windows 10.
Thanks in advance.
Re: Access to Windows store?
Fri Apr 01, 2016 4:49 pm
[quote="raspiBenett"]Hello together,
Only Universal Windows Apps are supported:
https://msdn.microsoft.com/en-us/window ... 2147217396
https://msdn.microsoft.com/en-us/window ... hats-a-uwp
https://developer.microsoft.com/en-us/w ... ndows-apps
RPi 4B 4GB (SSD Boot)..
raspiBenett
Sun Apr 03, 2016 11:41 am
Thank you for your answer!
If I understand it right, all Universal Windows Apps can be installed, but there is no access to the Windows Store.
In the concrete case, Fitbit connect is a Universal Windows App and therefor it should be the possibility to install the app on Windows10 IoT. Am I right? If yes, how is the easiest way?
Thank you.
Sun Apr 03, 2016 11:56 am
That's not true. The Raspberry Pi runtime is a subset of full-fat Windows and you'll find that functions that aren't part of the IoT stack simply won't run.
If you want to run Fitbit, get a regular laptop or other X86 based WIn10 system and forget trying to run that stuff on a RPi.
mimi123
Sun Apr 03, 2016 2:47 pm
raspiBenett wrote:Hello together,
Thanks in advance.
The Windows Store needs Windows 10 Mobile, which can also be made to work on an RPi
raspiBenett
Thu Apr 07, 2016 1:59 pm
Thank you alltogether for the replies!
It is much more clear now.
