Been going for about an hour so far, do I have time for 2 pints?
I'm thinking easily...
The SD card clockspeed can be set with init_emmc_clock in config.txt, see http://elinux.org/RPi_config.txt#Boot_optionsian.macarthur123 wrote:As an aside, I doubt the class of the SD card is making that much of a difference, since it looks very much as if the the way the SD interface is being clocked in the R-Pi is set to a fixed (and relatively low) clock speed.
Heh, true enough - but if you find yourself building the kernel often (as I did recently trying to keep my wifi module in sync with the firmware updates!) it becomes a bind waiting over night all the time! I must say I'm not familiar with ccache though.Lorian wrote:There is no fun in that
